10-17-2018, 17:05 | #1 (permalink) |
Freak Poster Join Date: May 2010
Member: 1305804 Status: Offline Thanks Meter: 22 | LG G6 in Qualcomm mode [Solved] now driver manager show me only qloader 9008 i need file xxxxxxx.oct for h873 to unbrick it. Thank you Last edited by Octopus box; 10-18-2018 at 18:38. |
10-18-2018, 05:23 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Quote:
10-18-2018, 15:08 | #3 (permalink) |
Member: 1305804 Status: Offline Thanks Meter: 22 | THANK YOU FOR REPLY. I BIELIVE IT S BRICKED AND I NEED TO UNBRICKE IT. HERE LOG FILE Reconnecting phone...OK Checking request... Request has been successfully sent! Obtaining response...OK Reading partitions...OK Searching signatures... Step 1... Step 2... Step 3... Step 4... Step 5... Error code: ASDQKEASDA Rebooting phone... Performed by 2.8.9 Software version. |
10-18-2018, 15:28 | #5 (permalink) |
Member: 1305804 Status: Offline Thanks Meter: 22 | HERE FULL LOG FILE: Welcome to Octoplus/Octopus Box LG Software version 2.8.9 Please select Reset FRP Method! To perform Reset FRP operation do the next: 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS- USB QDLoader 9008". 3. Release testpoint. Found port COM180 Connecting...OK Sending loader...OK Reconnecting phone...OK Checking request... Request has been successfully sent! Obtaining response...OK Reading partitions...OK Searching signatures... Step 1... Step 2... Step 3... Step 4... Step 5... Error code: ASDQKEASDA Rebooting phone... Performed by 2.8.9 Software version. |
10-18-2018, 15:38 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | It is not possible to damage boot with this operation via Test Point. Or maybe You have posted not the first log. Please post the first Software log with this device info. |
10-18-2018, 15:47 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Anyway, to repair the device install the latest test Software version v2.8.9.3 from the Support Area and do the following: 1. Select LG H873 in the list of Software. 2. Select this backup file (https://drive.google.com/open?id=1T3...m88v_ZZ3GXWsvn) into the Firmware slot in Software. 3. Press "Reset FRP via TP (Qualcomm Mode)" button in Software and write backup file. 4. Post here the result. |
10-18-2018, 16:03 | #9 (permalink) |
Member: 1305804 Status: Offline Thanks Meter: 22 | THANK YOU, HERE LOG FILE, THE PHONE STILL NOT OPENING. Welcome to Octoplus/Octopus Box LG Software version 2.8.9 Please select Reset FRP Method! Opening "LG_H873_V20.oct"... Restore device from backup file? Please, connect the phone... Found port COM180 Connecting...Failed! Performed by 2.8.9 Software version. Please select Reset FRP Method! Opening "LG_H873_V20.oct"... Restore device from backup file? Please, connect the phone... Found port COM180 Connecting...OK Sending loader...OK Reconnecting phone...OK Checking request... Request has been successfully sent! Obtaining response...OK Reading partitions...OK Rebooting phone... Performed by 2.8.9 Software version. |
10-18-2018, 18:28 | #13 (permalink) |
Member: 1305804 Status: Offline Thanks Meter: 22 | MIRACLE HAPPENE THE PHONE IS ON!!! THANK YOU A LOT HERE LOG: Please select Reset FRP Method! Opening "LG_H873_V20.oct"... Restore device from backup file? Please, connect the phone... Found port COM180 Connecting...OK Sending loader...OK Reconnecting phone...OK Checking request... Request has been successfully sent! Obtaining response...OK Reading partitions...OK Restoring BOOT...OK Rebooting phone... Performed by 2.8.9.2 Software version. |
10-19-2018, 05:18 | #15 (permalink) | |
No Life Poster Join Date: Aug 2005 Location: Canada Age: 44
Member: 169896 Status: Offline Thanks Meter: 323 | Quote:
Sent from my SM-G965W using Tapatalk | |
The Following User Says Thank You to ashahzad_pk For This Useful Post: |
