hi
lg frp done with octopus
phone version h870s v10h error
flash version h870s v10f done frp
PHP Code:
Welcome to Octoplus/Octopus Box LG Software version 2.7.9
Checking data...OK
Platform: LG Qualcomm
Selected port: COM25
Selected model: H870S
Reading info...
Model ID: LG-H870S
IMEI: 357457-08-063801-9
Android version: 7.0
Battery level: 66%
SW Version: H87010h
Mode: Emergency
Initializing flash...OK
SW version: LGH870SAT-00-V10h-AME-XX-JAN-12-2018+0
LAF Version: 1.1
Product ID: PT01S170403000623
Target operator: GLOBAL
Hardware: rev_10
Opening "H870S10f_00_OPEN_AME_DS_OP_0722_2.kdz"...OK
Firmware version: LGH870SAT-00-V10f-DS1-SI-JUL-22-2017+0
Firmware model: LG-H870S
Writing phone firmware without real necessity is at your own risk.
Downgrade may lead to phone damage!
Please, make sure the phone's battery is fully charged.
Disconnect all other devices from the computer (including phones,
modems, etc.) and close all other running programs.
To avoid errors in the flashing process, use a clean PC (without any
installed drivers for other Qualcomm-based devices).
You should not run any other programs or attach new devices to your
computer during the flashing!
Prepairing firmware...OK
Setting options...OK
Reading partitions...OK
Formating USERDATA...OK
Formating ENCRYPT...OK
Sending signature...OK
Writing 1/107 PrimaryGPT_0.bin...OK
Writing 2/107 laf_6.bin...OK
Writing 3/107 lafbak_12294.bin...OK
Writing 4/107 factory_45062.bin...OK
Writing 6/107 persist_62598.bin...OK
Writing 7/107 system_70790.bin...OK
Writing 8/107 system_103911.bin...OK
Writing 9/107 system_104414.bin...OK
Writing 10/107 system_136829.bin...OK
Writing 11/107 system_169447.bin...OK
Writing 12/107 system_169950.bin...OK
Writing 13/107 system_202365.bin...OK
Writing 14/107 system_234983.bin...OK
Writing 15/107 system_235486.bin...OK
Writing 16/107 system_267901.bin...OK
Writing 17/107 system_300519.bin...OK
Writing 18/107 system_301022.bin...OK
Writing 19/107 system_333437.bin...OK
Writing 20/107 system_366055.bin...OK
Writing 21/107 system_366558.bin...OK
Writing 22/107 system_398973.bin...OK
Writing 23/107 system_431741.bin...OK
Writing 24/107 system_464006.bin...OK
Writing 25/107 system_464509.bin...OK
Writing 26/107 system_496774.bin...OK
Writing 27/107 system_497277.bin...OK
Writing 28/107 system_529542.bin...OK
Writing 29/107 system_530045.bin...OK
Writing 30/107 system_562813.bin...OK
Writing 31/107 system_595581.bin...OK
Writing 32/107 system_628349.bin...OK
Writing 33/107 system_661117.bin...OK
Writing 34/107 system_693885.bin...OK
Writing 35/107 system_726653.bin...OK
Writing 36/107 system_759421.bin...OK
Writing 37/107 system_792189.bin...OK
Writing 38/107 system_824957.bin...OK
Writing 39/107 system_857725.bin...OK
Writing 40/107 system_890343.bin...OK
Writing 41/107 system_890846.bin...OK
Writing 42/107 system_923261.bin...OK
Writing 43/107 system_955879.bin...OK
Writing 44/107 system_956382.bin...OK
Writing 45/107 system_988797.bin...OK
Writing 46/107 system_1021565.bin...OK
Writing 47/107 system_1054333.bin...OK
Writing 48/107 system_1087101.bin...OK
Writing 49/107 system_1119869.bin...OK
Writing 50/107 system_1152637.bin...OK
Writing 51/107 system_1185405.bin...OK
Writing 52/107 system_1218173.bin...OK
Writing 53/107 system_1250941.bin...OK
Writing 54/107 system_1283709.bin...OK
Writing 55/107 system_1316477.bin...OK
Writing 56/107 system_1349245.bin...OK
Writing 57/107 system_1382013.bin...OK
Writing 58/107 system_1414781.bin...OK
Writing 59/107 system_1447549.bin...OK
Writing 60/107 system_1480007.bin...OK
Writing 61/107 BackupGPT_7728123.bin...OK
Writing 62/107 PrimaryGPT_0.bin...OK
Writing 63/107 xbl_6.bin...OK
Writing 64/107 xblbak_774.bin...OK
Writing 65/107 BackupGPT_8187.bin...OK
Writing 66/107 PrimaryGPT_0.bin...OK
Writing 67/107 xbl2_6.bin...OK
Writing 68/107 xbl2bak_774.bin...OK
Writing 69/107 BackupGPT_2043.bin...OK
Writing 70/107 PrimaryGPT_0.bin...OK
Writing 71/107 BackupGPT_2043.bin...OK
Writing 72/107 PrimaryGPT_0.bin...OK
Writing 73/107 boot_6.bin...OK
Writing 74/107 recovery_10246.bin...OK
Writing 75/107 recoverybak_20614.bin...OK
Writing 76/107 tz_30982.bin...OK
Writing 77/107 tzbak_31494.bin...OK
Writing 78/107 aboot_32006.bin...OK
Writing 79/107 abootbak_32518.bin...OK
Writing 80/107 raw_resources_33030.bin...OK
Writing 81/107 raw_resourcesbak_34054.bin...OK
Writing 82/107 rpm_35078.bin...OK
Writing 83/107 rpmbak_35206.bin...OK
Writing 84/107 hyp_35334.bin...OK
Writing 85/107 hypbak_35462.bin...OK
Writing 86/107 pmic_35590.bin...OK
Writing 87/107 pmicbak_35718.bin...OK
Writing 88/107 devcfg_35846.bin...OK
Writing 89/107 devcfgbak_35878.bin...OK
Writing 90/107 modem_35910.bin...OK
Writing 91/107 sec_57926.bin...OK
Writing 92/107 keymaster_58054.bin...OK
Writing 93/107 keymasterbak_58182.bin...OK
Writing 94/107 cmnlib_58310.bin...OK
Writing 95/107 cmnlibbak_58438.bin...OK
Writing 96/107 cmnlib64_58566.bin...OK
Writing 97/107 cmnlib64bak_58694.bin...OK
Writing 98/107 apdp_58822.bin...OK
Writing 99/107 msadp_58950.bin...OK
Writing 100/107 BackupGPT_59387.bin...OK
Writing 101/107 PrimaryGPT_0.bin...OK
Writing 102/107 BackupGPT_2043.bin...OK
Writing 103/107 PrimaryGPT_0.bin...OK
Writing 104/107 BackupGPT_2043.bin...OK
Writing 105/107 0_OP_OPEN_AME_DS.img...OK
Writing 106/107 1_OP_OPEN_AME_DS.img...OK
Writing 107/107 2_OP_OPEN_AME_DS.img...OK
Formating RCT...OK
Formating MPT...OK
Finalizing...OK
Writing firmware done!
Performed by 2.7.9 Software version.
Please select Reset FRP Method!
Checking data...OK
Please, put the phone into download mode manually (Power phone OFF,
press and hold "Vol+" button and connect the cable).
Reading info...
Model ID: LG-H870S
Battery level: 66%
SW Version: H87010f
Mode: Normal
Switching to Download mode...OK
Resetting FRP Lock...
Resetting FRP lock successfully completed!
