03-10-2018, 13:52 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | LG G6 (H870DS) Reset FRP question [Answered] tp methrd or normal tell me pls Last edited by Octopus box; 03-20-2018 at 14:01. |
03-10-2018, 13:57 | #3 (permalink) |
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | Welcome to Octoplus/Octopus Box LG Software version 2.8.0 Please select Reset FRP Method! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM282 Selected model: H870DS Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... Model ID: LG-H870DS IMEI: 356145-08-107227-7 Android version: 7.0 Battery level: 33% SW Version: H87010u Mode: Emergency Initializing flash...OK SW version: LGH870DSAT-00-V10u-IND-XX-JAN-24-2018+0 Android version: 7.0 LAF Version: 1.1 Product ID: HD58S170418002358 IMEI: 356145-08-107227-7 Target operator: GLOBAL Hardware: rev_10 Reading partitions...OK Resetting FRP Lock...Failed! LAF Error: 0F0F0F0F. Reset FRP operation is currently not supported for your phone's firmware. Performed by 2.8.0 Software version. where to get testpoint |
03-10-2018, 14:00 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Quote:
03-10-2018, 15:37 | #5 (permalink) | |
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | Quote:
03-10-2018, 16:01 | #6 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | @umarmsn Quote:
1. Attach testpoint as shown on H870 TP, and connect phone with Micro USB cable (donīt use USB hubs!). 2. Check PC Device Manager, a new device should appear "Qualcomm HS-USB QDLoader 9008" or "Unknown Device" if you hadnīt installed a driver. Drivers are in {Installation_Folder}\Driver\QHSUSB. 3. Release testpoint and press "Reset FRP Lock" button. 4. Click "Reset FRP via TP (Qualcomm Mode)" button; 5. Follow software instructions (prompts). | |
03-11-2018, 10:51 | #7 (permalink) | |
03-20-2018, 13:55 | #9 (permalink) |
Junior Member Join Date: Aug 2016
Member: 2617518 Status: Offline Thanks Meter: 2 | done Performed by 2.8.0 Software version awesome thx Welcome to Octoplus/Octopus Box LG Software version 2.8.0 Please select Reset FRP Method! To perform Reset FRP operation do the next: 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS- USB QDLoader 9008". 3. Release testpoint. Found port COM11 Connecting...OK Sending loader...OK Reconnecting phone...OK Checking request... Request has been successfully sent! Obtaining response...OK Reading partitions...OK Searching signatures... Step 1... Step 2... Step 3... Resetting FRP Lock... Rebooting phone... . |
The Following User Says Thank You to avatar2112 For This Useful Post: |
