02-24-2015, 06:18 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | LG G2 D802 - Setting Mini OS Status to 2...Failed! Platform: LG Qualcomm Selected port: COM41 Selected model: D802 Reading info...OK Mode: Emergency Initializing flash...OK Model ID: LG-D802 SW version: LGD802AT-00-V20b-H3G-XX-MAR-12-2014+0 LAF Version: 1.0 Product ID: IMEI: 358635-05-951858-0 Target operator: H3G Hardware: rev_b Battery level: 94% Opening "India 32GB D80210C_00.oct"...OK Setting options...OK Reading partition...OK Formating USERDATA...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing dbi...OK Writing aboot...OK Writing rpm...OK Writing boot...OK Writing tz...OK Writing persist...OK Writing recovery...OK Writing laf...OK Writing system...OK Writing cust...OK Writing BackupGPT...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Waiting for phone... Found model D802 at port COM41 Setting Mini OS Status to 2...Failed! Octoplus LG 1.8.5 Problem is after flash showing 11 gb where phone is 32 gb Br - srinibas |
02-24-2015, 07:21 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Try to write other firmwares, most likely, firmware, that You have written is not suitable to your phone's revision. |
02-24-2015, 07:47 | #3 (permalink) |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | This is the firmware - " India 32GB D80210C_00.kdz " & " BIN_LGD802AT-01-V20b-240-02-MAR-12-2014-32G+0.tot " flash after convert Same result of both files Can you please suggest any other file Br - srinibas |
02-24-2015, 07:50 | #4 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,308 | India 32GB D80210C_00.kdz this firmware not match with such phones try to use lg flash tool for repair u r phone use this link :csmg.lgmobile.com:9002/csmg/b2c/client/auth_model_check2.jsp?esn=(enter here u r phone imei) and download the firmware given in down lines |
02-24-2015, 08:10 | #5 (permalink) | |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Br - srinibas | |
02-24-2015, 12:01 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | We have prepared and sent You test Software version to PM. Here is original firmwares: LG G2 Firmware List. Download original firmware, which You need, convert it into "*.oct" file ("Firmware converter" button in the Software) and try to write. Post here the result. |
02-24-2015, 15:18 | #7 (permalink) | |
Br - srinibas | |
02-24-2015, 17:32 | #9 (permalink) |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Checking data...OK Platform: LG Qualcomm Selected port: COM41 Selected model: D802 Reading info...OK Mode: Normal Model ID: D802 Firmware compiled date: Aug 05 2013 Firmware compiled time: 17:00:00 Firmware released date: Dec 4 2013 Firmware released time: 14:39:46 SW Version: M8974A-AAAANAZM-1.0.190036 IMEI: 358635-05-951858-0 SPC: 000000 Opening "India 32GB D80210C_00.oct"...OK Switching to Download mode...OK Initializing flash...OK Setting options...OK Reading partition...OK Formating USERDATA...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing dbi...OK Writing aboot...OK Writing rpm...OK Writing boot...OK Writing tz...OK Writing persist...OK Writing recovery...OK Writing laf...OK Writing system...OK Writing cust...OK Writing BackupGPT...OK Reading partition...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! |
02-25-2015, 05:38 | #11 (permalink) | |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | No main problem is same , still showing as a 16GB phone Quote:
Br - srinibas | |
02-25-2015, 05:57 | #12 (permalink) | |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | The particular model is 32 GB before flashing it was OK , i have checked . In new setup only this part is fixed Quote:
Br - srinibas | |
