11-20-2018, 22:38 | #1 (permalink) |
Freak Poster Join Date: Mar 2017
Member: 2693973 Status: Offline Thanks Meter: 10 | H870 reset FRP question [Solved] Welcome to Octoplus/Octopus Box LG Software version 2.8.7 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM86 Selected model: H870 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... Model ID: LG-H870 IMEI: 356144-08-842880-6 Android version: 8.0.0 Battery level: 90% SW Version: H87020c Mode: Emergency Initializing flash...OK SW version: LGH870AT-00-V20c-EUR-XX-AUG-17-2018+0 Android version: 8.0.0 LAF Version: 1.1 Product ID: SM07S171025002611 IMEI: 356144-08-842880-6 Target operator: GLOBAL Hardware: rev_10 Reset FRP operation is currently not supported for your phone's firmware. Performed by 2.8.7 Software version. Last edited by Octopus box; 11-29-2018 at 05:51. |
11-21-2018, 06:25 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please install the latest Software version from the Support Area (here is direct link for You: https://drive.google.com/open?id=1nX...Gxit3LxMnxwdr-) and repeat the operation. Post here the result. |
11-21-2018, 07:43 | #3 (permalink) |
Member: 2693973 Status: Offline Thanks Meter: 10 | here is the opération log after install laest setup for octoplus lg whzt i don i continued or it rsik Welcome to Octoplus/Octopus Box LG Software version 2.8.9.8 Please select Reset FRP Method! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM86 Selected model: H870 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... Model ID: LG-H870 IMEI: 356144-08-842880-6 Android version: 8.0.0 Battery level: 82% SW Version: H87020c Mode: Emergency Initializing flash...OK Platform: msm8996 SW version: LGH870AT-00-V20c-EUR-XX-AUG-17-2018+0 Android version: 8.0.0 LAF Version: 1.1 Product ID: SM07S171025002611 IMEI: 356144-0*********** Target operator: GLOBAL Hardware: rev_10 Reading partitions...OK Reading BOOT... ID: 0005F0E100310000 Operation is not safe and exist risk to damage the device! Do You want to continue? Canceled! Performed by 2.8.9.8 Software version. Last edited by fatistar; 11-21-2018 at 07:48. |
11-21-2018, 07:51 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Disconnect all devices from PC, connect your device directly to PC motherboard USB port (don't use USB hubs) and perform "Reset FRP" operation without doubts. |
11-21-2018, 07:56 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Exist risk, but easy to repair by writing backup, which will be created by Software before performing the operation. |
11-21-2018, 08:17 | #9 (permalink) |
Member: 2693973 Status: Offline Thanks Meter: 10 | pleas it dont connect to qualquom usb driver i need this driver for install Qualcomm USB Driver Welcome to Octoplus/Octopus Box LG Software version 2.8.9.8 Please select Reset FRP Method! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM86 Selected model: H870 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... Model ID: LG-H870 IMEI: 356144-08-842880-6 Android version: 8.0.0 Battery level: 82% SW Version: H87020c Mode: Emergency Initializing flash...OK Platform: msm8996 SW version: LGH870AT-00-V20c-EUR-XX-AUG-17-2018+0 Android version: 8.0.0 LAF Version: 1.1 Product ID: SM07S171025002611 IMEI: 356144-08-842880-6 Target operator: GLOBAL Hardware: rev_10 Reading partitions...OK Reading BOOT... ID: 0005F0E100310000 Operation is not safe and exist risk to damage the device! Do You want to continue? Canceled! Performed by 2.8.9.8 Software version. Please select Reset FRP Method! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM86 Selected model: H870 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... Model ID: LG-H870 IMEI: 356144-08-842880-6 Android version: 8.0.0 Battery level: 82% SW Version: H87020c Mode: Emergency Initializing flash...OK Platform: msm8996 SW version: LGH870AT-00-V20c-EUR-XX-AUG-17-2018+0 Android version: 8.0.0 LAF Version: 1.1 Product ID: SM07S171025002611 IMEI: 356144-08-842880-6 Target operator: GLOBAL Hardware: rev_10 Reading partitions...OK Reading BOOT... ID: 0005F0E100310000 Operation is not safe and exist risk to damage the device! Do You want to continue?OK Backup saved to "H870_356144088428806_21-11-2018_08-08-04.oct" Switching to Qualcomm 9008 mode... "Qualcomm HS-USB QDLoader 9008" device not found. Please, don't disconnect cable, this can damage your device! Install "Qualcomm USB Driver" and press "Continue" button "Qualcomm HS-USB QDLoader 9008" device not found. Please, don't disconnect cable, this can damage your device! Install "Qualcomm USB Driver" and press "Continue" button "Qualcomm HS-USB QDLoader 9008" device not found. Please, don't disconnect cable, this can damage your device! Install "Qualcomm USB Driver" and press "Continue" button |
11-21-2018, 08:36 | #11 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Quote:
To repair your device and do "Reset FRP" do the following: 1. Select LG H790 in the list of Software. 2. Select backup file "H870_356144088428806_21-11-2018_08-08-04.oct" into the Firmware slot in Software. 3. Press "Reset FRP via TP (Qualcomm Mode)" button in Software, install Qualcomm HSHUSB driver and write backup file. 4. Post here the result. Then perform "Reset FRP" operation again. | |
11-21-2018, 09:45 | #14 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Most likely, You have installed incorrect driver. Please make screenshot of Windows Device Manager (Port section) with device, that appears in there, when You connect phone to PC, and post here, we will check. |
