10-01-2014, 17:38 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: KABUPATEN SLEMAN
Member: 714648 Status: Offline Sonork: 1609640 Thanks Meter: 931 | LG F320L Reset pattern lock not solved [Solved] Platform: LG Qualcomm Selected port: COM70 Selected model: F320L Reading info...OK Mode: Emergency Initializing flash...OK Model ID: LG-F320L SW version: LGF320LAT-00-V11g-LGU-KR-OCT-21-2013+0 LAF Version: 1.0 Product ID: SM05S131118000589 IMEI: 356458-05-369909-6 Target operator: LGU Hardware: rev_10 Battery level: 95% This process can take about 15 minutes. Please, wait... Reading partition...OK Resetting Screen Lock... Resetting screen lock successfully completed! Last edited by Octopus box; 10-02-2014 at 06:29. |
10-01-2014, 18:10 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. In order to perform Reset Screen Lock operation "USB debugging" should be turned in the phone. Please connect the phone to PC and try to make "Reset Screen Lock" again. If "USB debugging" is enabled - Screen Lock will be removed. If it is not enabled - unfortunately, currently no solution. |
10-01-2014, 19:56 | #4 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Uruguay
Member: 1459662 Status: Offline Thanks Meter: 152 | Take your phone and turn it off – just press power button and select “power off”. Wait while your device is shutting down. Then, press volume down button and power button together until the LG logo appears on the screen. When the LG logo is displayed, let go of the power button, keep pressing the volume down key and then press once more the power button. Once you do that, on your LG G2 the factory reset menu will be displayed. Press power button in order to agree and wait while the hard reset is being completed. |
10-02-2014, 03:14 | #5 (permalink) | |
Member: 714648 Status: Offline Sonork: 1609640 Thanks Meter: 931 | Quote:
but my problem have solved - press power and vol up, phone have adb - then root phone with vroot or u can root with octopus follow intruction on octopus ( for octopus root u must follow this step 1.press hold vol up then connect usb phone show on download mode , click root on octopus software, on octopus u can see for following procedure to adb connect, remove battery and unplug usb,then plug battery press power and vol up then connect usb, now phone on adb mode and rooting progress) - after root u must adb format, u can adb format with command promt or u can simple progress with one click adb format with MAAT from miracle. GOOD LUCk | |
