04-06-2014, 17:05 | #1 (permalink) |
Freak Poster Join Date: Apr 2007 Location: EDMONTON, CA / PH
Member: 489518 Status: Offline Thanks Meter: 47 | LG e960 it won't Flash I have e960 phone here which is stuck in logo Google display customer trying to update but its getting error I try to flash 2 different firmware download from support but I got this error can you please guide me how to manage to fix this software.. Thanks.. Platform: LG Qualcomm Selected port: COM11 Selected model: E960 Searching Diagnostic Ports...OK Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Incompatible model ID! Please, select correct model! |
04-06-2014, 17:16 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to do the next: 1. Remove SD and SIM cards from the phone. 2. Put the phone into Emergency Mode manually (disconnect the cable, power phone off, press and hold "Vol-" + "Vol+" keys and connect the cable). 3. Select firmware file. 4. Click "Write Firmware" button. 5. Follow software instructions (promts). |
04-06-2014, 17:49 | #3 (permalink) |
Member: 489518 Status: Offline Thanks Meter: 47 | Thanks for reply, phone no memory card no sim card here is another log from different computer Platform: LG Qualcomm Selected port: COM11 Selected model: E960 Searching Diagnostic Ports...OK Reading info...OK Mode: Fastboot Model ID: mako 16GB Device serial number: 00a454fd624f2605 Hardware: rev_11 Bootloader lock state: unlocked Switching to Normal mode... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. how can i switch to enable usb debugging because phone stuck in in Google logo |
04-07-2014, 06:13 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Quote:
Should be like here: http://forum.gsmhosting.com/vbb/10161207-post2610.html. | |
06-15-2016, 12:04 | #5 (permalink) | |
Freak Poster Join Date: Jun 2008 Location: mumbai Age: 31
Member: 787164 Status: Offline Thanks Meter: 24 | workig octopus team download method thanq octoplus team Quote:
