06-17-2017, 15:24 | #1 (permalink) |
Freak Poster Join Date: May 2015
Member: 2397754 Status: Offline Thanks Meter: 98 | Lg g3 d852 unlocked -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM306 Selected model: D852 Reading info... Mode: Emergency Initializing flash...OK SW version: LGD852AT-01-V30g-302-220-JUL-21-2016+0 Android version: 6.0 LAF Version: 1.1 Product ID: HD54S150910002238 IMEI: 354608-06-538557-9 Target operator: TLS Hardware: rev_10 Performed by 2.6.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM306 Selected model: D852 Reading info... Model ID: LG-D852 IMEI: 354608-06-538557-9 Android version: 6.0 Battery level: 19% SW Version: D85230g Mode: Emergency Initializing flash...OK SW version: LGD852AT-01-V30g-302-220-JUL-21-2016+0 Android version: 6.0 LAF Version: 1.1 Product ID: HD54S150910002238 IMEI: 354608-06-538557-9 Target operator: TLS Hardware: rev_10 Unlocking... Switching to Normal mode... Trying to enable Diagnostics ports...Failed! Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Press "Ok" button Trying to enable Diagnostics ports...Failed! Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Diagnostics ports are enbled! Switching to Serial Port...Failed! Trying to enable Diagnostics ports... Checking root access... Phone is not rooted. Sending exploit...OK Performed by 2.6.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM307 Selected model: D852 Reading info... Model ID: LG-D852 IMEI: 354608-06-538557-9 Android version: 6.0 Battery level: 19% SW Version: D85230g Trying to enable Diagnostics ports... Found model D852 at port COM307 Unlocking... Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "D852_354608065385579_17-06-2017_14-06-03.qcn" Do you want to create security backup? Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Reading security area...OK Backup saved to "D852_354608065385579_17-06-2017_14-20-55.SEC" Switching to Normal mode... Found model D852 at port COM307 Writing security area...OK Rebooting phone... Found model D852 at port COM307 Phone successfully unlocked! Rebooting phone... Performed by 2.6.8 Software version. Last edited by Octopus box; 06-18-2017 at 08:50. |
The Following 2 Users Say Thank You to fast solution For This Useful Post: |
