Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus LG/Octoplus LG
Old 06-16-2012, 00:39   #1 (permalink)
Member: 333519
Sonork: 100.1620327
Lg gt540 big problem [Solved]
PLEASE my lg gt540 when i try to write flash the soft shows writing amms error, i tried everything in diferents pcs i repaired the boot with medusa and with riff but i cant flash the phone im sure is not hardware problem.
i tried with differents cables, new drivers all but no solution i need help
Old 06-16-2012, 08:57   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Hello.
Writing AMSS...Failed!
Such error arise if your PC is very "dirtied" by different software and drivers. Please, clean your PC - uninstall all modem dashboard software, PC suite software, BB software. The best way is to use totally cleaned PC (only OS installed and drivers). Also please try to connect the phone via different USB ports.
To resurrect your phone please perform the next operations:
1. Repair phone boot using Medusa Box. Post here software log of Repair procedure. Then You MANDATORY need to do the next:
2. Disconnect the cable, reconnect the battery, manually put phone into emergency mode (press and hold "Vol+"+"Vol-"+"Power" and connect the cable). It is very IMPORTANT to put the phone into Emergency mode MANUALLY!
3. Then You need to select "Write boot loaders" option and write V20X firmware firmware from the support area.
4. If the error occurs during writing (AMSS or another part of firmware), YOU MANDATORY NEED to disconnect the cable, reconnect the battery, MANUALLY put phone into emergency mode (press and hold "Vol+"+"Vol-"+"Power"), connect the cable and repeat the procedure of firmware writing. Also it is very IMPORTANT to put the phone into Emergency mode MANUALLY!
Also, after Write firmware, don't forget to make Repair security, Repair IMEI, Unlock and then make Repair NVM.
The Following User Says Thank You to Octopus box For This Useful Post:
Old 06-16-2012, 19:28   #3 (permalink)
Member: 333519
Sonork: 100.1620327
thanks
problem solved with medusa thanks
The Following User Says Thank You to julipsike For This Useful Post:
Sim card sleep mode problem with 6130 ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 05-22-2012 11:13
GId1 problem old_man Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 10-18-2006 15:21
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 09-11-1999 17:39
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 07-16-1999 00:44
Really big favour! MiMiR the WiseMan Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 06-18-1999 03:21
Page generated in 0.31055 seconds with 11 queries
