03-05-2015, 16:23 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Republica Dominicana Age: 40
Member: 381487 Status: Offline Sonork: 100.1659930 Thanks Meter: 160 | lg flex d951 imei null [Solved] Last edited by Octopus box; 03-11-2015 at 06:57. |
03-05-2015, 16:27 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to re-flash the phone with different firmwares. If this will not help and IMEI will be still null, most likely, this is HW issue. We can prepare test Software version for You with "Write Firmware" feature and You will try to write firmware at your own risk. |
03-05-2015, 16:39 | #3 (permalink) | |
Member: 381487 Status: Offline Sonork: 100.1659930 Thanks Meter: 160 | Quote:
03-05-2015, 17:15 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | We have prepared and sent You test Software version to PM. Please try to find original firmware (currently we have no firmwares for D951), select D959 model in the Software list, convert firmware into "*.oct" firmware file by using built-in Firmware converter ("Firmware converter" button in the Software) and then try to write it. Post here the result. |
03-10-2015, 17:58 | #5 (permalink) | |
