07-02-2015, 17:42 | #1 (permalink) |
Freak Poster Join Date: Oct 2012 Location: TURKEY
Member: 1823773 Status: Offline Sonork: 100.1622605 Thanks Meter: 97 | lg h815 root need Platform: LG Qualcomm Selected port: COM109 Selected model: H815 Reading info... Model ID: LG-H815 IMEI: 359872-xxxxxxxxxxx Android version: 5.1 Battery level: 23% Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is not rooted. Please, root the phone manually! |
07-04-2015, 10:08 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Please check your PM, we have sent You test Software version. Try to perform the operation with test Software version without rooting. |
07-04-2015, 11:40 | #7 (permalink) |
Member: 1823773 Status: Offline Sonork: 100.1622605 Thanks Meter: 97 | not work Code: Welcome to Octoplus/Octopus Box LG Software version 2.0.0.1 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM109 Selected model: H815 Reading info... Model ID: LG-H815 IMEI: 359872-xxxxxxxx Android version: 5.1 Battery level: 39% Trying to enable Diagnostics ports... -------------------------------------------------------------------------- |
07-04-2015, 12:51 | #8 (permalink) |
Member: 1823773 Status: Offline Sonork: 100.1622605 Thanks Meter: 97 | i opened diagnostic port (enable diag) but problem soft not detected diag Code: -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM109 Selected model: H815 Reading info... Model ID: LG-H815 IMEI: 359872-xxxxxxxxxxxxx Android version: 5.1 Battery level: 39% Mode: Normal Firmware compiled date: Apr 15 2015 Firmware compiled time: 21:00:00 Firmware released date: May 1 2015 Firmware released time: 04:14:02 SW Version: MPSS.BO.2.5.c3-00060-M8992FAAAANAZM-1.18275.1 IMEI: 359872-06-004581-1 Bluetooth address: 00:00:00:00:00:00 SPC: 000000 Fixing IMEI... New IMEI: 356211-xxxxxxxxxxxx Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "H815_3598720xxxxxxxx_04-07-2015_13-38-31.qcn" Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "H815_35987206xxxxxxx_04-07-2015_13-51-31.SEC" Writing security area...OK Switching to Normal mode... Trying to enable Diagnostics ports... ------------------------------------------------------------- |
07-07-2015, 12:15 | #10 (permalink) | ||
Member: 1823773 Status: Offline Sonork: 100.1622605 Thanks Meter: 97 | Quote:
but problem soft not detected diag Quote:
i try but not change imei (same imei) Last edited by Octopus box; 07-07-2015 at 13:01. | ||
07-07-2015, 14:05 | #12 (permalink) | |
Code: Checking data...OK Platform: LG Qualcomm Selected port: COM109 Selected model: H815 Reading info... Model ID: LG-H815 IMEI: 359872-06-xxxxxxx Android version: 5.1 Battery level: 24% Mode: Normal Firmware compiled date: Apr 15 2015 Firmware compiled time: 21:00:00 Firmware released date: May 1 2015 Firmware released time: 04:14:02 SW Version: MPSS.BO.2.5.c3-00060-M8992FAAAANAZM-1.18275.1 IMEI: 359872-06-0xxxxxxx Bluetooth address: 00:00:00:00:00:00 SPC: 000000 Fixing IMEI... New IMEI: 356211-02-xxxxxxx Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "H815_35987206xxxxxxx_07-07-2015_14-06-09.qcn" Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "H815_35987206xxxxxxx_07-07-2015_14-19-09.SEC" Writing security area...OK Switching to Normal mode... Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.OK Diagnostics ports are enbled! Switching to Serial Port... Found model LGH815AT: ÿd at port COM109 Send SPC...OK Writing QCN... Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing QCN done! IMEI successfully fixed! Please, reboot the phone manually. after manualy restart but same imei manual factory reset but same | |
07-07-2015, 14:49 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Please do the next: 1. Enable "Skip Read/Write QCN during Repair IMEI operation" option in Software. 2. Repeat "Repair IMEI" operation. 3. Make Factory Reset immediately after operation ends, do not check IMEI (this is important). 4. As phone turns on after Factory Reset - check IMEI. Post here results and Software log of the operation. |
07-07-2015, 15:16 | #14 (permalink) | |
Code: -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM109 Selected model: H815 Reading info... Model ID: LG-H815 IMEI: 359872-06-xxxxxxx Android version: 5.1 Battery level: 69% Mode: Normal Firmware compiled date: Apr 15 2015 Firmware compiled time: 21:00:00 Firmware released date: May 1 2015 Firmware released time: 04:14:02 SW Version: MPSS.BO.2.5.c3-00060-M8992FAAAANAZM-1.18275.1 IMEI: 359872-06-xxxxxxx Bluetooth address: 00:00:00:00:00:00 SPC: 000000 Fixing IMEI... New IMEI: 356211-02-xxxxxxx Skip Read/Write QCN Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "H815_35987206xxxxxxx_07-07-2015_17-03-17.SEC" Writing security area...OK Switching to Normal mode... Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.OK Diagnostics ports are enbled! Switching to Serial Port... Found model LGH815AT: ÿd at port COM109 IMEI successfully fixed! Please, reboot the phone manually. | |
