06-02-2016, 16:47 | #1 (permalink) |
Freak Poster Join Date: Feb 2008
Member: 714642 Status: Offline Thanks Meter: 16 | lg h791 imei repair problem [Solved] Checking data...OK Platform: LG Qualcomm Selected port: COM5 Selected model: H791 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5X Firmware version: Kernel version: 3.10.73-g8eaa82a (android- [email protected]) (gcc version 4.9.x-google 20140827 (prerelease) (GCC) ) #1 SMP PREEMPT Sat Mar 26 01:36:22 UTC 201 Android version: 6.0.1 Hardware: Qualcomm Technologies, Inc MSM8992 AArch64 Processor rev 3 (aarch64) Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is not rooted. Sending exploit...OK Switching to Fastboot mode...OK Unlocking Bootloader... Bootloader is unlocked. Writing Recovery...OK To Root the phone, please perform the following steps: 1. Select "Recovery mode" (use Vol+, Vol-), then boot into "Recovery" (press "Power" button); 2. Press "Install" and go into "Octo_Root" folder in the phone; 3. Select "supersu.zip" and press "Add more zips"; 4. Select "busybox.zip" and press "Add more zips"; 5. Select "quick-reboot.zip" then swipe to confirm flash; 6. Press "Reboot System"; 7. Please, wait while the phone will turn on and press "OK" button. Last edited by Octopus box; 06-04-2016 at 13:44. |
06-03-2016, 14:28 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please, try to root the phone with nexus root tool kit, then repeat Repair IMEI operation again. Last edited by Octopus box; 06-04-2016 at 13:44. |
07-02-2016, 10:19 | #7 (permalink) |
Freak Poster Join Date: Mar 2008 Location: TURKEY ADANA Age: 36
Member: 724562 Status: Offline Thanks Meter: 217 | Welcome to Octoplus/Octopus Box LG Software version 2.3.3 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM307 Selected model: H791 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5X Firmware version: Kernel version: 3.10.73-gc28506a (android- [email protected]) (gcc version 4.9.x-google 20140827 (prerelease) (GCC) ) #1 SMP PREEMPT Thu Apr 14 22:40:19 UTC 201 Android version: 6.0.1 Hardware: Qualcomm Technologies, Inc MSM8992 AArch64 Processor rev 3 (aarch64) Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is not rooted. Sending exploit...OK Switching to Fastboot mode...OK Unlocking Bootloader... Bootloader is unlocked. Writing Recovery...OK To Root the phone, please perform the following steps: 1. Select "Recovery mode" (use Vol+, Vol-), then boot into "Recovery" (press "Power" button); 2. Press "Install" and go into "Octo_Root" folder in the phone; 3. Select "supersu.zip" and press "Add more zips"; 4. Select "busybox.zip" and press "Add more zips"; 5. Select "quick-reboot.zip" then swipe to confirm flash; 6. Press "Reboot System"; 7. Please, wait while the phone will turn on and press "OK" button. Press "Grant" button on the phone every time when superuser dialog appears Checking root access... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Enable "Settings" -> "Developer options" -> "OEM unlocking" option 7. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.OKFailed! Error code: ADB0000001 Performed by 2.3.3 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM307 Selected model: H791 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Incompatible model ID! Please, select correct model! Performed by 2.3.3 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM307 Selected model: H791 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5X Firmware version: Kernel version: 3.10.73-gc28506a (android- [email protected]) (gcc version 4.9.x-google 20140827 (prerelease) (GCC) ) #1 SMP PREEMPT Thu Apr 14 22:40:19 UTC 201 Android version: 6.0.1 Hardware: Qualcomm Technologies, Inc MSM8992 AArch64 Processor rev 3 (aarch64) Checking root access... Phone is not rooted. Sending exploit...OK Switching to Fastboot mode...OK Unlocking Bootloader... Bootloader is unlocked. Writing Recovery...OK To Root the phone, please perform the following steps: 1. Select "Recovery mode" (use Vol+, Vol-), then boot into "Recovery" (press "Power" button); 2. Press "Install" and go into "Octo_Root" folder in the phone; 3. Select "supersu.zip" and press "Add more zips"; 4. Select "busybox.zip" and press "Add more zips"; 5. Select "quick-reboot.zip" then swipe to confirm flash; 6. Press "Reboot System"; 7. Please, wait while the phone will turn on and press "OK" button. Failed! Performed by 2.3.3 software version. |
07-02-2016, 10:19 | #8 (permalink) |
07-02-2016, 10:20 | #9 (permalink) |
Member: 724562 Status: Offline Thanks Meter: 217 | Welcome to Octoplus/Octopus Box LG Software version 2.3.3 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM307 Selected model: H791 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5X Firmware version: Kernel version: 3.10.73-gc28506a (android- [email protected]) (gcc version 4.9.x-google 20140827 (prerelease) (GCC) ) #1 SMP PREEMPT Thu Apr 14 22:40:19 UTC 201 Android version: 6.0.1 Hardware: Qualcomm Technologies, Inc MSM8992 AArch64 Processor rev 3 (aarch64) Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is not rooted. Sending exploit...OK Switching to Fastboot mode...OK Unlocking Bootloader... Bootloader is unlocked. Writing Recovery...OK To Root the phone, please perform the following steps: 1. Select "Recovery mode" (use Vol+, Vol-), then boot into "Recovery" (press "Power" button); 2. Press "Install" and go into "Octo_Root" folder in the phone; 3. Select "supersu.zip" and press "Add more zips"; 4. Select "busybox.zip" and press "Add more zips"; 5. Select "quick-reboot.zip" then swipe to confirm flash; 6. Press "Reboot System"; 7. Please, wait while the phone will turn on and press "OK" button. Press "Grant" button on the phone every time when superuser dialog appears Checking root access... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Enable "Settings" -> "Developer options" -> "OEM unlocking" option 7. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.OKFailed! Error code: ADB0000001 Performed by 2.3.3 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM307 Selected model: H791 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Incompatible model ID! Please, select correct model! Performed by 2.3.3 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM307 Selected model: H791 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5X Firmware version: Kernel version: 3.10.73-gc28506a (android- [email protected]) (gcc version 4.9.x-google 20140827 (prerelease) (GCC) ) #1 SMP PREEMPT Thu Apr 14 22:40:19 UTC 201 Android version: 6.0.1 Hardware: Qualcomm Technologies, Inc MSM8992 AArch64 Processor rev 3 (aarch64) Checking root access... Phone is not rooted. Sending exploit...OK Switching to Fastboot mode...OK Unlocking Bootloader... Bootloader is unlocked. Writing Recovery...OK To Root the phone, please perform the following steps: 1. Select "Recovery mode" (use Vol+, Vol-), then boot into "Recovery" (press "Power" button); 2. Press "Install" and go into "Octo_Root" folder in the phone; 3. Select "supersu.zip" and press "Add more zips"; 4. Select "busybox.zip" and press "Add more zips"; 5. Select "quick-reboot.zip" then swipe to confirm flash; 6. Press "Reboot System"; 7. Please, wait while the phone will turn on and press "OK" button. Failed! Performed by 2.3.3 software version. Last edited by looupss; 07-02-2016 at 10:27. |
01-10-2017, 08:53 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | You can try to root your device with Nexus Root Toolkit or any other root method, which You can find at your own risk. |
10-21-2018, 09:04 | #12 (permalink) |
Crazy Poster Join Date: Mar 2016 Location: 1205,motalab plaza dhaka.
Member: 2543177 Status: Offline Thanks Meter: 18 | Welcome to Octoplus/Octopus Box LG Software version 2.8.9 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Analog Devices Selected port: COM1 Selected baudrate: 921600 Selected model: A7100 Please reconnect battery... Disconnected. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM1 Selected model: H791 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5X Phone firmware version: Kernel version: 3.10.73-g76d746e (android- [email protected]) (gcc version 4.9.x-google 20140827 (prerelease) (GCC) ) #1 SMP PREEMPT Wed Aug 31 19:49:49 UTC 201 Android version: 7.0 Hardware: Qualcomm Technologies, Inc MSM8992 AArch64 Processor rev 3 (aarch64) Performed by 2.8.9 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM1 Selected model: H791 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5X Phone firmware version: Kernel version: 3.10.73-g76d746e (android- [email protected]) (gcc version 4.9.x-google 20140827 (prerelease) (GCC) ) #1 SMP PREEMPT Wed Aug 31 19:49:49 UTC 201 Android version: 7.0 Hardware: Qualcomm Technologies, Inc MSM8992 AArch64 Processor rev 3 (aarch64) Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is not rooted. Sending exploit...OK Switching to Fastboot mode...OK Unlocking Bootloader... Select "Yes" on phone screen and press "Power" button. Please perform the following steps: 1. Wait while the phone will turn on 2. Reboot the phone 3. Enable "USB debugging" Mode 4. Connect the cable and check, whether ADB interface has appeared in PC Device Manager 5. Press "Ok" button. Initializing ADB...OK Waiting for phone...OK Switching to Fastboot mode...OK Bootloader is unlocked. Writing Recovery...OK To Root the phone, please perform the following steps: 1. Select "Recovery mode" (use Vol+, Vol-), then boot into "Recovery" (press "Power" button); 2. Press "Install" and go into "Octo_Root" folder in the phone; 3. Select "supersu.zip" and press "Add more zips"; 4. Select "busybox.zip" and press "Add more zips"; 5. Select "quick-reboot.zip" then swipe to confirm flash; 6. Press "Reboot System"; 7. Please, wait while the phone will turn on and press "OK" button. Press "Grant" button on the phone every time when superuser dialog appears Checking root access... Initializing ADB...OK Waiting for phone...OKFailed! Error code: ADB0000001 Performed by 2.8.9 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM1 Selected model: H791 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5X Phone firmware version: Kernel version: 3.10.73-g76d746e (android- [email protected]) (gcc version 4.9.x-google 20140827 (prerelease) (GCC) ) #1 SMP PREEMPT Wed Aug 31 19:49:49 UTC 201 Android version: 7.0 Hardware: Qualcomm Technologies, Inc MSM8992 AArch64 Processor rev 3 (aarch64) Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is not rooted. Sending exploit...OK Switching to Fastboot mode...OK Unlocking Bootloader... Bootloader is unlocked. Writing Recovery...OK To Root the phone, please perform the following steps: 1. Select "Recovery mode" (use Vol+, Vol-), then boot into "Recovery" (press "Power" button); 2. Press "Install" and go into "Octo_Root" folder in the phone; 3. Select "supersu.zip" and press "Add more zips"; 4. Select "busybox.zip" and press "Add more zips"; 5. Select "quick-reboot.zip" then swipe to confirm flash; 6. Press "Reboot System"; 7. Please, wait while the phone will turn on and press "OK" button. Press "Grant" button on the phone every time when superuser dialog appears Checking root access... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Enable "Settings" -> "Developer options" -> "OEM unlocking" option 7. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.OK Phone is not rooted. Root access garanted! Diagnostics ports are enbled! Switching to Serial Port... Failed! Performed by 2.8.9 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM1 Selected model: H791 Reading info...Failed! Could not detect mode! Performed by 2.8.9 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM1 Selected model: H791 Reading info...Failed! Could not detect mode! Performed by 2.8.9 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM1 Selected model: H791 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5X Phone firmware version: Kernel version: 3.10.73-g76d746e (android- [email protected]) (gcc version 4.9.x-google 20140827 (prerelease) (GCC) ) #1 SMP PREEMPT Wed Aug 31 19:49:49 UTC 201 Android version: 7.0 Hardware: Qualcomm Technologies, Inc MSM8992 AArch64 Processor rev 3 (aarch64) Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is not rooted. Sending exploit...OK Switching to Fastboot mode...OK Unlocking Bootloader... Bootloader is unlocked. Writing Recovery...OK To Root the phone, please perform the following steps: 1. Select "Recovery mode" (use Vol+, Vol-), then boot into "Recovery" (press "Power" button); 2. Press "Install" and go into "Octo_Root" folder in the phone; 3. Select "supersu.zip" and press "Add more zips"; 4. Select "busybox.zip" and press "Add more zips"; 5. Select "quick-reboot.zip" then swipe to confirm flash; 6. Press "Reboot System"; 7. Please, wait while the phone will turn on and press "OK" button. Press "Grant" button on the phone every time when superuser dialog appears Checking root access... Initializing ADB...OK Waiting for phone...OK Phone is not rooted. Root access garanted! Diagnostics ports are enbled! Switching to Serial Port... Found model FAAAANAZ*ÿš i at port COM122 Reading info... Mode: Normal Firmware compiled date: Jun 25 2016 Firmware compiled time: 10:00:00 Firmware released date: Jul 7 2016 Firmware released time: 08:46:36 SW Version: M8994F-2.6.33.2.14 SPC: 000000 Fixing IMEI... New IMEI: 387858-78-878788-9 Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "H791_Bad_21-10-2018_13-46-32.qcn" Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Reading security area...OK Backup saved to "H791_Bad_21-10-2018_13-54-37.SEC" Writing security area...OK Switching to Normal mode... Please perform the following steps: 1. Wait while the phone will turn on 2. Reboot the phone 3. Enable "USB debugging" Mode 4. Connect the cable and check, whether ADB interface has appeared in PC Device Manager 5. Press "Ok" button. Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model FAAAANAZ*ÿš i at port COM122 Send SPC...OK Writing QCN... Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing QCN done! IMEI successfully fixed! Rebooting phone... Performed by 2.8.9 Software version. |
