08-22-2015, 04:47 | #1 (permalink) |
Freak Poster Join Date: Jan 2008 Location: egypt
Member: 667857 Status: Offline Thanks Meter: 34 | Lg d885 no sim after unlock Platform: LG Qualcomm Selected port: COM13 Selected model: D855 Reading info... Model ID: LG-D855 IMEI: 354153-06-854737-0 Android version: 5.0 Battery level: 49% Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model D855 at port COM13 Unlocking... Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "D855_354153068547370_22-08-2015_04-58-24.qcn" Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D855_354153068547370_22-08-2015_05-03-44.SEC" Writing security area...OK Switching to Normal mode... Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Failed! Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Press "Ok" button Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model D855 at port COM13 Send SPC...OK Writing QCN... Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing QCN done! Phone successfully unlocked! I WANT QCN FOR D885 |
08-22-2015, 11:26 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Please repeat "Unlock" operation with enabled "Skip Read/Write QCN during Unlock operation" option. Post here result and full Software log of the operation. |
08-23-2015, 09:32 | #3 (permalink) |
Member: 667857 Status: Offline Thanks Meter: 34 | Checking data...OK Platform: LG Qualcomm Selected port: COM13 Selected model: D855 Reading info... Model ID: LG-D855 IMEI: 354153-06-854737-0 Android version: 5.0 Battery level: 38% Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Diagnostics ports are enbled! Switching to Serial Port... Failed! Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Initializing ADB...OK Waiting for phone...OK Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model D855 at port COM13 Unlocking... Skip Read/Write QCN Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D855_354153068547370_22-08-2015_18-48-10.SEC" Writing security area...OK Switching to Normal mode... now imei is 0 |
08-24-2015, 13:21 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Please do the next: 1. Fully charge phone's battery. 2. Write "D855_354153068547370_22-08-2015_18-48-10.SEC" Security backup back into the phone. 3. Manually put the phone into Download/Emergency Mode (to enter emergency mode, power phone OFF, press and hold "Vol+" button and connect USB cable) 4. Repeat "Unlock" operation. Note: You should use P999 cable (with 910kOm resistor) for connection. |
