01-16-2017, 16:55 | #1 (permalink) |
Insane Poster Join Date: Dec 2006 Location: Hungary
Member: 414226 Status: Offline Thanks Meter: 4 | Lg-h815 [Answered] There is an LG-H815, when try to power on the unit, unit is hanging on LG logo, after few minutes it power off. Try to load software, but software failed with Could not detect mode! Any idea? Last edited by Octopus box; 01-18-2017 at 09:18. |
01-16-2017, 16:59 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please put the phone into Emergency Mode manually, according to the Software manual (press Cable & Manual button in Software), after repeat "Write Firmware" operation. Also make sure, that You don't downgrade phone's firmware version - downgrading may damage your device! All firmwares for this device are available at the Support Area. To enter Support Area, press "Go to support" button on "Support & options" tab of the Software. |
01-17-2017, 17:49 | #3 (permalink) |
Member: 414226 Status: Offline Thanks Meter: 4 | Hello I try to do emergency mode, but it happen that you see above. I try to use LGH815_V20A_00.oct, beacuse I do not know which software present in the unit. Unit recognised by the PC as Qualcomm HS-USB QDLoader 9008. Unit has boot damage? |
01-18-2017, 07:31 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Quote:
01-18-2017, 16:03 | #6 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Medusa Pro Box supports repairing this device via eMMC and USB. If You have an old Medusa Box or Octoplus Box with JTAG activation, You can buy only Medusa Pro Upgrade Kit, no need to buy any additional activation: https://gsmserver.com/item/boxes-and...o-upgrade-kit/. |
01-23-2017, 10:41 | #7 (permalink) |
Freak Poster Join Date: Nov 2004 Age: 53
Member: 91140 Status: Offline Thanks Meter: 12 | LG H815 on logo Welcome to Octoplus/Octopus Box LG Software version 2.5.6 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM250 Selected model: H815 Reading info... Model ID: LG-H815 IMEI: 359872-06-021408-6 Android version: 5.1 Battery level: 73% SW Version: H81510a Mode: Emergency Initializing flash...OK SW version: LGH815AT-00-V10a-EUR-XX-APR-26-2015+0 Android version: 5.1 LAF Version: 1.1 Product ID: HD54S150507003226 IMEI: 359872-06-******* Target operator: GLOBAL Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "LGH815_V20A_00.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Writing PrimaryGPT...OK Writing modem...OK Writing pmic...OK Writing sbl1...OK Writing tz...OK Writing sdi...OK Writing hyp...OK Writing rpm...OK Writing aboot...OK Writing sbl1bak...OK Writing pmicbak...OK Writing tzbak...OK Writing hypbak...OK Writing rpmbak...OK Writing abootbak...OK Writing sdibak...OK Writing persist...OK Writing sec...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing factory...OK Writing raw_resources... Writing raw_resourcesbak... Writing system...Failed! Error code: ZXLCALSZXD Performed by 2.5.6 Software version. Please help! Thanks! |
01-23-2017, 13:18 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please, try to reflash the phone with V20i firmware from the Support Area. |
