Today i did flash one lg h812 from rogers canada, this phone have installed 20x version and i couldn´t find the rom anywhere, so i finally find the same version on z3x support but here is the mistery of this repair:
Octoplus have ugrade mode option to flash this phone, so i decide to use it, but when i try to flash even using the same version octoplus give me an alert about downgrade and risk taken so i decide to take the risk and the rom was flashed succesfully very fast but the phone was not repaired, still stuck on logo, so i did repeat write firmware option but with upgrade mode unchecked and the process it take much longer but it works, the phone is alive...
Thank you octoplus team to allow flash firmware on kdz format.
Best Regards !!!
Bienvenido en Octoplus/Octopus Box LG Software version 2.7.5
Checking data...OK
Plataforma: LG Qualcomm
Puerto seleccionado: COM1
Modelo seleccionado: H812
Lectura de la información...
Model ID: LG-H812
IMEI: 359803-06-02****-*
Android version: 6.0
Battery level: 34%
Versión de SW: H81220x
Mode: Emergency
Initializing flash...OK
Versión de SW: LGH812AT-00-V20x-302-720-JUL-12-2016+0
LAF Version: 1.1
Product ID: BS05S150513002384
Target operator: RGS
Hardware: rev_10
Abriendo "H81220x_00_0712.kdz"...OK
Firmware version: H81220x
Firmware model: LG-H812
Writing phone firmware without real necessity is at your own risk.
Downgrade may lead to phone damage!
Please, make sure the phone's battery is fully charged.
Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs.
To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices).
You should not run any other programs or attach new devices to your computer during the flashing!
Prepairing firmware...OK
Setting options...OK
Reading partitions...OK
Formating USERDATA...OK
Formating ENCRYPT...OK
Escribiendo 1/67 PrimaryGPT_0.bin...OK
Escribiendo 2/67 modem_32768.bin...OK
Escribiendo 3/67 pmic_229376.bin...OK
Escribiendo 4/67 sbl1_230400.bin...OK
Escribiendo 5/67 tz_232448.bin...OK
Escribiendo 6/67 sdi_234496.bin...OK
Escribiendo 7/67 hyp_235520.bin...OK
Escribiendo 8/67 rpm_236544.bin...OK
Escribiendo 9/67 aboot_237568.bin...OK
Escribiendo 10/67 sbl1bak_241664.bin...OK
Escribiendo 11/67 pmicbak_243712.bin...OK
Escribiendo 12/67 tzbak_244736.bin...OK
Escribiendo 13/67 hypbak_246784.bin...OK
Escribiendo 14/67 rpmbak_247808.bin...OK
Escribiendo 15/67 abootbak_248832.bin...OK
Escribiendo 16/67 sdibak_252928.bin...OK
Escribiendo 17/67 persist_294912.bin...OK
Escribiendo 18/67 sec_376832.bin...OK
Escribiendo 20/67 laf_393216.bin...OK
Escribiendo 21/67 boot_491520.bin...OK
Escribiendo 22/67 recovery_573440.bin...OK
Escribiendo 23/67 raw_resources_770048.bin...OK
Escribiendo 24/67 raw_resourcesbak_778240.bin...OK
Escribiendo 25/67 factory_917504.bin...OK
Escribiendo 26/67 system_1048576.bin...OK
Escribiendo 27/67 system_1312904.bin...OK
Escribiendo 28/67 system_1576912.bin...OK
Escribiendo 29/67 system_1837192.bin...OK
Escribiendo 30/67 system_1841240.bin...OK
Escribiendo 31/67 system_2101200.bin...OK
Escribiendo 32/67 system_2361480.bin...OK
Escribiendo 33/67 system_2365528.bin...OK
Escribiendo 34/67 system_2625488.bin...OK
Escribiendo 35/67 system_2885768.bin...OK
Escribiendo 36/67 system_2889816.bin...OK
Escribiendo 37/67 system_3149776.bin...OK
Escribiendo 38/67 system_3410056.bin...OK
Escribiendo 39/67 system_3414104.bin...OK
Escribiendo 40/67 system_3674064.bin...OK
Escribiendo 41/67 system_3936208.bin...OK
Escribiendo 42/67 system_4198352.bin...OK
Escribiendo 43/67 system_4460496.bin...OK
Escribiendo 44/67 system_4722640.bin...OK
Escribiendo 45/67 system_4984784.bin...OK
Escribiendo 46/67 system_5246928.bin...OK
Escribiendo 47/67 system_5509072.bin...OK
Escribiendo 48/67 system_5771216.bin...OK
Escribiendo 49/67 system_6033360.bin...OK
Escribiendo 50/67 system_6295504.bin...OK
Escribiendo 51/67 system_6557648.bin...OK
Escribiendo 52/67 system_6819792.bin...OK
Escribiendo 53/67 system_7077888.bin...OK
Escribiendo 54/67 system_7340032.bin...OK
Escribiendo 55/67 system_7602176.bin...OK
Escribiendo 56/67 system_7604360.bin...OK
Escribiendo 57/67 system_7608408.bin...OK
Escribiendo 58/67 system_8126464.bin...OK
Escribiendo 59/67 system_8128648.bin...OK
Escribiendo 60/67 system_8132696.bin...OK
Escribiendo 61/67 system_8650752.bin...OK
Escribiendo 62/67 system_8912896.bin...OK
Escribiendo 63/67 system_9175040.bin...OK
Escribiendo 64/67 system_9437184.bin...OK
Escribiendo 65/67 system_9699328.bin...OK
Escribiendo 66/67 system_9703376.bin...OK
Escribiendo 67/67 BackupGPT_61070336.bin...OK
Formating RCT...OK
Formating MPT...OK
Finalización...OK
Writing firmware done!
Performed by 2.7.5 Software version.
