07-09-2019, 13:29 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | lg d850 flash error [Solved] -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM172 Selected model: D850 Reading info... Model ID: LG-D850 IMEI: 014065-00-410198-3 Android version: 6.0 Battery level: 6% Mode: Emergency Initializing flash...OK Platform: msm8974 SW version: LGD850AT-00-V30p-310-410-JUL-19-2016+0 Android version: 6.0 LAF Version: 1.1 Product ID: SM05S140911003033 IMEI: 014065-00-410198-3 Target operator: ATT Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "LGD850AT-01-V21l-310-410-APR-06-2015+0.oct"...OK Selecting firmware partitions...OK Selected default partitions! Setting options...OK Do you want to format User Data? Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing dbi...OK Writing aboot...OK Writing rpm...OK Writing tz...OK Writing boot...OK Writing persist...OK Writing recovery...OK Writing laf...OK Writing factory...OK Writing system...Failed! LAF Error: 00000000. Write Firmware operation is currently not supported for your phone's firmware. Error code: ZXLCALSZXC Performed by 2.9.5 Software version. |
07-09-2019, 13:49 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. At first: Battery level: 6% Second: LGD850AT-00-V30p-310-410-JUL-19-2016+0 > pening "LGD850AT-01-V21l-310-410-APR-06-2015+0.oct"...OK Downgrade may lead to phone damage! Third: As You can see from the Software log: Write Firmware operation is currently not supported for your |
07-09-2019, 13:51 | #3 (permalink) | |
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | Quote:
07-09-2019, 15:44 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Why You have decided to re-flash it? P.S Unfortunately, we don't have any other firmwares for this device, except that what are available at the Support Area |
07-09-2019, 18:18 | #8 (permalink) | |
so pls upload latest firmware for recovery my problem | |
07-10-2019, 10:00 | #9 (permalink) |
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | Welcome to Octoplus/Octopus Box LG Software version 2.9.5 -------------------------------------------------------------------------------- Checking data... Access violation at address 00000000. Read of address 00000000OK Platform: LG Qualcomm Selected port: COM170 Selected model: D850 Reading info... Access violation at address 00000000. Read of address 00000000 Model ID: LG-D850 IMEI: 014065-00-410198-3 Android version: 6.0 Battery level: 84% Mode: Emergency Initializing flash...OK Platform: msm8974 SW version: LGD850AT-00-V30p-310-410-JUL-19-2016+0 Android version: 5.0.1 LAF Version: 1.1 Product ID: SM05S140911003033 IMEI: 014065-00-410198-3 Target operator: ATT Hardware: rev_10 This operation is not supported in emergency mode! Performed by 2.9.5 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM170 Selected model: D850 Reading info... Model ID: LG-D850 IMEI: 014065-00-410198-3 Android version: 6.0 Battery level: 84% Mode: Emergency Initializing flash...OK Platform: msm8974 SW version: LGD850AT-00-V30p-310-410-JUL-19-2016+0 Android version: 5.0.1 LAF Version: 1.1 Product ID: SM05S140911003033 IMEI: 014065-00-410198-3 Target operator: ATT Hardware: rev_10 Opening "D850PR30a_00_0209.kdz"...OK Firmware version: LGD850AT-00-V30a-CLR-PR-FEB-09-2017+0 Firmware model: LG-D850 Firmware type: 0100 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Prepairing firmware...OK Selecting firmware partitions...OK Selected default partitions! Setting options...OK Do you want to format User Data? Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing 1/44 PrimaryGPT_0.bin...OK Writing 2/44 modem_32768.bin...OK Writing 3/44 sbl1_163840.bin...OK Writing 4/44 dbi_165888.bin...OK Writing 5/44 aboot_167936.bin...OK Writing 6/44 rpm_172032.bin...OK Writing 7/44 tz_174080.bin...OK Writing 8/44 boot_196608.bin...OK Writing 9/44 persist_229376.bin...OK Writing 10/44 recovery_294912.bin...OK Writing 12/44 laf_393216.bin...OK Writing 13/44 factory_671744.bin...OK Writing 14/44 system_753664.bin...OK Writing 15/44 system_1017288.bin...OK Writing 16/44 system_1281976.bin...OK Writing 17/44 system_1541576.bin...OK Writing 18/44 system_1545600.bin...OK Writing 19/44 system_1806264.bin...OK Writing 20/44 system_2065864.bin...OK Writing 21/44 system_2069888.bin...OK Writing 22/44 system_2330552.bin...OK Writing 23/44 system_2590152.bin...OK Writing 24/44 system_2594176.bin...OK Writing 25/44 system_2854840.bin...OK Writing 26/44 system_3114440.bin...OK Writing 27/44 system_3118464.bin...OK Writing 28/44 system_3379128.bin...OK Writing 29/44 system_3641272.bin...OK Writing 30/44 system_3903416.bin...OK Writing 31/44 system_4161536.bin...OK Writing 32/44 system_4423680.bin...OK Writing 33/44 system_4685824.bin...OK Writing 34/44 system_4947968.bin...OK Writing 35/44 system_5210112.bin...OK Writing 36/44 system_5472256.bin...OK Writing 37/44 system_5734400.bin...OK Writing 38/44 system_5996544.bin...OK Writing 39/44 system_6258688.bin...OK Writing 40/44 system_6520832.bin...OK Writing 41/44 system_6523896.bin...OK Writing 42/44 cust_8388608.bin...OK Writing 43/44 cust_8650752.bin...OK Writing 44/44 BackupGPT_30776320.bin...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.9.5 Software version. problem solved thanks |
