03-03-2015, 12:58 | #1 (permalink) |
Crazy Poster Join Date: Jun 2004 Age: 44
Member: 68763 Status: Offline Thanks Meter: 1 | lg e460 flash error Checking data...OK Platform: LG MTK Selected port: COM16 Selected baudrate: 460800 Selected model: E460 Selected USB connection type Please, disconnect battery and connect cable...OK Phone found. CPU name: MT6575 CPU revision: 8A00.CB00.E201.0000 Setting power state...OK Prepairing loader...OK Sending loader...OK Synchronizing with loader... Loader version: 3.2.132 Detecting flash chip...OK Detecting EMMC flash chip...OK Reading info...OK Opening "LGE460AT-00-V10p-EUR-XX-JAN-07-2014+0.oct"... Writing Firmware... Formating filesystem...OK Unlocking Bootloader...OK Writing FILE_INFO...OK Writing MBR...Failed! Error code: QAZ6CQAWB5 please solution, cable 910k resistor |
03-03-2015, 15:22 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Hello. We have prepared and sent You test Software version to PM. Try to write firmware by using this Software and post here the result. |
03-03-2015, 15:55 | #3 (permalink) | |
Member: 68763 Status: Offline Thanks Meter: 1 | Quote:
Welcome to Octoplus/Octopus Box LG Software version 1.8.6.3 -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM16 Selected baudrate: 460800 Selected model: E460 Selected USB connection type Please, disconnect battery and connect cable...OK Phone found. CPU name: MT6575 CPU revision: 8A00.CB00.E201.0000 Setting power state...OK Prepairing loader...OK Sending loader...OK Synchronizing with loader... Loader version: 3.2.132 Detecting flash chip...OK Detecting EMMC flash chip...OK Reading info...OK Opening "LGE460AT-00-V10p-EUR-XX-JAN-07-2014+0.oct"... Writing Firmware... Formating filesystem...OK Unlocking Bootloader...OK Writing FILE_INFO...OK Writing MBR...Failed! Error code: QAZ6CQAWB5 | |
03-03-2015, 16:19 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | What is the state of your phone exactly? What is the problem with it? Why do You want to write firmware? |
03-03-2015, 17:45 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | We have prepared and sent You to PM new test Software version. Try to write firmware by using this Software and post here the result. Also, we have uploaded new firmware into the Support Area, try to write another firmware also. If the problem is still the same, most likely, your device has HW issues. |
03-27-2015, 18:06 | #7 (permalink) |
No Life Poster Join Date: Jul 2010 Location: North Africa
Member: 1350724 Status: Offline Thanks Meter: 188 | hi i have the same problem Selected model: E460 Selected USB connection type Please, disconnect battery and connect cable...OK Phone found. CPU name: MT6575 CPU revision: 8A00.CB00.E201.0000 Setting power state...OK Prepairing loader...OK Sending loader...OK Synchronizing with loader... Loader version: 3.2.132 Detecting flash chip...OK Detecting EMMC flash chip...OK Reading info...OK Opening "e460 V10N_00.oct"... Writing Firmware... Formating filesystem...OK Unlocking Bootloader...OK Writing FILE_INFO...OK Writing MBR...Failed! Error code: QAZ6CQAWB5 if this is hardware problem what can we repair?? thanks |
03-27-2015, 19:27 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Try to write different firmwares from the Support Area with latest Software version (Software). If the problem will remain the the same, most likely, your device has HW issues. |
03-17-2016, 21:08 | #9 (permalink) |
Insane Poster Join Date: Jan 2005 Age: 48
Member: 106154 Status: Offline Thanks Meter: 7 | i have the same problem Добро пожаловать в Octoplus/Octopus Box LG Software version 2.2.2 -------------------------------------------------------------------------------- Checking data...OK Платформа: LG MTK Выбранный порт: COM3 Выбранная скорость: 921600 Выбранная модель: E460 Selected USB connection type Please, disconnect battery and connect cable...OK Телефон найден. CPU name: MT6575 CPU revision: 8A00.CB00.E201.0000 Setting power state...OK Подготовка загрузчика...OK Отправка загрузчика... Performed by 2.2.2 software version. -------------------------------------------------------------------------------- Checking data...OK Платформа: LG MTK Выбранный порт: COM3 Выбранная скорость: 921600 Выбранная модель: E460 Selected USB connection type Please, disconnect battery and connect cable...OK Телефон найден. CPU name: MT6575 CPU revision: 8A00.CB00.E201.0000 Setting power state...OK Подготовка загрузчика...OK Отправка загрузчика...OK Synchronizing with loader... Loader version: 3.2.132 Detecting flash chip...OK Detecting EMMC flash chip...OK Чтение информации...OK Открытие "LGE460AT-00-V10p-EUR-XX-JAN-07-2014+0.oct"... Writing Firmware... Formating filesystem...OK Unlocking Bootloader...OK Запись FILE_INFO...OK Запись MBR...Ошибка! Error code: QAZ6CQAWB5 Performed by 2.2.2 software version. -------------------------------------------------------------------------------- Checking data...OK Платформа: LG MTK Выбранный порт: COM3 Выбранная скорость: 921600 Выбранная модель: E460 Selected USB connection type Please, disconnect battery and connect cable...OK Телефон найден. CPU name: MT6575 CPU revision: 8A00.CB00.E201.0000 Setting power state...OK Подготовка загрузчика...OK Отправка загрузчика...OK Synchronizing with loader... Loader version: 3.2.132 Detecting flash chip...OK Detecting EMMC flash chip...OK Чтение информации...OK Открытие "LGE460AT-00-V10p-EUR-XX-JAN-07-2014+0.oct"... Writing Firmware... Formating filesystem...OK Unlocking Bootloader...OK Запись FILE_INFO...OK Запись MBR...Ошибка! Error code: QAZ6CQAWB5 Performed by 2.2.2 software version. Connecting to server support.octoplusbox.com:82...OK Authorizing...OK -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM3 Selected baudrate: 921600 Selected model: E460 Selected USB connection type Please, disconnect battery and connect cable...OK Phone found. CPU name: MT6575 CPU revision: 8A00.CB00.E201.0000 Setting power state...OK Prepairing loader...OK Sending loader...OK Synchronizing with loader... Loader version: 3.2.132 Detecting flash chip...OK Detecting EMMC flash chip...OK Reading info...OK Opening "LGE460AT-00-V10p-EUR-XX-JAN-07-2014+0.oct"... Writing Firmware... Formating filesystem...OK Unlocking Bootloader...OK Writing FILE_INFO...OK Writing MBR...Failed! Error code: QAZ6CQAWB5 Performed by 2.2.2 software version. |
03-18-2016, 09:52 | #10 (permalink) |
