11-19-2016, 12:41 | #1 (permalink) |
Insane Poster Join Date: Apr 2005 Location: turkya Age: 45
Member: 141155 Status: Offline Thanks Meter: 6 | LG-G350 cant repair imei New IMEI A: XXXXXX-XX-XXXXXX-X Writing security area...OK all is ok but the imei did not change ? There has been no change on the old imei |
11-19-2016, 12:51 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. What is IMEI in your device now? Is the IMEI correct or it is damaged? Please read phone's info, repeat "Repair IMEI" operation again and post here full Software log, we will check. |
11-19-2016, 13:13 | #3 (permalink) | |
Member: 141155 Status: Offline Thanks Meter: 6 | Quote:
Platform: LG MTK Selected port: COM13 Selected baudrate: 921600 Selected model: G350 Selected USB connection type Please, disconnect battery and connect cable...OK Phone found. Setting power state...OK Sending loader...OK Synchronizing with loader...OK Detecting NOR flash chip...OK Reading info...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 350305-26-000000-1 Bluetooth address: 00:05:C9:00:00:00 Wi-Fi MAC address: 00:00:00:00:00:00 NOR flash chip: Unknown NOR size: 32 Mb -------------------------------------------------------------------------------- Fixing IMEI A... New IMEI A: 356609-01-011121-7 Writing security area...OK but the imei stel 350305260000001 | |
11-19-2016, 13:21 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please, install the latest Software version after repeat operation again. |
11-19-2016, 13:35 | #5 (permalink) | |
-------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM13 Selected baudrate: 921600 Selected model: G350 Selected USB connection type Please, disconnect battery and connect cable...OK Phone found. Setting power state...OK Sending loader...OK Synchronizing with loader...OK Detecting NOR flash chip...OK Reading info...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 350305-26-000000-1 Bluetooth address: 00:05:C9:00:00:00 Wi-Fi MAC address: 00:00:00:00:00:00 NOR flash chip: Unknown NOR size: 32 Mb -------------------------------------------------------------------------------- Fixing IMEI A... New IMEI A: 356609-01-011122-5 Writing security area...OK Performed by 2.5.0 Software version. The problem is still going on nothing has changed old imei not change | |
11-19-2016, 14:41 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please, read Full flash and EEPROM ("Read Full flash" and "Read EEPROM / FS" buttons in Software), after send read files us to PM, we will research where can be the problem with your phone. Last edited by Octopus box; 11-19-2016 at 16:29. |
11-19-2016, 15:30 | #7 (permalink) | |
Ok I am waiting you and thanx 4 help me Last edited by Octopus box; 11-19-2016 at 16:30. | |
11-19-2016, 15:33 | #8 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Quote:
11-19-2016, 17:35 | #9 (permalink) | |
https://mega.nz/#!h4Ellaba!WqNw5lO8c...KgOo8tgR9Jts8Q eprom https://mega.nz/#!55dznAzZ!AydYqRCdo...1dvlBWLTr76gpA big thanx octopus tem | |
11-21-2016, 08:37 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | We will research the problem, when solution will be ready, we will inform You. |
11-22-2016, 14:36 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please, download and install test Software version form the Support Area (LG/TEST SOFTWARE/) then repeat operation which You need again, post here full Software log. |
11-23-2016, 13:09 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | To enter Support Area, press "Go to support" button on "Support & options" tab of the Software. Then go to "LG/TEST SOFTWARE" folder. Last edited by Octopus box; 11-23-2016 at 13:34. |
