10-09-2013, 19:07 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: CIEGO DE AVILA ,CUBA
Member: 1176958 Status: Offline Thanks Meter: 158 | lg E400R cant unlock security error [Solved] *******r bring me phone for unlock and change language but my mistake that now( i know is was my mistake )was that i first flashed instead to direct unlock first then flash ...so i first flashe LGE400fAT-00-V10a-724-31-MAR-22-2012+2 and i tick botton write boot loader and phone hangin onl logo restar blinking then i flashe back original flashed LGE400RAT-00-v11e-SSV-RGS-AUG-09-2012+0.oct then phone get back to life SO when i try to unlock again it said Sending loader... Warning! BCPE check not passed! and phone star blinking again ...at this point i find up some strange cause another custumer bring me another phone similar form rogers canada so what i did was direct unlock first the phone goes blinking then u put in emegercy mode manually and i flashed with LGE400fAT-00-V10a-724-31-MAR-22-2012+2 that has spanish language and phone star successfully then i direct unlock and phone was ok but becase i flashed first i guess that i mess up any way i only can get back life this phone with rogers firmware so i try to unlock via code and it said phone is not personalized it so i canot put unlock code and when i put a sim card said security error i every time i try reapair security and imei phone go blibking again does anyone have any idea and help me please -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM36 Selected model: E400f Reading info...OK Mode: Normal Model ID: E400R Firmware compiled date: Apr 02 2012 Firmware compiled time: 06:00:00 Firmware released date: Aug 9 2012 Firmware released time: 14:12:00 SW Version: E0_CA-M7225A-V11e-AUG-09-2012-XX IMEI: 013305-00-041623-8 Bluetooth address: F0:1C:13:1E:98:F7 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM36 Selected model: E400r Reading info...OK Mode: Normal Model ID: E400R Firmware compiled date: Apr 02 2012 Firmware compiled time: 06:00:00 Firmware released date: Aug 9 2012 Firmware released time: 14:12:00 SW Version: E0_CA-M7225A-V11e-AUG-09-2012-XX IMEI: 013305-00-041623-8 Bluetooth address: F0:1C:13:1E:98:F7 Switching to Download mode...OK To avoid damaging your phone, please, follow these simple precautions: Use a clean PC (without any installed drivers and software for BlackBerry phones, modem Dashboard software, Phone PC suites software). Please, make sure the phone's battery is fully charged. You should not run any other programs or attach new devices to your computer during this operation! Sending loader... Warning! BCPE check not passed! Searching security area...OK Reading security area...OK Backup saved to "E400R_09-10-2013_12-50-39.SEC" Analyzing security... Writing security area...OK Switching to Normal mode...Failed! Last edited by Octopus box; 10-14-2013 at 06:17. |
10-10-2013, 06:54 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please do the next: 1. Put the phone into Emergency Mode manually and re-flash the phone with firmware for LG E400 ("LGE400AT-00-V10m-EUR-XXX-SEP-17-2012+0") with phone's boot loaders. 2. Put the phone into Emergency Mode manually and make Repair Security. 3. Put the phone into Emergency Mode manually and make Repair IMEI. 4. Put the phone into Emergency Mode manually and make Unlock. 5. Make Repair NVM. 6. Post here the result. Note, if an error occurs during of doing of any of these operations mentioned above (1-4), You need to disconnect phone's battery (this is important!), put the phone into Emergency Mode manually again and then repeat the operation. Also, to avoid damaging your phone, please, follow these simple precautions: Use a clean PC (without any installed drivers and software for BlackBerry phones, modem Dashboard software, Phone PC suites software). Please, make sure the phone's battery is fully charged. You should not run any other programs or attach new devices to your computer during this operation! P.S. Please install and use the latest Software version (http://octopusbox.com/files/softs/in...s_LG_1.3.1.exe). |
10-12-2013, 18:23 | #4 (permalink) |
Member: 1176958 Status: Offline Thanks Meter: 158 | still not success ok i did everything u said but not luck but i notice some thing when i finished flash the mobile star ok with imei ok but afther i repair security phone star blinking again then when i try to put in emergency mode it dosent go only go in (octopus mode) I guess is the same???..any way afher repair security it look like the phone imei change because when i did reapair imei in the log u can see that imei star...change any way imei is repair ok but phone still blinking then i pu in (octopus mode ) manually again and did unlock but phone dosent star properly again and finally put manually again and i try to repair NVM but it open an explorer and ask me for a file which i dont have ..and phone still blibink i think problem the phone is afther reapir security and unlock it dosent star properly ani other idea ???? thanks in advance i already paid the phone to the custumer so please help me to fis this phone here is the log . -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM12 Selected model: E400 Reading info...OK Mode: Emergency Model ID: BS/E400f/7D Opening "DZ_LGE400AT-00-V10m-EUR-XXX-SEP-17-2012+0.oct"...OK Checking partition...OK Write BootLoaders: Yes Checking BCPL status...OK BCPL status: 1 Unlocking BCPL...OK BCPE status: 1 Checking BCPL status...OK BCPL status: 0 Writing QCSBL_CFG...OK Writing QCSBL...OK Writing OEMSBL...OK Writing AMSS...OK Writing EMMCBOOT...OK Writing Boot Image...OK Writing Recovery Image...OK Writing Persist...OK Writing System...OK Finalizing...OK Writing firmware done! To finish the operation please power on phone and wait 3 minutes -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM12 Selected model: E400 Reading info...OK Mode: Normal Model ID: E400 Firmware compiled date: Nov 17 2011 Firmware compiled time: 22:00:00 Firmware released date: Sep 17 2012 Firmware released time: 17:08:29 SW Version: E0_EU-M7225A-V10m-SEP-17-2012-XX IMEI: 013305-00-041623-8 Bluetooth address: F0:1C:13:1E:98:F7 Wi-Fi MAC address: A8:16:B2:F1:4E:93 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM12 Selected model: E400 Reading info...OK Mode: Emergency Model ID: BS/E400/7D -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM12 Selected model: E400 Reading info...OK Mode: Emergency Model ID: BS/E400/7D To avoid damaging your phone, please, follow these simple precautions: Use a clean PC (without any installed drivers and software for BlackBerry phones, modem Dashboard software, Phone PC suites software). Please, make sure the phone's battery is fully charged. You should not run any other programs or attach new devices to your computer during this operation! Sending loader... Warning! BCPE check not passed! Searching security area...OK Reading security area...OK Backup saved to "E400_12-10-2013_13-09-35.SEC" Analyzing security... Writing security area...OK Switching to Normal mode...OK Found model E400 at port COM12 Finalizing...OK Rebooting phone...OK Security succesfully repaired. Rebooting phone... -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM12 Selected model: E400 Reading info...OK Mode: Emergency Model ID: BS/E400/7D Fixing IMEI... New IMEI: 013305-00-041623-8 Searching security area...OK Reading security area...OK Backup saved to "E400_12-10-2013_13-13-16.SEC" Analyzing security...OK IMEI: 358103-04-048885-0 Bluetooth address: F0:1C:13:1E:98:F7 New IMEI: 013305-00-041623-8 Writing security area...OK Switching to Normal mode...OK Found model E400 at port COM12 Finalizing...OK Rebooting phone...OK IMEI successfully fixed! Rebooting phone... -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM12 Selected model: E400 Reading info...OK Mode: Emergency Model ID: BS/E400/7D Unlocking... Searching security area...OK Reading security area...OK Backup saved to "E400_12-10-2013_13-16-28.SEC" Analyzing security...OK IMEI: 013305-00-041623-8 Bluetooth address: F0:1C:13:1E:98:F7 Writing security area...OK Switching to Normal mode...OK Found model E400 at port COM12 Finalizing... Rebooting phone...OK Phone successfully unlocked! Rebooting phone... -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM12 Selected model: E400 Reading info...OK Mode: Emergency Model ID: BS/E400/7D Selecting output file...Canceled! |
10-13-2013, 10:16 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | After You have successfully performed Unlock and Repair IMEI operations, please re-flash the phone again with phone's boot loaders. After the phone will be powered, please make Repair NVM from Normal Mode connection. |
10-13-2013, 19:59 | #6 (permalink) |
Member: 1176958 Status: Offline Thanks Meter: 158 | WELL DONE thanks octopus team for ur help afther i flash again and then repair NVM phone was succesfull unlock is all done now thanks octopus team here is the log Welcome to Octoplus/Octopus Box LG Software version 1.3.2 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM36 Selected model: E400 Reading info...OK Mode: Normal Model ID: E400 Firmware compiled date: Nov 17 2011 Firmware compiled time: 22:00:00 Firmware released date: Sep 17 2012 Firmware released time: 17:08:29 SW Version: E0_EU-M7225A-V10m-SEP-17-2012-XX IMEI: 013305-00-041623-8 Bluetooth address: F0:1C:13:1E:98:F7 Wi-Fi MAC address: A8:16:B2:F1:4E:93 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM36 Selected model: E400 Reading info...OK Mode: Normal Model ID: E400 Firmware compiled date: Nov 17 2011 Firmware compiled time: 22:00:00 Firmware released date: Sep 17 2012 Firmware released time: 17:08:29 SW Version: E0_EU-M7225A-V10m-SEP-17-2012-XX IMEI: 013305-00-041623-8 Bluetooth address: F0:1C:13:1E:98:F7 Wi-Fi MAC address: A8:16:B2:F1:4E:93 Checking data...OK Repairing NVM...OK NVM succesfully repaired. Rebooting phone... |
