07-21-2014, 12:38 | #17 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Write first ecurity backup back into the phone - this You will restore the phone to its initial condition. And check whether network is full. |
07-23-2014, 17:02 | #19 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | You should write backups only from your device. Backups from other device will not be suitable - they are HW depended. All backups are saved here: "c:\Program Files\Octoplus\Octoplus_LG\BACKUP\". |
08-20-2014, 16:04 | #22 (permalink) |
08-20-2014, 16:10 | #23 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: <<heaven>> Age: 43
Member: 754364 Status: Offline Thanks Meter: 59 | Quote:
Add support for this issue Last edited by ozeltekno; 08-20-2014 at 16:19. | |
08-20-2014, 16:19 | #24 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Software creates backups during Repair IMEI and Unlock operations and store them into "c:\Program Files\Octoplus\Octoplus_LG\BACKUP\" folder. If You have formatted PC, or intentionally deleted files in any other way, without creating copy, then it is no longer possible to restore the phone to its initial state. As I wrote above: "Backups from other device will not be suitable - they are HW depended". |
08-20-2014, 18:41 | #25 (permalink) |
Member: 754364 Status: Offline Thanks Meter: 59 | LG F320S-LG-F240S Octopus Box after repair imei error. You are right, but I corrupted files in the NVM ,I bought this device, I got this way ,Octopus Box with IMEI repair done before and these issues have begun, Tell me now,!(Write your solution options) Octopus Box f320s to repair imei repair F320k nvm is loading files,why is that,? |
08-20-2014, 21:15 | #26 (permalink) |
Member: 754364 Status: Offline Thanks Meter: 59 | LG Service Menu Code: 5457#*320# band selection GSM 1800 band manuel ,NETWORK FULL NO PROBLEMS ! Automatic band problems !!! Welcome to Octoplus/Octopus Box LG Software version 1.6.6 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM43 Selected model: F320K Reading info...OK Mode: Normal Model ID: F320S Firmware compiled date: Jan 03 2014 Firmware compiled time: 14:00:00 Firmware released date: Jan 20 2014 Firmware released time: 13:54:42 SW Version: M8974A-AAAANAZM-1.0.190082 IMEI: 351475-80-411668-8 Fixing IMEI... New IMEI: 355806-00-114382-6 Reading NVM...OK Backup saved to "F320S_351475804116688_20-08-2014_22-26-52.NVM" Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "F320S_351475804116688_20-08-2014_22-30-10.SEC" Writing security area...OK Switching to Normal mode... Found model F320S at port COM43 Checking data...OK Writing NVM...OK NVM succesfully repaired. IMEI successfully fixed! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). |
08-23-2014, 06:00 | #27 (permalink) |
Freak Poster Join Date: May 2008
Member: 775704 Status: Offline Thanks Meter: 14 | I also encountered the same problem.Change IMEI is ok. But Signals sometimes not. Write back backup NVM,SEC ,all is ok . If you want to change imei. You can try to use the QPST( write xxx .qcn) and use the DFS change imei. will all is ok , Good luck! |
