10-03-2016, 13:04 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. For which operation exactly You need root your device? Unfortunately root files for this phone isn't available at the Support Area. |
10-03-2016, 13:31 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | According to the Software manual, You don't need to root your phone. Repair IMEI 1.Remove SD and SIM cards from the phone; 2.Connect powered-on phone to PC with Micro USB cable; 3.Install necessary driver; 4.Enter correct IMEI; 5.Click "IMEI fix" button; 6.Follow software instructions (prompts). Note: To connect the phone in Normal Mode, do one of the following: Enable "USB Debugging" mode; Type 277634#*#, go to "Port Check Test" (or "SVC Menu -> Port Check Test") and switch "Port Check Test" to "Enabled". |
