01-14-2015, 19:45 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: EVERYWHERE U GO Age: 46
Member: 106026 Status: Offline Sonork: 100.77890 Thanks Meter: 127 | Lg d851 unlock problem [Solved] Last edited by Octopus box; 01-15-2015 at 17:18. |
01-14-2015, 19:54 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please install required drivers ("LG United Mobile Driver v 3.8.1" and "LG Android ADB Driver"), reboot the PC and do the next: Go to "Settings -> PC connection -> USB connection type -> Select USB Connection method" and select "LG Software" ("PC Software"). Note: You need to use LG P999 cable with 910 kOhm resistor inside (not standard Micro USB cable) and connect the phone directly to PC motherboard USB port. Also, it is recommended to use desktop PC. Not all laptops providing enough power for USB ports. |
01-14-2015, 20:01 | #4 (permalink) |
Member: 106026 Status: Offline Sonork: 100.77890 Thanks Meter: 127 | Welcome to Octoplus/Octopus Box LG Software version 1.8.1 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM8 Selected model: D851 Reading info...Failed! Port busy -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM8 Selected model: D851 Reading info...Failed! Port busy -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM24 Selected model: D851 Reading info...Failed! Could not detect mode! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM9 Selected model: D851 Reading info...Failed! Port busy |
01-14-2015, 20:04 | #5 (permalink) |
Member: 106026 Status: Offline Sonork: 100.77890 Thanks Meter: 127 | @octopus products support i will try all ur suggestion n come back with results maybe i will need cable with resistor ..thx 4 ur quich responce |
01-14-2015, 20:32 | #6 (permalink) |
Member: 106026 Status: Offline Sonork: 100.77890 Thanks Meter: 127 | @pls I don't see PC connection on dis Lg I hav been search maybe I worng here aswell driver installed sucessful , pc conection ,connection type .ethod n Lg sw pls where to get dis in dis phone sir? |
01-14-2015, 20:50 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | If You don't have this menu, connect the phone directly to PC and do the next: Go to "Settings -> Networks -> Tethering & Networks -> Turn on "USB tethering"; |
01-15-2015, 10:20 | #8 (permalink) |
Member: 106026 Status: Offline Sonork: 100.77890 Thanks Meter: 127 | Platform: LG Qualcomm Selected port: COM17 Selected model: D851 Reading info...OK Mode: Normal Model ID: D85110m Firmware compiled date: Jun 18 2014 Firmware compiled time: 02:00:00 Firmware released date: Aug 22 2014 Firmware released time: 10:54:11 SW Version: MPSS.DI.2.0.1.c1.13-00018-M8974AAAAANPZM-1 IMEI: 014088-00-172941-6 SPC: 000000 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM17 Selected model: D851 Reading info...OK Mode: Normal Model ID: D85110m Firmware compiled date: Jun 18 2014 Firmware compiled time: 02:00:00 Firmware released date: Aug 22 2014 Firmware released time: 10:54:11 SW Version: MPSS.DI.2.0.1.c1.13-00018-M8974AAAAANPZM-1 IMEI: 014088-00-172941-6 SPC: 000000 Unlocking... Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "D851_014088001729416_15-01-2015_09-56-39.qcn" Switching to Download mode...Failed! Please perform the following steps: 1. Disconnect cable 2. Put phone into download mode manually (Power phone OFF and press and hold "Vol+" button) 3. Connect cable and press "Ok" button.Failed! |
01-15-2015, 10:23 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. What cable do You use exactly? You need to use the special LG P999 cable with 910 kOhm resistor inside, not standart Micro USB cabel. Please read Software manual ("Cable & Options" button in the Software). |
01-15-2015, 10:47 | #10 (permalink) |
Member: 106026 Status: Offline Sonork: 100.77890 Thanks Meter: 127 | I use Standard usb cable ! I hav been lookin for dis cable here in Nigeria But can't get anyone ! Any way to configured it sir ? Pls n thx for ur urgents useful responce ! Best regards |
01-15-2015, 10:49 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | You can create this cable easyly, just solder 910 kOhm resistor into your standart Micro USB cable accordingly to the cable's pinout picture in the Software manual. |
01-15-2015, 17:12 | #12 (permalink) |
Member: 106026 Status: Offline Sonork: 100.77890 Thanks Meter: 127 | Thx so much ! I sucessful unlock it thx once again Ure a real supporter .More power to U octopus! I wil post result ! |
The Following User Says Thank You to damabib For This Useful Post: |
