05-17-2016, 00:12 | #1 (permalink) |
Junior Member Join Date: Oct 2014 Location: san francisco
Member: 2282177 Status: Offline Thanks Meter: 1 | LG G4 H810 IMEI Repair [Solved] Welcome to Octoplus/Octopus Box LG Software version 2.2.9 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM89 Selected model: H810 Reading info... Model ID: LG-H810 IMEI: 000000-00-000000-0 Android version: 6.0 Battery level: 41% Mode: Normal Fixing IMEI... New IMEI: 357905-06-360000-0 Error code: Z1AL3CAS2Q Performed by 2.2.9 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM89 Selected model: H810 Reading info... Model ID: LG-H810 IMEI: 000000-00-000000-0 Android version: 6.0 Battery level: 42% Mode: Normal Fixing IMEI... New IMEI: 357905-06-360000-0 Error code: Z1AL3CAS2Q Performed by 2.2.9 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM90 Selected model: H810 Reading info... Could not detect mode! Performed by 2.2.9 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM89 Selected model: H810 Reading info... Model ID: LG-H810 IMEI: 000000-00-000000-0 Android version: 6.0 Battery level: 42% Mode: Normal Fixing IMEI... New IMEI: 357905-06-360000-0 Error code: Z1AL3CAS2Q Performed by 2.2.9 software version. Last edited by Octopus box; 06-09-2017 at 14:31. |
05-17-2016, 09:10 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Please, make sure that You perform these steps:To connect the phone in Normal Mode, do one of the following: 1.Enable "USB Debugging" mode; 2.Type 277634#*# or *#546368#*810# for coresponding Android version 5.x or 6.x, go to "Port Check Test" (or "SVC Menu -> Port Check Test") and switch "Port Check Test" to "Enabled". |
05-18-2016, 07:27 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please, make sure that You perform these steps: Type 277634#*# or *#546368#*810# for coresponding Android version 5.x or 6.x, go to "Port Check Test" (or "SVC Menu -> Port Check Test") and switch "Port Check Test" to "Enabled". |
08-29-2016, 18:10 | #6 (permalink) | |
Insane Poster Join Date: Aug 2015 Location: VN
Member: 2440630 Status: Offline Thanks Meter: 15 | Quote:
Thanks | |
08-30-2016, 07:00 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Unfortunately, QCN file isn't available for this phone, but You can read out QCN from another correctly working phone and write into your. |
06-09-2017, 13:04 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | @farhan baloch Hello. Please post here full Software log, we will check it. Also, read these rules: http://forum.gsmhosting.com/vbb/f62/...rules-1591101/, http://forum.gsmhosting.com/vbb/f799...leted-2165821/. Last edited by Octopus box; 06-09-2017 at 13:26. |
