08-27-2014, 09:58 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | What is the problem exactly? Explain the problem in more details, describe all of your actions step by step and post here full Software log with all of these actions. |
08-27-2014, 10:28 | #3 (permalink) |
Freak Poster Join Date: Apr 2011 Location: Bangladesh Age: 34
Member: 1547481 Status: Offline Thanks Meter: 27 | Try to Flash, Update Firmware GT540AT-00-V20e-BAL-XXX-MAR-22-2011 But, some section write then error, Now Condition only logo hang.. Try to GT540AT-00-V10d-BAL-XXX-MAY-17-2010 But, Error! |
08-27-2014, 10:38 | #4 (permalink) |
Member: 1547481 Status: Offline Thanks Meter: 27 | Welcome to Octoplus/Octopus Box LG Software version 1.4.7 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM3 Selected model: GT540 Phone not detected. Please try again. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM1 Selected model: GT540 Phone not detected. Please try again. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM1 Selected model: GT540 Phone not detected. Please try again. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM1 Selected model: GT540 Phone not detected. Please try again. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM4 Selected model: GT540 Phone model: GT540 Mode: Emergency Software Log! Opening "GT540AT-00-V20e-BAL-XXX-MAR-22-2011.oct"...OK Writing Firmware... Checking partition...OK Write BootLoaders: Yes Writing QCSBL...Failed! |
08-27-2014, 10:39 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Have You written firmware with phone's boot loaders or without? Post here full Software log with all of your actions. |
08-27-2014, 10:45 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | To write firmware, do the next: 1. Disconnect the cable, reconnect the battery, manually put phone into emergency mode (press and hold "Vol+"+"Vol-"+"Power" and connect the cable). It is very IMPORTANT to put the phone into Emergency mode MANUALLY! 2. Select "Write boot loaders" option in the Software and write V20X firmware firmware from the support area. 3. Post here full (not cut) Software log with all of your actions. Note: if there will occurs an error during process of writing firmware, You mandatory should reconnect the battery and put the phone into Emergency Mode manually and repeat the procedure of writing firmware again! Otherwise, phone's boot can be damage! Please uninstall all BB software, modem dashboard software and PC Suite software. Also please don't use USB hubs or PCI USB ports, You need to use motherboard USB ports only! Make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! Please, follow these simple precautions to avoid damaging your phone. |
