04-05-2014, 11:47 | #1 (permalink) |
Freak Poster Join Date: Feb 2008 Location: sri lanka Age: 44
Member: 700923 Status: Offline Thanks Meter: 13 | lg E400r not unlock Platform: LG Qualcomm Selected port: COM6 Selected model: E400r Reading info...OK Mode: Emergency Model ID: BS/E400R/7D Unlocking... To avoid damaging your phone, please, follow these simple precautions: Use a clean PC (without any installed drivers and software for BlackBerry phones, modem Dashboard software, Phone PC suites software). Please, make sure the phone's battery is fully charged. You should not run any other programs or attach new devices to your computer during this operation! Canceled! |
04-05-2014, 12:42 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. If You want to make Unlock - You need to do everything from following warning: Quote:
04-05-2014, 12:59 | #3 (permalink) | |
Member: 700923 Status: Offline Thanks Meter: 13 | Quote:
i flached phone but phone is not blinking i trito unlock but same Platform: LG Qualcomm Selected port: COM6 Selected model: E400r Reading info...OK Mode: Emergency Model ID: BS/E400R/7D Unlocking... To avoid damaging your phone, please, follow these simple precautions: Use a clean PC (without any installed drivers and software for BlackBerry phones, modem Dashboard software, Phone PC suites software). Please, make sure the phone's battery is fully charged. You should not run any other programs or attach new devices to your computer during this operation! Sending loader... Warning! BCPE check not passed! Failed! Last edited by w850; 04-05-2014 at 13:06. | |
04-05-2014, 14:30 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Do the next: 1. Reconnect the battery, put the phone into Emergency Mode manually and make "Repair Security". 2. Reconnect the battery, put the phone into Emergency Mode manually and make "Repair IMEI". 3. Reconnect the battery, put the phone into Emergency Mode manually and re-flash the phone with phone's boot loaders (with selected "Write boot loaders" option in Software) with the firmware "DZ_LGE400AT-00-V10m-EUR-XXX-SEP-17-2012+0.oct". 4. Connect the device in Normal Mode and make "Repair NVM". 5. Post here full Software log with all of these actions. To put the phone into Emergency Mode manually, disconnect the cable, reconnect the battery, press and hold "Vol-" + "Vol+" + "Power ON" buttons and connect the cable. Also, please look here: http://forum.gsmhosting.com/vbb/f799.../#post10209696. |
