11-26-2017, 00:25 | #2 (permalink) |
No Life Poster Join Date: May 2006 Location: pakistan
Member: 270869 Status: Offline Sonork: 100.1600061 Thanks Meter: 429 | Here is factory reset log......... Checking data...OK Platform: LG Qualcomm Selected port: COM114 Selected model: F160LV Reading info... Model ID: LGF160LV-00-V20d-LGU-KR-JUN-01-20130 IMEI: Android version: Battery level: 0% SW Version: 0-V20d-LGU-KR-JUN-01-2013+0 Mode: Normal Factory reset... Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Formating userdata...OK Formating cache...OK Finalizing...OK Factory reset done! Performed by 2.7.7 Software version. |
11-26-2017, 23:33 | #3 (permalink) |
Member: 270869 Status: Offline Sonork: 100.1600061 Thanks Meter: 429 | and then flash with octopus flashing error log here Welcome to Octoplus/Octopus Box LG Software version 2.7.7 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM4 Selected model: F160LV Reading info...Failed! Port busy Performed by 2.7.7 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM117 Selected model: F160LV Reading info... Model ID: LGF160LV-00-V20d-LGU-KR-JUN-01-20130 IMEI: Android version: Battery level: 48% SW Version: 0-V20d-LGU-KR-JUN-01-2013+0 Mode: Normal Firmware compiled date: Jun 01 2013 Firmware compiled time: 14:37:20 Firmware released date: Jun 01 2013 Firmware released time: 14:37:20 SW Version: F160LV IMEI: 354249-05-028074-7 SPC: 000000 Opening "LGF160LVAT-00-V20d-LGU-KR-JUN-01-2013+0.oct"...OK Switching to Download mode...OK Initializing flash...OK Testing connection...OK Writing PrimaryGPT...OK Writing modem...Failed! Performed by 2.7.7 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM117 Selected model: F160LV Reading info... Model ID: LGF160LV-00-V10e-LGU-KR-OCT-31-20120 IMEI: Android version: Battery level: 48% SW Version: 0-V10e-LGU-KR-OCT-31-2012+0 Mode: Emergency Model ID: BS/D1LU/1 Incompatible model ID! SW version: LGF160LVAT-00-V20d-LGU-KR-JUN-01-2013+0 Product ID: PT02S120707003529 IMEI: 354249-05-028074-7 Opening "LGF160LVAT-00-V20d-LGU-KR-JUN-01-2013+0.oct"...OK Initializing flash...OK Testing connection...OK Writing PrimaryGPT...OK Writing modem...Failed! Performed by 2.7.7 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM4 Selected model: F160LV Reading info...Failed! Port busy Performed by 2.7.7 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM119 Selected model: F160LV Reading info... Model ID: LGF160LV-00-V10e-LGU-KR-OCT-31-20120 IMEI: Android version: Battery level: 48% SW Version: 0-V10e-LGU-KR-OCT-31-2012+0 Mode: Emergency Model ID: BS/D1LU/1 Incompatible model ID! SW version: LGF160LVAT-00-V20d-LGU-KR-JUN-01-2013+0 Product ID: PT02S120707003529 IMEI: 354249-05-028074-7 Opening "LGF160LVAT-00-V20d-LGU-KR-JUN-01-2013+0.oct"...OK Initializing flash...OK Testing connection...OK Writing PrimaryGPT...OK Writing modem...Failed! Performed by 2.7.7 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM4 Selected model: F160LV Reading info...Failed! Port busy Performed by 2.7.7 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM4 Selected model: F160LV Reading info...Failed! Port busy Performed by 2.7.7 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM4 Selected model: F160LV Reading info...Failed! Port busy Performed by 2.7.7 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM4 Selected model: F160LV Reading info...Failed! Port busy Performed by 2.7.7 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM117 Selected model: F160LV Reading info... Model ID: LGF160LV-00-V20d-LGU-KR-JUN-01-20130 IMEI: Android version: Battery level: 0% SW Version: 0-V20d-LGU-KR-JUN-01-2013+0 Mode: Normal Opening "LGF160LVAT-00-V20d-LGU-KR-JUN-01-2013+0.oct"...OK Switching to Download mode...OK Initializing flash...OK Testing connection...OK Writing PrimaryGPT...OK Writing modem...Failed! Performed by 2.7.7 Software version. |
11-27-2017, 07:52 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Unfortunately, reseting this type of lock is not supported at the moment. Most likely, writing firmware will not help to disable this lock, but You can try. To write firmware, please fully charge phone's battery, connect the phone directly to PC motherboard USB port (don't use USB hubs, this is important) and repeat "Write Firmware" operation. |
11-27-2017, 11:41 | #5 (permalink) | |
Member: 270869 Status: Offline Sonork: 100.1600061 Thanks Meter: 429 | Quote:
11-27-2017, 11:59 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Currently we have no any device with such type of lock for researching. We will try to find/buy one, then research and develop the solution. |
