04-07-2016, 11:29 | #1 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 656666 Status: Offline Thanks Meter: 28 | LG G3 Mcafee removed but comes back after update !![Solved] |
04-07-2016, 16:37 | #3 (permalink) |
Member: 656666 Status: Offline Thanks Meter: 28 | Thanks Once the phone is returned I will try. Person said she updated to lolipop then mcafee ask for pin and was locked out. I had re-flash phone to kitkat initially. My question is anytime the phone is updated to latest this problem will occur or did I miss a step? |
04-14-2016, 19:18 | #4 (permalink) |
Member: 656666 Status: Offline Thanks Meter: 28 | OK, ran kill switch again. Install kitkat tot through octopus box. After I run update OS through phone for lolipop update I get Mcafee Lock again. I have Wifi off and sim remove still pops up. Any thoughts? FYI Their no tot or KDz for lolipop ONLY Kitkat Tot/KMZ availible. |
04-15-2016, 08:42 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please, check your PM, we have sent firmware for You ,then post here result. Last edited by Octopus box; 04-15-2016 at 13:08. |
08-11-2016, 10:16 | #12 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | This is my G3 Download mode info. (what android version of your firmware?) should I flash with your file? Code: Welcome to Octoplus/Octopus Box LG Software version 2.3.8 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM381 Selected model: D850 Reading info... Model ID: LG-D850 IMEI: 014065-00-44AAAA-6 Android version: 5.0.1 Battery level: 12% Mode: Emergency Initializing flash...OK SW version: LGD850AT-00-V21r-310-410-AUG-17-2015+0 LAF Version: 1.1 Product ID: SM05S140911001714 IMEI: 014065-00-44AAAA-6 Target operator: ATT Hardware: rev_10 Performed by 2.3.8 software version. |
The Following User Says Thank You to razib143 For This Useful Post: |
08-11-2016, 12:30 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | According to the Software log, You have higher version of firmware, but You can try to reflash phone with firmware which we sent to You. Last edited by Octopus box; 08-11-2016 at 12:36. |
08-11-2016, 14:34 | #14 (permalink) | |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Quote:
Code: Welcome to Octoplus/Octopus Box LG Software version 2.3.8 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM381 Selected model: D850 Reading info... Mode: Emergency Initializing flash...OK SW version: LGD850AT-00-V21r-310-410-AUG-17-2015+0 LAF Version: 1.1 Product ID: SM05S140911001714 IMEI: 014065-00-44AAAA-6 Target operator: ATT Hardware: rev_10 Opening "D85020a_00.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing dbi...OK Writing aboot...OK Writing rpm...OK Writing tz...OK Writing boot...OK Writing persist...OK Writing recovery...OK Writing laf...OK Writing factory...OK Writing system...OK Writing cust...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.3.8 software version. | |
11-07-2016, 15:14 | #15 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | Welcome to Octoplus/Octopus Box LG Software version 2.4.8 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM14 Selected model: D850 To deactivate Kill Switch do the next: 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS- USB QDLoader 9008". 3. Release testpoint.Failed! Performed by 2.4.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM14 Selected model: D850 To deactivate Kill Switch do the next: 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS- USB QDLoader 9008". 3. Release testpoint.Failed! Performed by 2.4.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM14 Selected model: D850 To deactivate Kill Switch do the next: 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS- USB QDLoader 9008". 3. Release testpoint.OK Sending loader...OK Connecting to server ...OK Initializing device...OK Deactivating Kill Switch...OK Please, reconnect the battery, put the phone in download mode manually and re-flash the phone. Performed by 2.4.8 Software version. Welcome to Octoplus/Octopus Box LG Software version 2.4.8 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM14 Selected model: D850 To deactivate Kill Switch do the next: 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS- USB QDLoader 9008". 3. Release testpoint.Failed! Performed by 2.4.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM14 Selected model: D850 To deactivate Kill Switch do the next: 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS- USB QDLoader 9008". 3. Release testpoint.Failed! Performed by 2.4.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM14 Selected model: D850 To deactivate Kill Switch do the next: 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS- USB QDLoader 9008". 3. Release testpoint.OK Sending loader...OK Connecting to server ...OK Initializing device...OK Deactivating Kill Switch...OK Please, reconnect the battery, put the phone in download mode manually and re-flash the phone. Performed by 2.4.8 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM571 Selected model: D850 Reading info... Mode: Emergency Initializing flash...OK SW version: LGD850AT-00-V30l-ATT-US-MAY-11-2016+0 Android version: 6.0 LAF Version: 1.1 Product ID: SM01S140912000898 IMEI: 014065-00-410765-9 Target operator: ATT Hardware: rev_10 Performed by 2.4.8 Software version. Welcome to Octoplus/Octopus Box LG Software version 2.4.8 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM14 Selected model: D850 To deactivate Kill Switch do the next: 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS- USB QDLoader 9008". 3. Release testpoint.Failed! Performed by 2.4.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM14 Selected model: D850 To deactivate Kill Switch do the next: 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS- USB QDLoader 9008". 3. Release testpoint.Failed! Performed by 2.4.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM14 Selected model: D850 To deactivate Kill Switch do the next: 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS- USB QDLoader 9008". 3. Release testpoint.OK Sending loader...OK Connecting to server ...OK Initializing device...OK Deactivating Kill Switch...OK Please, reconnect the battery, put the phone in download mode manually and re-flash the phone. Performed by 2.4.8 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM571 Selected model: D850 Reading info... Mode: Emergency Initializing flash...OK SW version: LGD850AT-00-V30l-ATT-US-MAY-11-2016+0 Android version: 6.0 LAF Version: 1.1 Product ID: SM01S140912000898 IMEI: 014065-00-410765-9 Target operator: ATT Hardware: rev_10 Performed by 2.4.8 Software version. tot flash error i need to use fw converter ? with octopus ? |
