08-03-2015, 16:51 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Location: PaKiStAn Age: 44
Member: 51639 Status: Offline Thanks Meter: 76 | LG G3 D855 service disabled [Solved] just want to ask question can octopus repair "service disable" phone ? phone was working now totally disabled Last edited by Octopus box; 11-30-2015 at 12:37. |
08-03-2015, 16:53 | #2 (permalink) |
Member: 51639 Status: Offline Thanks Meter: 76 | log file is here Platform: LG Qualcomm Selected port: COM36 Selected model: D855 Reading info... Model ID: LG-D855 IMEI: 354153-06-261540-5 Android version: 5.0 Battery level: 40% Mode: Normal -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM36 Selected model: D855 Reading info... Model ID: LG-D855 IMEI: 354153-06-261540-5 Android version: 5.0 Battery level: 40% Mode: Normal Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D855_354153062615405_03-08-2015_17-01-32.SEC" Writing security area...OK Rebooting phone... -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM36 Selected model: D855 Reading info... Model ID: LG-D855 IMEI: 000000-00-000000-0 Android version: 5.0 Battery level: 40% Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Diagnostics ports are enbled! Switching to Serial Port... Failed! Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Initializing ADB...OK Waiting for phone...OK Phone is not rooted. Sending exploit...OK Switching to Download mode...OK Initializing flash...OK Executing exploit...OK Press "Grant" button on the phone every time when superuser dialog appears Initializing ADB...OK Waiting for phone...OK Checking root access... Initializing ADB...OK Waiting for phone...OK Phone is not rooted. Could not get root access. Please, root the phone manually! Failed! Connecting to server support.octoplusbox.com:82...OK Authorizing...OK -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM36 Selected model: D855 Reading info... Model ID: LG-D855 IMEI: 000000-00-000000-0 Android version: 5.0 Battery level: 41% Mode: Normal Firmware compiled date: Nov 20 2014 Firmware compiled time: 04:00:00 Firmware released date: May 15 2015 Firmware released time: 14:50:11 SW Version: MPSS.DI.2.0.1.c1.13-00048-M8974AAAAANPZM-1 SPC: 000000 Opening "Please, select firmware file"...Failed! File does not exists! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM36 Selected model: D855 Reading info... Model ID: LG-D855 IMEI: 000000-00-000000-0 Android version: 5.0 Battery level: 41% Mode: Normal Firmware compiled date: Nov 20 2014 Firmware compiled time: 04:00:00 Firmware released date: May 15 2015 Firmware released time: 14:50:11 SW Version: MPSS.DI.2.0.1.c1.13-00048-M8974AAAAANPZM-1 SPC: 000000 Opening "D85520i_00_16GB.oct"...OK Switching to Download mode...OK Initializing flash...OK Setting options...OK Reading partition...OK Formating USERDATA...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing dbi...OK Writing aboot...OK Writing rpm...OK Writing tz...OK Writing boot...OK Writing persist...OK Writing recovery...OK Writing laf...OK Writing factory...OK Writing system...OK Writing cust...OK Writing BackupGPT...OK Reading partition...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM36 Selected model: D855 Reading info... Model ID: LG-D855 IMEI: 000000-00-000000-0 Android version: 5.0 Battery level: 42% Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.OK Diagnostics ports are enbled! Switching to Serial Port... Failed! Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Initializing ADB...OK Waiting for phone...OK Phone is not rooted. Sending exploit...OK Switching to Download mode...OK Initializing flash...OK Executing exploit...OK Press "Grant" button on the phone every time when superuser dialog appears Initializing ADB...OK Waiting for phone...OK Checking root access... Initializing ADB...OK Waiting for phone...OK Phone is already rooted. Root access garanted! Diagnostics ports are enbled! Switching to Serial Port... Found model D855 at port COM36 Fixing IMEI... New IMEI: 354153-06-261540-5 Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "D855_000000000000000_03-08-2015_18-10-38.qcn" Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D855_000000000000000_03-08-2015_18-16-06.SEC" Writing security area...OK Switching to Normal mode... Found model D855 at port COM36 Send SPC...OK Writing QCN... Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing QCN done! IMEI successfully fixed! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM36 Selected model: D855 Reading info... Model ID: LG-D855 IMEI: 354153-06-261540-5 Android version: 5.0 Battery level: 41% Mode: Normal Firmware compiled date: Nov 20 2014 Firmware compiled time: 04:00:00 Firmware released date: Feb 26 2015 Firmware released time: 10:11:23 SW Version: MPSS.DI.2.0.1.c1.13-00048-M8974AAAAANPZM-1 IMEI: 354153-06-261540-5 SPC: 000000 Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D855_354153062615405_03-08-2015_18-26-19.SEC" Writing security area...OK Rebooting phone... -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM36 Selected model: D855 Reading info... Model ID: LG-D855 IMEI: 000000-00-000000-0 Android version: 5.0 Battery level: 41% Mode: Normal Firmware compiled date: Nov 20 2014 Firmware compiled time: 04:00:00 Firmware released date: Feb 26 2015 Firmware released time: 10:11:23 SW Version: MPSS.DI.2.0.1.c1.13-00048-M8974AAAAANPZM-1 SPC: 000000 Fixing IMEI... New IMEI: 354153-06-261540-5 Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "D855_000000000000000_03-08-2015_18-27-51.qcn" Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D855_000000000000000_03-08-2015_18-33-20.SEC" Writing security area...OK Switching to Normal mode... Found model D855 at port COM36 Send SPC...OK Writing QCN... Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing QCN done! IMEI successfully fixed! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM36 Selected model: D855 Reading info... Model ID: LG-D855 IMEI: 354153-06-261540-5 Android version: 5.0 Battery level: 42% Mode: Normal Firmware compiled date: Nov 20 2014 Firmware compiled time: 04:00:00 Firmware released date: Feb 26 2015 Firmware released time: 10:11:23 SW Version: MPSS.DI.2.0.1.c1.13-00048-M8974AAAAANPZM-1 IMEI: 354153-06-261540-5 SPC: 000000 Unlocking... Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "D855_354153062615405_03-08-2015_18-36-25.qcn" Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D855_354153062615405_03-08-2015_18-41-41.SEC" Writing security area...OK Switching to Normal mode... Found model D855 at port COM36 Send SPC...OK Writing QCN... Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing QCN done! Phone successfully unlocked! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). |
08-03-2015, 17:11 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Please repeat "Unlock" operation with enabled "Skip Read/Write QCN during Unlock operation" option, then make Factory Reset, as it is prompted by Software. When phone turns on, configure it, wait 2-5 minutes, then try to find and select Network manually. |
08-03-2015, 17:57 | #4 (permalink) |
Member: 51639 Status: Offline Thanks Meter: 76 | Checking data...OK Platform: LG Qualcomm Selected port: COM36 Selected model: D855 Reading info... Model ID: LG-D855 IMEI: 354153-06-261540-5 Android version: 5.0 Battery level: 49% Mode: Normal Firmware compiled date: Nov 20 2014 Firmware compiled time: 04:00:00 Firmware released date: Feb 26 2015 Firmware released time: 10:11:23 SW Version: MPSS.DI.2.0.1.c1.13-00048-M8974AAAAANPZM-1 IMEI: 354153-06-261540-5 SPC: 000000 Unlocking... Skip Read/Write QCN Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D855_354153062615405_03-08-2015_19-17-39.SEC" Writing security area...OK Switching to Normal mode... Found model D855 at port COM36 Phone successfully unlocked! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). after that factory reset and after setup waited for 10 minutes still service disable, no network found |
08-03-2015, 18:06 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Try to write QCN file from the Support Area, then again make Factory Reset, configure the phone, wait 2-5 minutes and try to find and select Network manually. |
08-03-2015, 18:57 | #6 (permalink) |
Member: 51639 Status: Offline Thanks Meter: 76 | Initializing ADB...OK Waiting for phone...OK Checking root access... Initializing ADB...OK Waiting for phone...OK Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model D855 at port COM36 Selecting input file...OK Source file: "D855.qcn" Do You want to write IMEI from QCN file or to leave current IMEI? Write IMEI from QCN file! Send SPC...OK Writing QCN... Writing EFS...OK Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing Provisioning Items...OK Writing QCN done! factory reset still same |
08-04-2015, 13:14 | #7 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please write first Security backup back into the phone - phone will be restored to its initial condition: Quote:
11-29-2015, 13:18 | #8 (permalink) |
Freak Poster Join Date: Apr 2008 Location: *.onion
Member: 740263 Status: Offline Sonork: 100.1608512 Thanks Meter: 37 | it worked for me thanks octopus service deabled it mean diffrent thinks form me it imei come to 000000000000000 do repair imei unlock again repair network thats all Welcome to Octoplus/Octopus Box LG Software version 2.1.2 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM521 Selected model: D855 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... Model ID: LG-D855 IMEI: 000000-00-000000-0 Android version: 5.0 Battery level: 91% Mode: Normal Switching to Download mode...OK Initializing flash...OK Resetting Screen Lock... Reading partition...OK Resetting FRP Lock... Resetting screen lock successfully completed! -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM103 Selected model: D855 Reading info... Model ID: Canceled! -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM103 Selected model: D855 Reading info... Could not detect mode! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM103 Selected model: D855 Reading info... Model ID: LG-D855 IMEI: 000000-00-000000-0 Android version: 5.0 Battery level: 94% Mode: Normal Firmware compiled date: Nov 20 2014 Firmware compiled time: 04:00:00 Firmware released date: Aug 18 2015 Firmware released time: 19:19:38 SW Version: MPSS.DI.2.0.1.c1.13-00048-M8974AAAAANPZM-1 SPC: 000000 Fixing IMEI... New IMEI: 355673-06-996895-1 Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "D855_000000000000000_29-11-2015_12-31-50.qcn" Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D855_000000000000000_29-11-2015_12-42-09.SEC" Writing security area...OK Switching to Normal mode... Found model D855 at port COM103 Send SPC...OK Writing QCN... Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing QCN done! IMEI successfully fixed! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM521 Selected model: D855 Reading info... Model ID: LG-D855 IMEI: 355673-06-996895-1 Android version: 5.0 Battery level: 93% Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM521 Selected model: D855 Reading info... Model ID: LG-D855 IMEI: 355673-06-996895-1 Android version: 5.0 Battery level: 94% Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Diagnostics ports are enbled! Switching to Serial Port... Failed! Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Initializing ADB...OK Waiting for phone...OK Phone is not rooted. Sending exploit...OK Switching to Download mode...OK Initializing flash...OK Executing exploit...OK Press "Grant" button on the phone every time when superuser dialog appears Initializing ADB...OK Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Failed! -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM103 Selected model: D855 Reading info... Model ID: LG-D855 IMEI: 355673-06-996895-1 Android version: 5.0 Battery level: 96% Mode: Normal Firmware compiled date: Nov 20 2014 Firmware compiled time: 04:00:00 Firmware released date: Aug 18 2015 Firmware released time: 19:19:38 SW Version: MPSS.DI.2.0.1.c1.13-00048-M8974AAAAANPZM-1 IMEI: 355673-06-996895-1 SPC: 000000 Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM103 Selected model: D855 Reading info... Model ID: LG-D855 IMEI: 355673-06-996895-1 Android version: 5.0 Battery level: 96% Mode: Normal Firmware compiled date: Nov 20 2014 Firmware compiled time: 04:00:00 Firmware released date: Aug 18 2015 Firmware released time: 19:19:38 SW Version: MPSS.DI.2.0.1.c1.13-00048-M8974AAAAANPZM-1 IMEI: 355673-06-996895-1 SPC: 000000 Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.Canceled! -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM103 Selected model: D855 Reading info... Model ID: LG-D855 IMEI: 355673-06-996895-1 Android version: 5.0 Battery level: 97% Mode: Normal Firmware compiled date: Nov 20 2014 Firmware compiled time: 04:00:00 Firmware released date: Aug 18 2015 Firmware released time: 19:19:38 SW Version: MPSS.DI.2.0.1.c1.13-00048-M8974AAAAANPZM-1 IMEI: 355673-06-996895-1 SPC: 000000 Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.Canceled! -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM103 Selected model: D855 Reading info... Model ID: LG-D855 IMEI: 355673-06-996895-1 Android version: 5.0 Battery level: 97% Mode: Normal Firmware compiled date: Nov 20 2014 Firmware compiled time: 04:00:00 Firmware released date: Aug 18 2015 Firmware released time: 19:19:38 SW Version: MPSS.DI.2.0.1.c1.13-00048-M8974AAAAANPZM-1 IMEI: 355673-06-996895-1 SPC: 000000 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM103 Selected model: D855 Reading info... Model ID: LG-D855 IMEI: 355673-06-996895-1 Android version: 5.0 Battery level: 97% Mode: Normal Firmware compiled date: Nov 20 2014 Firmware compiled time: 04:00:00 Firmware released date: Aug 18 2015 Firmware released time: 19:19:38 SW Version: MPSS.DI.2.0.1.c1.13-00048-M8974AAAAANPZM-1 IMEI: 355673-06-996895-1 SPC: 000000 Checking Resource File...OK Skip Read/Write QCN Repairing Network... Repair Network Done! Please, reboot the phone manually. after rebooting network comme again thank you octopus team |
01-25-2016, 14:37 | #9 (permalink) | |
No Life Poster Join Date: Aug 2001 Location: Roma Age: 49
Member: 5926 Status: Offline Thanks Meter: 275 | Quote:
I'd like to know how to fix this. | |
01-25-2016, 14:44 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Please, insert sim card, then check network, if network locked, please try to perform Unlock operation, after post here result. |
