07-26-2017, 12:59 | #1 (permalink) |
No Life Poster Join Date: Dec 2016 Location: Pakistan Age: 27
Member: 2665080 Status: Offline Thanks Meter: 63 | Lg D850 Flashing Failed -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM165 Selected model: D850 Reading info... Model ID: Unknown IMEI: 354608-06-196411-2 Android version: 4.4.2 Battery level: 60% SW Version: LGD855-V10m-ISR Mode: Emergency Initializing flash...OK SW version: LGD855AT-00-V10m-GLOBAL-COM-OCT-22-2014-32G+0 Android version: 4.4.2 LAF Version: 1.0 Product ID: BS03S150206002740 IMEI: 354153-06-302370-8 Target operator: GLOBAL Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "lgd850at-01-v10f-310-410-oct-15-2014+0.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing dbi...OK Writing aboot...OK Writing rpm...OK Writing tz...OK Writing boot...OK Writing persist...OK Writing recovery...OK Writing laf...OK Writing factory...OK Writing system...Failed! LAF Error: 80000017. Performed by 2.7.0 Software version. |
07-26-2017, 13:41 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. What phone model exactly do You have D855 or D850? Please check phone's model on PCB, after use correct firmware file and try to re-flash your device. Also, please don't downgrade phone's firmware, this can damage the device. Last edited by Octopus box; 07-26-2017 at 14:17. |
08-21-2017, 10:07 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please, download and install the latest Software version then repeat Write Firmware operation again. |
