01-17-2015, 01:25 | #1 (permalink) |
Junior Member Join Date: Jan 2015
Member: 2329684 Status: Offline Thanks Meter: 0 | lg g3 d855 imei repair Last edited by Octopus box; 04-13-2015 at 06:58. |
01-17-2015, 08:43 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. What is the problem exactly with connection? What cable do You use exactly? You should use the special LG P999 cable with 910 kOhm resistor inside, not standart Micro USB cable. Please, read Software manual ("Cable & Options" tab in the Software) what cable You should use for what action. |
01-26-2015, 07:31 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | You can try to use standart Micro USB cable, sometimes the operations can be performed via this cable, but in general, You should use LG P999 cable with 990 kOhm resistor inside. |
04-11-2015, 06:18 | #6 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | @ yasirsw Quote:
To connect the phone, do the next: 1. Install neccessary drivers (http://octoplusbox.com/files/drivers...Ver_3.12.3.exe). 2. Re-boot the PC. 3. Restart the phone. 4. Connect the phone directly to PC motherboard USB port via LG P999 cable (don't use USB hubs, this is important). 5. Go to "Settings -> Networks -> Tethering & Networks -> Turn on "USB tethering". 6. Press "Read info" button. | |
04-11-2015, 14:56 | #8 (permalink) | |
Freak Poster Join Date: Sep 2012 Location: south africa Age: 39
Member: 1813139 Status: Offline Thanks Meter: 45 | window 7 and xp same untitled.JPG 20150411_153201.jpg Quote:
04-12-2015, 07:04 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | What is the firmware Android version in your phone? Note, if here Android 5.x.x firmware in your device, You should downgrade it to Android 4.4.x and only then connect the phone in Normale Mode. |
