03-27-2017, 13:47 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Afrique du sud Age: 42
Member: 430612 Status: Offline Thanks Meter: 301 | LG H850 flashing failed Welcome to Octoplus/Octopus Box LG Software version 2.6.0 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM58 Selected model: H850 Reading info... Mode: Emergency Initializing flash...OK SW version: LGH850AT-00-V10n-ZAF-XX-OCT-07-2016+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: SM02S160418002234 IMEI: 357657-07-348893-0 Target operator: GLOBAL Hardware: rev_11 Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! Opening "LGH850AT-00-V10b-OPT1-SI-MAR-09-2016+0.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing PrimaryGPT...Failed! LAF Error: 80000121. operation is currently not supported for your phone's firmware. Performed by 2.6.0 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM58 Selected model: H850 Reading info... Mode: Emergency Initializing flash...OK SW version: LGH850AT-00-V10n-ZAF-XX-OCT-07-2016+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: SM02S160418002234 IMEI: 357657-07-348893-0 Target operator: GLOBAL Hardware: rev_11 Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! Opening "LGH850AT-00-V10b-OPT1-SI-MAR-09-2016+0.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing PrimaryGPT...Failed! LAF Error: 80000121. operation is currently not supported for your phone's firmware. Performed by 2.6.0 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM58 Selected model: H850 Reading info... Model ID: LG-H850 IMEI: 357657-07-348893-0 Android version: 6.0.1 Battery level: 35% SW Version: H85010n Mode: Emergency Initializing flash...OK SW version: LGH850AT-00-V10n-ZAF-XX-OCT-07-2016+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: SM02S160418002234 IMEI: 357657-07-348893-0 Target operator: GLOBAL Hardware: rev_11 Performed by 2.6.0 Software version. Welcome to Octoplus/Octopus Box LG Software version 2.6.0 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM58 Selected model: H850 Reading info... Mode: Emergency Initializing flash...OK SW version: LGH850AT-00-V10n-ZAF-XX-OCT-07-2016+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: SM02S160418002234 IMEI: 357657-07-348893-0 Target operator: GLOBAL Hardware: rev_11 Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! Opening "LGH850AT-00-V10b-OPT1-SI-MAR-09-2016+0.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing PrimaryGPT...Failed! LAF Error: 80000121. operation is currently not supported for your phone's firmware. Performed by 2.6.0 Software version. phone hang on download mode after frp now even flashing fail |
03-27-2017, 14:10 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. According to the Software log, You are trying to downgrade phone's firmware version for V10n to V10b. Downgrade may lead to phone damage! |
