07-25-2018, 15:50 | #1 (permalink) |
No Life Poster Join Date: May 2013 Location: Far From Home..:(
Member: 1948608 Status: Offline Thanks Meter: 1,744 | LG-H635 LG G4 Stylus succesfully Flash Done -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM711 Selected model: H635 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-H635 IMEI: 352431-07-126948-5 Android version: 5.0.2 Battery level: 52% SW Version: H63510b Mode: Emergency Initializing flash...OK SW version: LGH635AT-00-V20a-ZAF-XX-FEB-23-2016+0 Android version: 6.0 LAF Version: 1.1 Product ID: CY16S151027001660 IMEI: 352431-07-126948-5 Target operator: GLOBAL Hardware: rev_10 Reading partitions...OK Resetting FRP Lock... Resetting FRP lock successfully completed! Performed by 2.8.0 Software version. Connecting to server support.octoplusbox.com:82...OK Authorizing...OK -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM711 Selected model: H635 Reading info... Model ID: LG-H635 IMEI: 352431-07-126948-5 Android version: 6.0 Battery level: 55% SW Version: H63520a Mode: Emergency Initializing flash...OK SW version: LGH635AT-00-V20a-ZAF-XX-FEB-23-2016+0 Android version: 6.0 LAF Version: 1.1 Product ID: CY16S151027001660 IMEI: 352431-07-126948-5 Target operator: GLOBAL Hardware: rev_10 Opening "H63520b_00_0720.kdz"...OK Firmware version: H63520b Firmware model: LG-H635 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Prepairing firmware...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing 1/46 PrimaryGPT_0.bin...OK Writing 2/46 sbl1_1024.bin...OK Writing 3/46 tz_2048.bin...OK Writing 4/46 hyp_3072.bin...OK Writing 5/46 rpm_4096.bin...OK Writing 6/46 aboot_5120.bin...OK Writing 7/46 sbl1bak_12288.bin...OK Writing 8/46 tzbak_13312.bin...OK Writing 9/46 hypbak_14336.bin...OK Writing 10/46 rpmbak_15360.bin...OK Writing 11/46 abootbak_16384.bin...OK Writing 12/46 persist_53248.bin...OK Writing 13/46 laf_93184.bin...OK Writing 14/46 boot_142336.bin...OK Writing 15/46 recovery_191488.bin...OK Writing 17/46 cust_279552.bin...OK Writing 18/46 factory_484352.bin...OK Writing 19/46 modem_697344.bin...OK Writing 20/46 system_828416.bin...OK Writing 21/46 system_1091848.bin...OK Writing 22/46 system_1095800.bin...OK Writing 23/46 system_1356656.bin...OK Writing 24/46 system_1616136.bin...OK Writing 25/46 system_1620088.bin...OK Writing 26/46 system_1880944.bin...OK Writing 27/46 system_2140424.bin...OK Writing 28/46 system_2144376.bin...OK Writing 29/46 system_2405232.bin...OK Writing 30/46 system_2664712.bin...OK Writing 31/46 system_2668664.bin...OK Writing 32/46 system_2929520.bin...OK Writing 33/46 system_3189000.bin...OK Writing 34/46 system_3192952.bin...OK Writing 35/46 system_3453808.bin...OK Writing 36/46 system_3715952.bin...OK Writing 37/46 system_3978096.bin...OK Writing 38/46 system_4240240.bin...OK Writing 39/46 system_4502384.bin...OK Writing 40/46 system_4764528.bin...OK Writing 41/46 system_5026672.bin...OK Writing 42/46 system_5288816.bin...OK Writing 43/46 system_5550960.bin...OK Writing 44/46 system_5809152.bin...OK Writing 45/46 system_5812416.bin...OK Writing 46/46 BackupGPT_15268864.bin...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.8.0 Software version. |
The Following User Says Thank You to -Mosin- For This Useful Post: |
05-26-2019, 11:12 | #2 (permalink) |
Freak Poster Join Date: Jun 2013 Location: south Africa
Member: 1960717 Status: Offline Sonork: 100.1638403 Thanks Meter: 34 | Welcome to Octoplus/Octopus Box LG Software version 2.8.9.8 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM3 Selected model: H635 Reading info...Failed! Port busy Performed by 2.8.9.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM3 Selected model: H635 Reading info...Failed! Port busy Performed by 2.8.9.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM200 Selected model: H635 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-H635 IMEI: 352431-07-106427-4 Android version: 5.0.2 Battery level: 84% SW Version: H63510b Mode: Emergency Initializing flash...OK Platform: msm8916 SW version: LGH635AT-00-V10f-GLOBAL-COM-JUN-30-2015+0 Android version: 5.0.2 LAF Version: 1.1 Product ID: CY13S151010000057 IMEI: 352431-07-106427-4 Target operator: GLOBAL Hardware: rev_10 Reading partitions...OK Detecting writing method...OK Resetting FRP Lock... Resetting FRP lock successfully completed! Performed by 2.8.9.8 Software version. |
The Following User Says Thank You to ali_GSM98 For This Useful Post: |
