Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus LG/Octoplus LG
Old 01-14-2014, 20:57   #1 (permalink)
ElBerryKM13's Avatar
Member: 1414809
Thanks Meter: 153
Lg f6 d500 no service after imei repair [Solved]
Tried to repair nvm too and still no service. When you pull down the screen it says "Service disable" instead of Tmobile.
Tried to use a different imei and all imeis no service.
Platform: LG Qualcomm
Selected port: COM40
Selected model: D500
Reading info...OK
Mode: Normal
Model ID: D500Z00
Firmware compiled date: Nov 5 2013
Firmware compiled time: 09:37:06
Firmware released date: Nov 5 2013
Firmware released time: 09:37:06
SW Version: D500Z00
IMEI: 013658-00-******-4
Reading info...OK
Mode: Normal
Model ID: D500Z00
SW Version: D500Z00
Fixing IMEI...
New IMEI: 013658-00-******-3
Initializing ADB...OK
Waiting for phone...OK
Checking root access...
Device is already rooted.
Reading NVM...OK
Backup saved to "D500_01365800******4_14-01-2014_13-39-03.NVM"
Reading partition...OK
Reading security area...OK
Backup saved to "D500_01365800******4_14-01-2014_13-45-47.SEC"
Analyzing security...OK
Rebooting phone...
Found model D500Z00 at port COM40
Checking data...OK
Repairing NVM...OK
NVM succesfully repaired.
IMEI successfully fixed!
Please, reboot the phone manually.
Old 01-14-2014, 21:02   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 20,972
Hello.
Please try to write back into your phone first NVM backup (""D500_01365800******4_14-01-2014_13-39-03.NVM""). Also please upload somewhere this NVM backup and first Security backup ("D500_01365800******4_14-01-2014_13-45-47.SEC") and post here links, we will research where can be the problem with your device.
Old 01-14-2014, 22:22   #3 (permalink)
Member: 1414809
Thanks Meter: 153
here both files uploaded:
new imei no service.rar
Old 01-15-2014, 08:39   #4 (permalink)
Member: 1146942
Sonork: 100.1587278
Please try to write back into your phone first NVM backup (""D500_01365800******4_14-01-2014_13-39-03.NVM""), insert SIM card, wait 3-5 minutes and check, whether network is active. Also try to search and select network manually.
Old 01-16-2014, 05:41   #5 (permalink)
Member: 1893099
Thanks Meter: 10
Hmm...
Reading info...OK
Mode: Normal
Model ID: D500Z00
SW Version: D500Z00
Reading info...OK
Mode: Normal
Model ID: D500Z00
SW Version: D500Z00
Fixing IMEI...
Reading NVM...OK
Rebooting phone...
Checking data...OK
Repairing NVM...OK
Did you find solution for this?
I have the same exact problem...
Old 01-16-2014, 05:47   #6 (permalink)
Member: 1414809
Thanks Meter: 153
Same problem no network
Old 01-16-2014, 05:55   #7 (permalink)
Member: 1893099
Thanks Meter: 10
This does not work...
Old 01-16-2014, 07:03   #8 (permalink)
Member: 1146942
Sonork: 100.1587278
We research the poroblem.
Old 01-16-2014, 08:50   #9 (permalink)
Member: 1146942
Sonork: 100.1587278
@ ElBerryKM13 and @ WackyJoe
Please perform "Repair IMEI" once again and then make Factory data reset. Write the result here whether the network is active.
Old 01-16-2014, 14:18   #10 (permalink)
Member: 1893099
Thanks Meter: 10
No luck...
I repaired one more time and did the factory data reset.
Same thing.
Also, when I do *#*#4636#*#* and go into Phone Information, it shows that the RADIO is OFF.
GSM Service: Radio off
I try to press TURN ON RADIO, but it does nothing.
When I try to Manually Search Networks, it says "Searching" for less than a second, then says: "Error while searching for networks."
If I select automatic, it says: "Automatic registration..." but never picks up signal and says it could not find network because inside the *#*#4636#*#* the radio is off.
Old 01-16-2014, 15:50   #11 (permalink)
Member: 1414809
Thanks Meter: 153
Same thing.
yeah hard reset after doing imei repair still no service.
It says radio off on the info menu. Also turning it on does nothing. When you pull down the screen it still says "Service disabled" and normally when the imei is bad it says "No service"
Old 01-16-2014, 15:56   #12 (permalink)
Member: 1893099
Thanks Meter: 10
Yes...
Yes, I also confirm that it says: "Service disabled" where the Carrier name should be...
I hope these guys can solve this, I thought this to be a fast and easy job...bleh
Old 01-16-2014, 16:46   #13 (permalink)
Member: 1146942
Sonork: 100.1587278
We research the problem. As soon as we will have the result, we will write You.
Old 01-19-2014, 16:20   #14 (permalink)
Member: 1893099
Thanks Meter: 10
LG-MS659 F3....also the same problem as the F6 D500.
I did NOT want to try it, but what else was I to do, wait for someone else?
If it was 100% proven, then I would not have been reluctant...
So I tried to do the MS659 (F3) and the EXACT SAME problems as we are seeing in the D500.
1) No network
2) Inside *#*#45636#*#* > Phone Information > You cannot turn on radio
3) MANUAL Search cannot be clicked, it can be but it "Searching" for split second and goes away...select AUTOMATICALLY fails to find anything, if radio is OFF, it will never find anything.
4) Use only 2g networks does not work
5) Data enabled is CHECKED, but GREYED out and cannot select...data roaming can be checked, though it will not help of course.
6) NETWORK MODE cannot be changed in this model...I think it could in the D500, but it was very difficult, you had to click many times.
7) Typing in APN for either models force you to choose MCC and MNC, when it should not...unless these particular models you must?
Please look into these 2 models, thank you.
(Logs sent via SKYPE...I cannot post files/pics in this forum, strange)
Old 01-21-2014, 11:39   #15 (permalink)
Member: 1146942
Sonork: 100.1587278
We have researched backups from your device and have no found any problems with network - it is active. Try to re-flash your device with the firmware from the Support Area and check whether network is available (active), maybe, there is branded firmware in your device...
Page generated in 0.59564 seconds with 7 queries
