07-04-2014, 18:48 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: <<heaven>> Age: 43
Member: 754364 Status: Offline Thanks Meter: 59 | LG F320S-LG-F240S NVM need imei repair ok Network problem LG F320S full orjinal nvm need LG-F240S full orjinal nvm need (network) search is going to come again when you have made Please update repair!!! |
07-04-2014, 20:09 | #2 (permalink) |
Member: 754364 Status: Offline Thanks Meter: 59 | F320S imei repair Platform: LG Qualcomm Selected port: COM43 Selected model: F320S Reading info...OK Mode: Normal Model ID: F320S Firmware compiled date: Jan 03 2014 Firmware compiled time: 14:00:00 Firmware released date: Jan 20 2014 Firmware released time: 13:54:42 SW Version: M8974A-AAAANAZM-1.0.190082 IMEI: 35xxxxxxxxxxxxxxxx Fixing IMEI... New IMEI: 3530xxxxxxxxxxxx Reading NVM...OK Backup saved to "F320S_35xxxxxxxxxxx_03-07-2014_21-45-38.NVM" Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "F320S_3530xxxxxxxx_03-07-2014_21-49-40.SEC" Writing security area...OK Switching to Normal mode... Found model F320S at port COM43 Checking data...OK Writing NVM...OK NVM succesfully repaired. IMEI successfully fixed! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). F320S UNLOCK Repair Platform: LG Qualcomm Selected port: COM43 Selected model: F320S Reading info...OK Mode: Normal Model ID: F320S Firmware compiled date: Jan 03 2014 Firmware compiled time: 14:00:00 Firmware released date: Jan 20 2014 Firmware released time: 13:54:42 SW Version: M8974A-AAAANAZM-1.0.190082 IMEI: 35xxxxxxxxxxxxx Unlocking... Reading NVM...OK Backup saved to "F320S_35xxxxxxxxxxxxx_03-07-2014_21-58-18.NVM" Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "F320S_3530xxxxxxxxxxx_03-07-2014_22-01-57.SEC" Writing security area...OK Switching to Normal mode... Found model F320S at port COM43 Checking data...OK Writing NVM...OK NVM succesfully repaired. Phone successfully unlocked! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). network that is going to come, when you have made the search comes back after going full TEAM very urgent |
07-04-2014, 20:17 | #3 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Where is the problem exactly? Quote:
Have You done Factory Reset when Repair IMEI and Unlock operations were completed? Last edited by Octopus box; 07-04-2014 at 20:28. | |
07-04-2014, 20:42 | #4 (permalink) | |
Member: 754364 Status: Offline Thanks Meter: 59 | Quote:
yes I have tried many times does not format problem full network but the search does not Try 3g data connection, the full network is going down 2g 3g on both devices, network problems ,etc I think about these problems octopus la engineers can test again please full backup ,Add a solid backup files | |
07-04-2014, 20:53 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Please repair NVM manually, with "Repair NVM" button and check the network. All backups were made during the first operation (Repair IMEI in this case) with the phone. If You will write NVM (F320S_35xxxxxxxxxxx_03-07-2014_21-45-38.NVM) and security (F320S_3530xxxxxxxx_03-07-2014_21-49-40.SEC) backups back into the phone - You will restore the phone to its initial condition. |
07-04-2014, 21:12 | #6 (permalink) |
Member: 754364 Status: Offline Thanks Meter: 59 | replacement NVM manual installation Platform: LG Qualcomm Selected port: COM20 Selected model: F320S Reading info...OK Mode: Normal Model ID: F320S Firmware compiled date: Jan 03 2014 Firmware compiled time: 14:00:00 Firmware released date: Jan 20 2014 Firmware released time: 13:54:42 SW Version: M8974A-AAAANAZM-1.0.190082 IMEI: 3530xxxxxxxxxxxxxx Checking data...OK Writing NVM...OK NVM succesfully repaired. write backup SEC replacement manual installation Platform: LG Qualcomm Selected port: COM20 Selected model: F320S Reading info...OK Mode: Normal Model ID: F320S Firmware compiled date: Jan 03 2014 Firmware compiled time: 14:00:00 Firmware released date: Jan 20 2014 Firmware released time: 13:54:42 SW Version: M8974A-AAAANAZM-1.0.190082 IMEI: 3530XXXXXXXXXXXX Opening "F320S_3530XXXXXXXXX_03-07-2014_21-33-50.SEC"... Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "F320S_3530XXXXXXXXXX_03-07-2014_23-09-14.SEC" Writing security area...OK Switching to Normal mode... Found model F320S at port COM20 |
07-04-2014, 21:20 | #7 (permalink) |
Member: 754364 Status: Offline Thanks Meter: 59 | LG F320S-LG-F240S --Full robust backup files needed me ,You can add ? and, in my country, to use ,I need to change the imei ....really have a problem |
07-05-2014, 10:46 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Do the next: 1. Write the first backups (NVM and Security), which have been created by the Software before You have performed first Repair IMEI or Unlock operation. 2. Re-start the phone. 3. Perform the Unlock and Repair IMIE operations. 4. To complete the operation, it is necessary to make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). 5. Insert SIM card, wait 3-5 minutes and try to find and select network manually. If this will not help - we should have your device in hands to research, where is the problem with your device. You can also try to make Repair security and Repair NVM, no other solution. |
07-05-2014, 15:39 | #10 (permalink) |
Member: 754364 Status: Offline Thanks Meter: 59 | 1---Write the first backups (NVM) ok Platform: LG Qualcomm Selected port: COM20--------- Selected model: F320S Reading info...OK Mode: Normal Model ID: F320S Firmware compiled date: Jan 03 2014 Firmware compiled time: 14:00:00 Firmware released date: Jan 20 2014 Firmware released time: 13:54:42 SW Version: M8974A-AAAANAZM-1.0.190082 IMEI: 3530xxxxxxxxxxxxxxx Checking data...OK Writing NVM...OK NVM succesfully repaired. ------------------------------------------------------------ 2----SEC write backup Security Platform: LG Qualcomm Selected port: COM20--------------- Selected model: F320S Reading info...OK Mode: Normal Model ID: F320S Firmware compiled date: Jan 03 2014 Firmware compiled time: 14:00:00 Firmware released date: Jan 20 2014 Firmware released time: 13:54:42 SW Version: M8974A-AAAANAZM-1.0.190082 IMEI: 3530xxxxxxxxxxxxx Opening "F320S_3530xxxxxxxxxxxx_03-07-2014_21-33-50.SEC"... Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "F320S_3530xxxxxxxxxxxx_05-07-2014_17-23-13.SEC" Writing security area...OK Switching to Normal mode... Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Connect cable and press "Ok" button Found model F320S at port COM20Failed! -----------?? problems LGE AndroidNet USB Serial port (com20) I'm wearing the same error usb always |
07-05-2014, 16:22 | #11 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Old security was written into the phone. Quote:
07-05-2014, 19:12 | #12 (permalink) |
Member: 754364 Status: Offline Thanks Meter: 59 | 2. Re-start the phone. 3. Perform the Unlock and Repair IMIE operations. UNLOCK -------------------------------------------------- Platform: LG Qualcomm Selected port: COM20 Selected model: F320S Reading info...OK Mode: Normal Model ID: F320S Firmware compiled date: Jan 03 2014 Firmware compiled time: 14:00:00 Firmware released date: Jan 20 2014 Firmware released time: 13:54:42 SW Version: M8974A-AAAANAZM-1.0.190082 IMEI: 3530XXXXXXXXXXXX Unlocking... Reading NVM...OK Backup saved to "F320S_3530XXXXXXXXXX_05-07-2014_19-21-37.NVM" Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "F320S_3530XXXXXXXXXX_05-07-2014_19-25-04.SEC" Writing security area...OK Switching to Normal mode... Found model F320S at port COM20 Checking data...OK Writing NVM...OK NVM succesfully repaired. Phone successfully unlocked! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). OK imei Repair ---------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM20 Selected model: F320S Reading info...OK Mode: Normal Model ID: F320S Firmware compiled date: Jan 03 2014 Firmware compiled time: 14:00:00 Firmware released date: Jan 20 2014 Firmware released time: 13:54:42 SW Version: M8974A-AAAANAZM-1.0.190082 IMEI: 3530xxxxxxxxxxxx-------------------------------- Fixing IMEI... New IMEI: 3514xxxxxxxxxx------------------------------ Reading NVM...OK Backup saved to "F320S_3530xxxxxxxxxxx_05-07-2014_19-27-39.NVM"------ Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "F320S_3530xxxxxxxxxxx_05-07-2014_19-29-27.SEC"------ Writing security area...OK Switching to Normal mode... Found model F320S at port COM20 Checking data...OK----------------------- Writing NVM...OK------------------------- NVM succesfully repaired.----------------- IMEI successfully fixed!-------------------- To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). imei ok and Factory data reset -----Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). ok ok 5. Insert SIM card, wait 3-5 minutes and try to find and select network manually. --------The Result--------- I did what you said over and over again bad results network is going to come search, the search process is terminated writes In the two models have the same problem please full band -GSM 900 mhz- 1800mhz -2100 mhz etc 2g -3g LG F320S LG-F240S other models, but can be a problem -------------------------------------------------------------------------- LG F320S TEST - 0 Last edited by ozeltekno; 07-05-2014 at 19:18. |
07-05-2014, 19:54 | #15 (permalink) |
Member: 754364 Status: Offline Thanks Meter: 59 | LG F320S imei repair Cellular Phone Cellular Networks: GSM850, GSM900, GSM1800, GSM1900, UMTS2100 (B1) Cellular Data Links: GPRS, EDGE, UMTS, HSDPA, HSUPA, HSPA+ Cellular Antenna: Internal antenna Phone Controller: Qualcomm MSM8974A Dual Cellular Network Operation: Dual standby Secondary Cellular Networks: LTE2100 (B1), LTE850 (B5), LTE1800 (B3) Secondary Cellular Data Links: LTE, LTE-A Secondary Cellular Antenna: Internal antenna Secondary Phone Controller: Qualcomm MSM8974A LG F320S G2 LTE-A Detailed Specs | Technical Datasheet | PDAdb.net LG G2 F320 LG-F320S, LG-F320K, LG-F320L technical specifications :: GSMchoice.com |
