Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus LG/Octoplus LG
Old 04-25-2016, 09:11   #1 (permalink)
freshwhite's Avatar
Member: 87204
Thanks Meter: 146
Lg g3 f490l flashing
Plz help how to flash f490l with octoplus
Old 04-25-2016, 11:33   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,412
Hello.
Unfortunately, this phone model isn't supported, we will try to add support in future updates.
Old 12-05-2016, 12:17   #3 (permalink)
Member: 2013701
Thanks Meter: 24
Hello Octopus TM please add this phone for flashing
i have 2 devices fully Virus )))
Old 01-26-2017, 18:02   #4 (permalink)
Crazy Poster
Member: 1712378
brother is this f460l g3 .... ?
either cases u can do kdz file convert it under f460l model and perform flash u get success ,..
Old 07-06-2017, 06:27   #5 (permalink)
Member: 1024748
Thanks Meter: 53
i convert kdz file but not accepting file by octopus
Old 07-06-2017, 06:28   #6 (permalink)
Member: 1024748
Thanks Meter: 53
Originally Posted by Octopus box View Post
Hello.
sir can you please provide flash file... oct file for f490l
Old 07-06-2017, 06:40   #7 (permalink)
Faheem Anjum's Avatar
Member: 399832
Sonork: Faheem Anjum
Thanks Meter: 24,310
For flashing you need to choose F400K from Model list and Flash phone Sholud work
The Following User Says Thank You to Faheem Anjum For This Useful Post:
Old 07-06-2017, 06:58   #8 (permalink)
Member: 1024748
Thanks Meter: 53
broo
Checking data...OK
Platform: LG Qualcomm
Selected port: COM185
Selected model: F400K
Reading info...
Model ID: LG-F490L
Incompatible model ID!
IMEI: 354180-06-059606-3
Android version:
Battery level: 19%
SW Version: F490L10s
Mode: Emergency
Initializing flash...OK
SW version: LGF490LAT-00-V10s-LGU-KR-FEB-25-2016+0
Android version: 4.4.4
LAF Version: 1.1
Product ID: PT03S150216000743
Target operator: LGU
Hardware: rev_1.0
Opening "F490L21b_00.kdz"...OK
Firmware version: LGF490LAT-00-V21b-LGU-KR-MAR-23-2015+0
Firmware model: LG-F490L
File declared for different phone model!
Performed by 2.6.1 Software version.
Old 07-06-2017, 08:47   #9 (permalink)
Member: 399832
mark into Manual flashing and try once again as i already told to team about skip to check model id in flashing but they dont accept it
other tool can flash and can skip model id check
Old 07-06-2017, 11:04   #10 (permalink)
Member: 1024748
Thanks Meter: 53
brooooo i already tried manual tick... same option showing... test software can help ma b.. or can u broo provide any other firmware
Old 07-06-2017, 12:22   #11 (permalink)
Member: 1146942
Sonork: 100.1587278
We have prepared and uploaded test Software version into the Support Area; download and install it from the Support Area ("LG/TEST SOFTWARE" folder), then connect your device as F490L and perform "Write Firmware" operation. Post here full Software log.
The Following 3 Users Say Thank You to Octopus box For This Useful Post:
Old 07-06-2017, 13:04   #12 (permalink)
Member: 1024748
Thanks Meter: 53
txx octopus team
Welcome to Octoplus/Octopus Box LG Software version 2.6.9.5
Checking data...OK
Selected model: F490L
Reading info...
Mode: Emergency
LAF Version: 1.1
Hardware: rev_1.0
Writing phone firmware without real necessity is at your own risk.
Downgrade may lead to phone damage!
Please, make sure the phone's battery is fully charged.
Disconnect all other devices from the computer (including phones,
modems, etc.) and close all other running programs.
To avoid errors in the flashing process, use a clean PC (without any
installed drivers for other Qualcomm-based devices).
You should not run any other programs or attach new devices to your
computer during the flashing!
Prepairing firmware...OK
Setting options...OK
Reading partitions...OK
Formating USERDATA...OK
Formating ENCRYPT...OK
Writing 1/41 PrimaryGPT_0.bin...OK
Writing 2/41 MSBL_1024.bin...OK
Writing 3/41 CPBL_2048.bin...OK
Writing 4/41 CABL_4096.bin...OK
Writing 5/41 TEE_10240.bin...OK
Writing 6/41 BOOT_18432.bin...OK
Writing 7/41 MODEMBIN_51200.bin...OK
Writing 8/41 RECOVERY_346112.bin...OK
Writing 10/41 FACTORY_398336.bin...OK
Writing 11/41 LAF_439296.bin...OK
Writing 12/41 CPBLB_611328.bin...OK
Writing 13/41 CABLB_612352.bin...OK
Writing 14/41 TEEB_616448.bin...OK
Writing 15/41 SYSTEM_624640.bin...OK
Writing 16/41 SYSTEM_888136.bin...OK
Writing 17/41 SYSTEM_1152984.bin...OK
Writing 18/41 SYSTEM_1412424.bin...OK
Writing 19/41 SYSTEM_1416480.bin...OK
Writing 20/41 SYSTEM_1677272.bin...OK
Writing 21/41 SYSTEM_1936712.bin...OK
Writing 22/41 SYSTEM_1940768.bin...OK
Writing 23/41 SYSTEM_2201560.bin...OK
Writing 24/41 SYSTEM_2461000.bin...OK
Writing 25/41 SYSTEM_2465056.bin...OK
Writing 26/41 SYSTEM_2725848.bin...OK
Writing 27/41 SYSTEM_2985288.bin...OK
Writing 28/41 SYSTEM_2989344.bin...OK
Writing 29/41 SYSTEM_3250136.bin...OK
Writing 30/41 SYSTEM_3512280.bin...OK
Writing 31/41 SYSTEM_3774424.bin...OK
Writing 32/41 SYSTEM_4036568.bin...OK
Writing 33/41 SYSTEM_4294656.bin...OK
Writing 34/41 SYSTEM_4556800.bin...OK
Writing 35/41 SYSTEM_4818944.bin...OK
Writing 36/41 SYSTEM_5081088.bin...OK
Writing 37/41 SYSTEM_5343232.bin...OK
Writing 38/41 SYSTEM_5605376.bin...OK
Writing 39/41 SYSTEM_5867520.bin...OK
Writing 40/41 SYSTEM_5871576.bin...OK
Writing 41/41 BackupGPT_61070336.bin...OK
Formating RCT...OK
Formating MPT...OK
Finalizing...OK
Writing firmware done!
Performed by 2.6.9.5 Software version.
flashed successfully
The Following User Says Thank You to kamrul1111 For This Useful Post:
Old 09-21-2017, 22:35   #13 (permalink)
Crazy Poster
Member: 653559
Thanks Meter: 10
flash done but still bootloop
Old 09-22-2017, 07:39   #14 (permalink)
Member: 1146942
Sonork: 100.1587278
If You have reflash the device and problem still remain, most likely it's HW.
The Following User Says Thank You to Octopus box For This Useful Post:
Old 10-09-2017, 07:16   #15 (permalink)
Member: 2599806
Thanks Meter: 44
F490L flashing error how to solve???
Checking data...OK
Selected port: COM37
Reading info...
Model ID: LG-F490L
IMEI: 354180-06-163572-0
Battery level: 62%
Mode: Emergency
LAF Version: 1.1
Product ID: PT03S150907000829
Hardware: rev_1.0
Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs.
To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices).
You should not run any other programs or attach new devices to your computer during the flashing!
Opening "F490L21b_00.oct"...Failed!
Firmware file has wrong structure (error code: ABQP17D2PK). Please, redownload firmware file. If it will not help - contact to support at [email protected]
Performed by 2.7.6.2 Software version.
Page generated in 0.77264 seconds with 8 queries
