Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus LG/Octoplus LG
Old 08-27-2019, 11:10   #1 (permalink)
Member: 1143337
Thanks Meter: 104
Smile LG H870 reset frp done but stuck in 9008 port [Solved]
Log file "C:\Program Files (x86)\Octoplus\Octoplus_LG\LOG\27-08-2019_11-20-11.log" created.
8/27/2019 11:20:15 AM > Searching for server...
8/27/2019 11:20:15 AM > Trying to ping server...8/27/2019 11:20:15 AM > ok
8/27/2019 11:20:15 AM > Trying connect to server...
8/27/2019 11:20:16 AM > Server greeting: Card updates server v.2.2
8/27/2019 11:20:17 AM > Searching installed cards...
8/27/2019 11:20:17 AM > Found card with s/n: 00012085
8/27/2019 11:20:17 AM > Server check...
8/27/2019 11:20:17 AM > Server Check succesfull!
8/27/2019 11:20:19 AM > Welcome to Octoplus/Octopus Box LG Software version 2.9.5
8/27/2019 11:22:32 AM > Please, select Reset FRP Method!
8/27/2019 11:22:36 AM > --------------------------------------------------------------------------------
8/27/2019 11:22:36 AM > Checking data...8/27/2019 11:22:37 AM > OK
8/27/2019 11:22:37 AM > Platform: LG Qualcomm
8/27/2019 11:22:37 AM > Selected port: COM616
8/27/2019 11:22:37 AM > Selected model: H870
8/27/2019 11:22:37 AM > Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable).
8/27/2019 11:22:37 AM > Reading info...
8/27/2019 11:22:38 AM > Model ID: LG-H870
8/27/2019 11:22:38 AM > IMEI: 356144-08-053283-7
8/27/2019 11:22:38 AM > Android version: 8.0.0
8/27/2019 11:22:38 AM > Battery level: 44%
8/27/2019 11:22:47 AM > Mode: Normal
8/27/2019 11:22:47 AM > Switching to Download mode...8/27/2019 11:23:42 AM > OK
8/27/2019 11:23:42 AM > Reading partitions...
8/27/2019 11:23:42 AM > Initializing flash...8/27/2019 11:23:44 AM > OK8/27/2019 11:23:50 AM > OK
8/27/2019 11:23:50 AM > Reading BOOT...
8/27/2019 11:23:51 AM > ID: 0005F0E100310000
8/27/2019 11:23:51 AM > Operation is not safe and exist risk to damage the device!
Do You want to continue?8/27/2019 11:23:58 AM > OK
8/27/2019 11:23:58 AM > Backup saved to "H870_356144080532837_27-08-2019_11-23-58.oct"
8/27/2019 11:23:58 AM > Switching to Qualcomm 9008 mode...
8/27/2019 11:24:30 AM > Found port COM618
8/27/2019 11:24:30 AM > Connecting...8/27/2019 11:24:30 AM > Failed!
8/27/2019 11:24:30 AM > Performed by 2.9.5 Software version.
8/27/2019 11:24:30 AM > Elapsed Time: 12:01:59 AM
8/27/2019 11:24:38 AM > Please, select Reset FRP Method!
8/27/2019 11:24:41 AM > --------------------------------------------------------------------------------
8/27/2019 11:24:41 AM > Checking data...8/27/2019 11:24:41 AM > OK
8/27/2019 11:24:41 AM > Platform: LG Qualcomm
8/27/2019 11:24:41 AM > Selected port: COM3
8/27/2019 11:24:41 AM > Selected model: H870
8/27/2019 11:24:41 AM > Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable).
8/27/2019 11:24:41 AM > Reading info...
8/27/2019 11:24:53 AM > Could not detect mode!
8/27/2019 11:24:54 AM > Performed by 2.9.5 Software version.
8/27/2019 11:24:54 AM > Elapsed Time: 12:00:17 AM
8/27/2019 11:27:56 AM > Please, select Reset FRP Method!
8/27/2019 11:27:58 AM > To perform Reset FRP operation do the next:
1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable.
2. Check PC Device Manager, a new device should appear "Qualcomm HS-USB QDLoader 9008".
3. Release testpoint.
8/27/2019 11:27:58 AM > Found port COM618
8/27/2019 11:27:58 AM > Connecting...8/27/2019 11:27:58 AM > OK
8/27/2019 11:27:58 AM > Sending loader...8/27/2019 11:28:22 AM > OK
8/27/2019 11:28:22 AM > Reconnecting phone...8/27/2019 11:28:23 AM > OK
8/27/2019 11:28:25 AM > Checking request...
8/27/2019 11:28:25 AM > Request has been successfully sent!
8/27/2019 11:28:25 AM > Obtaining response...8/27/2019 11:28:25 AM > OK
8/27/2019 11:28:26 AM > Reading partitions...8/27/2019 11:28:27 AM > OK
8/27/2019 11:28:27 AM > Searching signatures...
8/27/2019 11:28:27 AM > Step 1...
8/27/2019 11:28:27 AM > Step 2...
8/27/2019 11:28:27 AM > Step 3...
8/27/2019 11:28:28 AM > Resetting FRP Lock...8/27/2019 11:28:28 AM > OK
8/27/2019 11:28:28 AM > Resetting FRP lock successfully completed!
8/27/2019 11:28:28 AM > Rebooting phone...
8/27/2019 11:28:28 AM > Performed by 2.9.5 Software version.
8/27/2019 11:28:28 AM > Elapsed Time: 12:00:33 AM
8/27/2019 11:32:12 AM > Please, select Reset FRP Method!
8/27/2019 11:32:16 AM > --------------------------------------------------------------------------------
8/27/2019 11:32:16 AM > Checking data...8/27/2019 11:32:16 AM > OK
8/27/2019 11:32:16 AM > Platform: LG Qualcomm
8/27/2019 11:32:16 AM > Selected port: COM3
8/27/2019 11:32:16 AM > Selected model: H870
8/27/2019 11:32:16 AM > Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable).
8/27/2019 11:32:16 AM > Reading info...
8/27/2019 11:32:29 AM > Could not detect mode!
8/27/2019 11:32:29 AM > Performed by 2.9.5 Software version.
8/27/2019 11:32:29 AM > Elapsed Time: 12:00:17 AM
8/27/2019 11:33:01 AM > Please, select Reset FRP Method!
8/27/2019 11:33:03 AM > Canceled!
8/27/2019 11:33:03 AM > Performed by 2.9.5 Software version.
8/27/2019 11:33:04 AM > Elapsed Time: 12:00:03 AM
team please help
Old 08-27-2019, 11:42   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,412
Hello.
Please, check H870 Reset FRP [Solved] same operation supported in Octoplus LG Tool
Old 08-27-2019, 13:04   #3 (permalink)
Member: 1143337
Thanks Meter: 104
Found port COM618
Connecting...OK
Sending loader...OK
Reconnecting phone...OK
Checking request...
Obtaining response...OK
Reading partitions...OK
Step 1...
Step 2...
Step 3...
Step 4...
Step 5...
Error code: ASDQKEASDA
Rebooting phone...
Old 08-27-2019, 13:22   #4 (permalink)
Member: 1143337
Thanks Meter: 104
Finally is done thx team
Found port COM618
Connecting...OK
Sending loader...OK
Checking request...
Step 1...
Step 2...
Step 3...
Step 4...
Step 5...
Rebooting phone...
Checking data...OK
Selected port: COM3
Reading info...
Opening "H870_356144080532837_27-08-2019_11-23-58.oct"...
Restore device from backup file?
Please, connect the phone...
Found port COM618
Connecting...OK
Sending loader...OK
Checking request...
Restoring BOOT...OK
Rebooting phone...
The Following User Says Thank You to TALHAGSM For This Useful Post:
Page generated in 0.19548 seconds with 9 queries
