03-14-2018, 10:58 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: FOCSANI Age: 39
Member: 718470 Status: Offline Thanks Meter: 79 | LG D820 error write firmware [Answered] error any firmware? -------------------------------------------------------------------------------- Opening "LGD820AT-00-V10a-NXS-OCT-09-2013-KQS81M-USER-16G+ 0.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing rpm...OK Writing tz...OK Writing sdi...OK Writing aboot...OK Writing sbl1b...OK Writing tzb...OK Writing rpmb...OK Writing abootb...OK Writing persist...OK Writing imgdata...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing system...Failed! LAF Error: 00000000. Write Firmware operation is currently not supported for your phone's firmware. Error code: ZXLCALSZXC Performed by 2.8.0 Software version. Last edited by Octopus box; 03-14-2018 at 11:32. |
03-14-2018, 11:31 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Fully charge phone's battery, try to write the latest firmware again and post here full Software log, not reduced, we will check it. |
03-15-2018, 08:57 | #3 (permalink) |
Member: 718470 Status: Offline Thanks Meter: 79 | the same error Welcome to Octoplus/Octopus Box LG Software version 2.8.0 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM102 Selected model: D820 Reading info... IMEI: 352136-06-919529-1 Android version: Battery level: 100% SW Version: LGD821AT-00-V10d-NXS-XX-DEC-11 Mode: Emergency Initializing flash...OK SW version: LGD821AT-00-V10d-NXS-XX-DEC-11-2013-KOT49H-USER- 16G+0 Android version: 6.0.1 LAF Version: 1.0 Product ID: PT04S140326002572 IMEI: 352136-06-919529-1 Target operator: ro.build.target_coun Hardware: rev_11 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "LGD820AT-00-V10a-NXS-OCT-09-2013-KQS81M-USER-16G+ 0.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing rpm...OK Writing tz...OK Writing sdi...OK Writing aboot...OK Writing sbl1b...OK Writing tzb...OK Writing rpmb...OK Writing abootb...OK Writing persist...OK Writing imgdata...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing system...Failed! LAF Error: 00000000. Write Firmware operation is currently not supported for your phone's firmware. Error code: ZXLCALSZXC Performed by 2.8.0 Software version. |
03-15-2018, 09:18 | #4 (permalink) | |||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Quote:
As we can see from the Software log which You have provide us, your device is d821 but You have selected D820 and use firmware file for D820 phone mode. | |||
03-15-2018, 09:40 | #5 (permalink) |
Member: 718470 Status: Offline Thanks Meter: 79 | Welcome to Octoplus/Octopus Box LG Software version 2.8.0 Connecting to server support.octoplusbox.com:82...OK Authorizing...OK -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM102 Selected model: D821 Reading info... IMEI: 352136-06-919529-1 Android version: Battery level: 100% SW Version: LGD821AT-00-V10d-NXS-XX-DEC-11 Mode: Emergency Initializing flash...OK SW version: LGD821AT-00-V10d-NXS-XX-DEC-11-2013-KOT49H-USER- 16G+0 Android version: 6.0.1 LAF Version: 1.0 Product ID: PT04S140326002572 IMEI: 352136-06-919529-1 Target operator: ro.build.target_coun Hardware: rev_11 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "LGD821AT-00-V10b-NXS-OCT-31-2013-KRT16M-USER-16G+ 0.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing rpm...OK Writing tz...OK Writing sdi...OK Writing aboot...OK Writing sbl1b...OK Writing tzb...OK Writing rpmb...OK Writing abootb...OK Writing persist...OK Writing imgdata...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing system...Failed! LAF Error: 00000000. Write Firmware operation is currently not supported for your phone's firmware. Error code: ZXLCALSZXC Performed by 2.8.0 Software version. |
03-15-2018, 13:14 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | What is the problem/state of your phone exactly? Why You have decided to re-flash it? Last edited by Octopus box; 03-15-2018 at 14:17. |
