07-10-2019, 16:11 | #1 (permalink) |
Registered User Join Date: Feb 2004 Location: morocco Age: 52
Member: 54024 Status: Offline Thanks Meter: 34 | lg h930 8.0.0 frp done Please, select Reset FRP Method! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM615 Selected model: H930 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info...Failed! Port busy Performed by 2.9.5.05 Software version. Please, select Reset FRP Method! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM507 Selected model: H930 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info...Failed! Port busy Performed by 2.9.5.05 Software version. Please, select Reset FRP Method! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM615 Selected model: H930 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info...Failed! Port busy Performed by 2.9.5.05 Software version. Please, select Reset FRP Method! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM507 Selected model: H930 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info...Failed! Port busy Performed by 2.9.5.05 Software version. Please, select Reset FRP Method! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM615 Selected model: H930 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... Model ID: LG-H930 IMEI: 359923-08-038486-0 Android version: 8.0.0 Battery level: 80% Mode: Emergency Initializing flash...OK Platform: msm8998 SW version: LGH930AT-00-V21o-EUR-XX-NOV-16-2018+0 Android version: 8.0.0 LAF Version: 1.1 Product ID: YE07S171128002455 IMEI: 359923-08-xxxxxx-0 Target operator: GLOBAL Hardware: rev_11 Reading partitions...OK Reading BOOT... ID: 0005E0E100310000 Operation is not safe and exist risk to damage the device! Do You want to continue?OK Backup saved to "H930_35992308xxxxxx0_10-07-2019_15-59- 52.oct" Switching to Qualcomm 9008 mode... Found port COM540 Connecting...OK Sending loader...OK Reconnecting phone...OK Checking request... Request has been successfully sent! Obtaining response...OK Reading partitions...OK Restoring BOOT...OK Searching signatures... Step 1... Resetting FRP Lock...OK Resetting FRP lock successfully completed! Rebooting phone... Performed by 2.9.5.05 Software version. |
The Following 2 Users Say Thank You to bakkougsm For This Useful Post: |
