09-22-2016, 06:57 | #1 (permalink) |
Freak Poster Join Date: May 2013
Member: 1929380 Status: Offline Sonork: john-ammu Thanks Meter: 6 | LG D850 Kill Switch phone doesn't boot on download mode short wire also removed used SmartBootDiag with all variants unplug / replug only qualcomm hs-usb |
09-22-2016, 07:05 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Have You You performed "Deactivate Kill Switch" operation? Was the operation successful? Please post here full Software log with all operation, which You performed with the phone. |
09-22-2016, 07:31 | #3 (permalink) |
Member: 1929380 Status: Offline Sonork: john-ammu Thanks Meter: 6 | Log file "C:\Program Files\Octoplus\Octoplus_LG\LOG\22-09-2016_08-31-51.log" created. 9/22/2016 8:31:56 AM > Welcome to Octoplus/Octopus Box LG Software version 2.2.8 9/22/2016 8:32:07 AM > -------------------------------------------------------------------------------- 9/22/2016 8:32:07 AM > Checking data...9/22/2016 8:32:07 AM > OK 9/22/2016 8:32:07 AM > Platform: LG Qualcomm 9/22/2016 8:32:07 AM > Selected port: COM85 9/22/2016 8:32:07 AM > Selected model: D850 9/22/2016 8:32:07 AM > To deactivate Kill Switch do the next: 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS-USB QDLoader 9008". 3. Release testpoint. 9/22/2016 8:32:09 AM > OK 9/22/2016 8:32:09 AM > Sending loader...9/22/2016 8:32:13 AM > OK 9/22/2016 8:32:13 AM > Connecting to server ...9/22/2016 8:32:16 AM > OK 9/22/2016 8:32:17 AM > Initializing device...9/22/2016 8:32:19 AM > OK 9/22/2016 8:32:19 AM > Deactivating Kill Switch...9/22/2016 8:32:19 AM > OK 9/22/2016 8:32:19 AM > Please, reconnect the battery, put the phone in download mode manually and re-flash the phone. 9/22/2016 8:32:19 AM > Performed by 2.2.8 software version. |
09-22-2016, 08:07 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | If device is always detects as "qualcomm hs-usb", this means that TP is still circuited or phone's boots are damaged, or device has HW issue. "Reset Kill Switch" operation doesn't work with phone's boots, so they can't be damaged after this operation. Please disassemble the phone and check carefully again, maybe TP is still circuited or, maybe, You have circuited something on phone's PCB when soldered TP. Last edited by Octopus box; 09-22-2016 at 08:59. |
09-22-2016, 08:42 | #7 (permalink) |
Member: 1929380 Status: Offline Sonork: john-ammu Thanks Meter: 6 | Log file "C:\Program Files\Octoplus\Octoplus_LG\LOG\22-09-2016_11-28-09.log" created. 9/22/2016 11:28:13 AM > Welcome to Octoplus/Octopus Box LG Software version 2.2.8 9/22/2016 11:28:34 AM > -------------------------------------------------------------------------------- 9/22/2016 11:28:34 AM > Checking data...9/22/2016 11:28:35 AM > OK 9/22/2016 11:28:35 AM > Platform: LG Qualcomm 9/22/2016 11:28:35 AM > Selected port: COM3 9/22/2016 11:28:35 AM > Selected model: D850 9/22/2016 11:28:35 AM > To deactivate Kill Switch do the next: 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS-USB QDLoader 9008". 3. Release testpoint. 9/22/2016 11:28:36 AM > OK 9/22/2016 11:28:36 AM > Sending loader...9/22/2016 11:28:41 AM > OK 9/22/2016 11:28:41 AM > Connecting to server ...9/22/2016 11:28:44 AM > OK 9/22/2016 11:28:45 AM > Initializing device...9/22/2016 11:28:47 AM > OK 9/22/2016 11:28:47 AM > Deactivating Kill Switch...9/22/2016 11:28:47 AM > Failed! 9/22/2016 11:28:47 AM > Performed by 2.2.8 software version. 9/22/2016 11:31:52 AM > -------------------------------------------------------------------------------- 9/22/2016 11:31:52 AM > Checking data...9/22/2016 11:31:53 AM > OK 9/22/2016 11:31:53 AM > Platform: LG Qualcomm 9/22/2016 11:31:53 AM > Selected port: COM3 9/22/2016 11:31:53 AM > Selected model: D850 9/22/2016 11:31:53 AM > To deactivate Kill Switch do the next: 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS-USB QDLoader 9008". 3. Release testpoint. 9/22/2016 11:32:33 AM > OK 9/22/2016 11:32:33 AM > Sending loader...9/22/2016 11:32:37 AM > OK 9/22/2016 11:32:37 AM > Connecting to server ...9/22/2016 11:32:40 AM > OK 9/22/2016 11:32:41 AM > Initializing device...9/22/2016 11:32:43 AM > OK 9/22/2016 11:32:43 AM > Deactivating Kill Switch...9/22/2016 11:32:43 AM > Failed! 9/22/2016 11:32:43 AM > Performed by 2.2.8 software version. |
09-22-2016, 09:00 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | @john-ammu Please disassemble the phone and check carefully again, maybe TP is still circuited or, maybe, You have circuited something on phone's PCB when soldered TP. Also, please use the latest Software version |
09-22-2016, 09:51 | #10 (permalink) |
Member: 1929380 Status: Offline Sonork: john-ammu Thanks Meter: 6 | in these pictures you can see that there is no wire even both camera's lcd touch connectors are disconnected and second thing second test point of emmc is print little bit erased by rubbing |
