05-13-2015, 05:18 | #1 (permalink) |
Junior Member Join Date: Jan 2015
Member: 2323893 Status: Offline Thanks Meter: 0 | LG-E960 Pattern unlock |
05-13-2015, 09:09 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Unfortunately, "Reset Screen Lock" operation requires "USB Debugging" option to be enabled. If option is not enabled, You can remove Pattern Lock via Hard Reset: 1. Turn OFF the phone. 2. Press and hold "Vol-" + "Power" buttons. 3. In recovery menu press Volume down twice. 4. Press power. You will see a red exclamation mark. 5. Press power + Volume UP. 6. Use the Volume keys to scroll to Wipe Data/Factory Reset and press Power to select it. |
05-14-2015, 08:57 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please check your PM, we have sent You test Software version. Put the phone into Emergency Mode manually and try to perform "Reset Screen Lock" operation. Post here results and full Software log of the operation. |
05-18-2015, 13:36 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | To witch E960 phone into Emergency mode, disconnect cable, power OFF phone, press and hold "Vol-" + "Vol+" buttons and connect cable. |
05-19-2015, 04:58 | #8 (permalink) |
Member: 2323893 Status: Offline Thanks Meter: 0 | Platform: LG Qualcomm Selected port: COM46 Selected model: E960 Searching Diagnostic Ports...OK Reading info... Model ID: Incompatible model ID! Please, select correct model!Failed! Could not detect mode! |
05-19-2015, 10:57 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please check your PM, we've sent You test Software version. Try to perform "Reset Screen Lock" operation with test Software and post here results. |
05-21-2015, 06:36 | #11 (permalink) |
Member: 2323893 Status: Offline Thanks Meter: 0 | I'd done it. Unfortunately my phone is turning off after Google logo now. I dont know why. Most probably system issue, because of it's working in recovery mode. Platform: LG Qualcomm Selected port: COM43 Selected model: E960 Searching Diagnostic Ports...OK Reading info... Model ID: IMEI: Android version: Battery level: 0% Mode: Emergency Model ID: BS/J1A/1 (LG-E960) SW version: LGE960AT-00-V10c-NXS-XX-NOV-13-2012-JOP40C-USER+0 Product ID: SM02S130205000448 IMEI: This process can take about 15 minutes. Please, wait... Initializing flash...OK Reading partition...OK Resetting Screen Lock... Resetting screen lock successfully completed! |
05-22-2015, 16:18 | #13 (permalink) |
Freak Poster Join Date: Dec 2007 Location: Philippines
Member: 643566 Status: Offline Thanks Meter: 31 | can u enter in fastboot mode... connect to pc install driver cmd type fastboot oem unlock ...it sxhould erasing..after done do to relock bootloader ...hope u can.. |
