06-24-2016, 11:17 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please, post here full Software log, make sure that You connect phone directly to USB port of your PC, don't use HUBS. |
06-24-2016, 16:38 | #4 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 748456 Status: Offline Thanks Meter: 32 | i noticed that if you start the device normaly, and then give the command to read firmware, octoplus reboot device to download mode and it is detected by the soft and the system correctly But if you put manually to download mode, then no device is shown I used several cables type C, but they were not originals, and i used one original (from Meizu or Xiaomi) but no succes |
06-25-2016, 08:30 | #6 (permalink) |
No Life Poster Join Date: Sep 2011 Location: Dubz
Member: 1651733 Status: Offline Thanks Meter: 21 | when come to normal mode cant connect Welcome to Octoplus/Octopus Box LG Software version 2.3.1 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM10 Selected model: H850 Reading info... Model ID: LG-H850 IMEI: 357657-07-xxxxxxx-8 Android version: 6.0.1 Battery level: 100% Mode: Emergency Initializing flash...OK SW version: LGH850AT-00-V10c-OPT1-HQ-APR-15-2016+0 LAF Version: 1.1 Product ID: YE03S160412003673 IMEI: 357657-07-xxxxxxx-8 Target operator: GLOBAL Hardware: rev_11 Performed by 2.3.1 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM10 Selected model: H850 Reading info... Model ID: LG-H850 IMEI: 357657-07-xxxxxxx-8 Android version: 6.0.1 Battery level: 100% Mode: Emergency Initializing flash...OK SW version: LGH850AT-00-V10c-OPT1-HQ-APR-15-2016+0 LAF Version: 1.1 Product ID: YE03S160412003673 IMEI: 357657-07-xxxxxx-8 Target operator: GLOBAL Hardware: rev_11 Fixing IMEI... New IMEI: 357657-01-xxxxxxx-9 Switching to Normal mode... Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Press "Ok" buttonCanceled! Performed by 2.3.1 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM10 Selected model: H850 Reading info... Mode: Emergency Initializing flash...OK SW version: LGH850AT-00-V10c-OPT1-HQ-APR-15-2016+0 LAF Version: 1.1 Product ID: YE03S160412003673 IMEI: 357657-07-xxxxxxx-8 Target operator: GLOBAL Hardware: rev_11 Fixing IMEI... New IMEI: 357657-01-xxxxxxx-9 Switching to Normal mode... Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Press "Ok" buttonFailed! Performed by 2.3.1 software version. |
06-25-2016, 10:00 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please, install the latest Software version and repeat operation again, after post here full Software log. |
08-25-2016, 10:10 | #8 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Budapest
Member: 472482 Status: Offline Thanks Meter: 105 | Welcome to Octoplus/Octopus Box LG Software version 2.3.9 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM266 Selected model: H850 Reading info... Model ID: LG-H850 IMEI: 357657-07,,,,,,,,,, Android version: 6.0.1 Battery level: 96% Mode: Normal Unlocking... Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...Failed! Reading NV_Numbered Items... here have problem , very very slow when reading, 1% half hour !!!!!!!!!, never end one phone . Need solution pls. I have original cable . If i skip backup and phone crash have solution to alive it? Thank |
08-25-2016, 10:45 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | It is better to make a backup of phone QCN. Most likely the problem occurred, because You have not configured the phone for connection. Please do the next: 1. Type 277634#*# or *#546368#*850# for coresponding Android version 5.x or 6.x, go to "Port Check Test" (or "SVC Menu -> Port Check Test") and switch "Port Check Test" to "Enabled". 2. Repeat "Unlock" operation. Post here result and full Software log of "Unlock" operation. |
08-25-2016, 11:40 | #10 (permalink) |
Member: 472482 Status: Offline Thanks Meter: 105 | Thank you ,realy the port is not enable, now is work for me, sorry but cant give the log, its hurry work and i close is . But all is good, very good,i like to use youre product ! little off, just one problem , the lg k10 when you make direct unlock its crash the imei nr. to 0 , after unlock need to repair always. BR. |
08-25-2016, 11:55 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Thank You for feedback! Please create a separate thread with detailed description of problem, which You've faced with lg k10 and with Software logs of performed operations. |
01-12-2017, 08:49 | #13 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Quote:
Please, connect phone via USB cable, select "File Transfer" option on your phone, make sure that You install all drivers according to the Software manual and try to perform Repair IMEI operation. Last edited by Octopus box; 01-12-2017 at 09:08. | |
