09-29-2018, 09:58 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: bangladesh Age: 42
Member: 894213 Status: Offline Thanks Meter: 599 | LG-H930DS After FRP Reset Only Detect As 9008 [Solved] trying FRP RESET download mode now set only detect 9008 port here is log Code: Log file "C:\Program Files (x86)\Octoplus\Octoplus_LG\LOG\29-09-2018_12-32-44.log" created. 9/29/2018 12:32:46 PM > Searching for server... 9/29/2018 12:32:48 PM > Trying to ping server... 9/29/2018 12:32:48 PM > The necessary server was not found! 9/29/2018 12:32:50 PM > Welcome to Octoplus/Octopus Box LG Software version 2.8.7 9/29/2018 12:35:43 PM > -------------------------------------------------------------------------------- 9/29/2018 12:35:43 PM > Checking data...9/29/2018 12:35:44 PM > OK 9/29/2018 12:35:44 PM > Platform: LG Qualcomm 9/29/2018 12:35:44 PM > Selected port: COM44 9/29/2018 12:35:44 PM > Selected model: H930DS 9/29/2018 12:35:44 PM > Reading info... 9/29/2018 12:35:46 PM > Model ID: LG-H930DS 9/29/2018 12:35:46 PM > IMEI: 351537-09-100615-1 9/29/2018 12:35:46 PM > Android version: 8.0.0 9/29/2018 12:35:46 PM > Battery level: 94% 9/29/2018 12:35:46 PM > SW Version: 9/29/2018 12:35:46 PM > H93020a 9/29/2018 12:35:46 PM > Mode: Emergency 9/29/2018 12:35:46 PM > Initializing flash...9/29/2018 12:35:49 PM > OK 9/29/2018 12:35:50 PM > SW version: 9/29/2018 12:35:50 PM > LGH930DSAT-00-V20a-IND-XX-JUN-26-2018+0 9/29/2018 12:35:50 PM > Android version: 8.0.0 9/29/2018 12:35:50 PM > LAF Version: 1.1 9/29/2018 12:35:50 PM > Product ID: YE07S171115001049 9/29/2018 12:35:50 PM > IMEI: 351537-09-100615-1 9/29/2018 12:35:50 PM > Target operator: GLOBAL 9/29/2018 12:35:50 PM > Hardware: rev_11 9/29/2018 12:35:51 PM > Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Reset Security operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? 9/29/2018 12:35:58 PM > Canceled! 9/29/2018 12:35:58 PM > Performed by 2.8.7 Software version. 9/29/2018 12:36:02 PM > -------------------------------------------------------------------------------- 9/29/2018 12:36:02 PM > Checking data...9/29/2018 12:36:03 PM > OK 9/29/2018 12:36:03 PM > Platform: LG Qualcomm 9/29/2018 12:36:03 PM > Selected port: COM44 9/29/2018 12:36:03 PM > Selected model: H930DS 9/29/2018 12:36:03 PM > Reading info... 9/29/2018 12:36:04 PM > Model ID: LG-H930DS 9/29/2018 12:36:04 PM > IMEI: 351537-09-100615-1 9/29/2018 12:36:04 PM > Android version: 8.0.0 9/29/2018 12:36:04 PM > Battery level: 94% 9/29/2018 12:36:04 PM > SW Version: 9/29/2018 12:36:04 PM > H93020a 9/29/2018 12:36:05 PM > Mode: Emergency 9/29/2018 12:36:05 PM > Initializing flash...9/29/2018 12:36:07 PM > OK 9/29/2018 12:36:08 PM > SW version: 9/29/2018 12:36:08 PM > LGH930DSAT-00-V20a-IND-XX-JUN-26-2018+0 9/29/2018 12:36:08 PM > Android version: 8.0.0 9/29/2018 12:36:08 PM > LAF Version: 1.1 9/29/2018 12:36:08 PM > Product ID: YE07S171115001049 9/29/2018 12:36:08 PM > IMEI: 351537-09-100615-1 9/29/2018 12:36:08 PM > Target operator: GLOBAL 9/29/2018 12:36:08 PM > Hardware: rev_11 9/29/2018 12:36:08 PM > Unlocking... 9/29/2018 12:36:09 PM > Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? 9/29/2018 12:36:23 PM > Canceled! 9/29/2018 12:36:23 PM > Performed by 2.8.7 Software version. 9/29/2018 12:36:27 PM > -------------------------------------------------------------------------------- 9/29/2018 12:36:27 PM > Checking data...9/29/2018 12:36:27 PM > OK 9/29/2018 12:36:27 PM > Platform: LG Qualcomm 9/29/2018 12:36:27 PM > Selected port: COM44 9/29/2018 12:36:27 PM > Selected model: H930DS 9/29/2018 12:36:27 PM > Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). 9/29/2018 12:36:27 PM > Reading info... 9/29/2018 12:36:29 PM > Model ID: LG-H930DS 9/29/2018 12:36:29 PM > IMEI: 351537-09-100615-1 9/29/2018 12:36:29 PM > Android version: 8.0.0 9/29/2018 12:36:29 PM > Battery level: 94% 9/29/2018 12:36:29 PM > SW Version: 9/29/2018 12:36:29 PM > H93020a 9/29/2018 12:36:30 PM > Mode: Emergency 9/29/2018 12:36:30 PM > Initializing flash...9/29/2018 12:36:32 PM > OK 9/29/2018 12:36:33 PM > SW version: 9/29/2018 12:36:33 PM > LGH930DSAT-00-V20a-IND-XX-JUN-26-2018+0 9/29/2018 12:36:33 PM > Android version: 8.0.0 9/29/2018 12:36:33 PM > LAF Version: 1.1 9/29/2018 12:36:33 PM > Product ID: YE07S171115001049 9/29/2018 12:36:33 PM > IMEI: 351537-09-100615-1 9/29/2018 12:36:33 PM > Target operator: GLOBAL 9/29/2018 12:36:33 PM > Hardware: rev_11 9/29/2018 12:36:33 PM > Reset FRP operation is currently not supported for your phone's firmware. 9/29/2018 12:36:33 PM > Performed by 2.8.7 Software version. 9/29/2018 12:38:06 PM > -------------------------------------------------------------------------------- 9/29/2018 12:38:06 PM > Checking data...9/29/2018 12:38:07 PM > OK 9/29/2018 12:38:07 PM > Platform: LG Qualcomm 9/29/2018 12:38:07 PM > Selected port: COM44 9/29/2018 12:38:07 PM > Selected model: H930DS 9/29/2018 12:38:07 PM > Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). 9/29/2018 12:38:07 PM > Reading info... 9/29/2018 12:38:09 PM > Model ID: LG-H930DS 9/29/2018 12:38:09 PM > IMEI: 351537-09-100615-1 9/29/2018 12:38:09 PM > Android version: 8.0.0 9/29/2018 12:38:09 PM > Battery level: 94% 9/29/2018 12:38:09 PM > SW Version: 9/29/2018 12:38:09 PM > H93020a 9/29/2018 12:38:09 PM > Mode: Emergency 9/29/2018 12:38:09 PM > Initializing flash...9/29/2018 12:38:12 PM > OK 9/29/2018 12:38:13 PM > SW version: 9/29/2018 12:38:13 PM > LGH930DSAT-00-V20a-IND-XX-JUN-26-2018+0 9/29/2018 12:38:13 PM > Android version: 8.0.0 9/29/2018 12:38:13 PM > LAF Version: 1.1 9/29/2018 12:38:13 PM > Product ID: YE07S171115001049 9/29/2018 12:38:13 PM > IMEI: 351537-09-100615-1 9/29/2018 12:38:13 PM > Target operator: GLOBAL 9/29/2018 12:38:13 PM > Hardware: rev_11 9/29/2018 12:38:13 PM > Reset FRP operation is currently not supported for your phone's firmware. 9/29/2018 12:38:13 PM > Performed by 2.8.7 Software version. Plz Team Need Help ..... Thanks in Advance ........ Last edited by Octopus box; 09-29-2018 at 11:48. |
09-29-2018, 10:17 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | First of all, please download and install the latest Software version and please in future use always latest Software version. According to the Software log, You are trying to Unlock your device, before performing Reset FRP operation. In what condition was your device before Unlock and Reset FRP operations (besides, Reset FRP operation even not started, it just make check for firmware version)?! |
09-29-2018, 10:26 | #3 (permalink) |
Member: 894213 Status: Offline Thanks Meter: 599 | here frp reset log 9/29/2018 12:38:06 PM > Checking data...9/29/2018 12:38:07 PM > OK 9/29/2018 12:38:07 PM > Platform: LG Qualcomm 9/29/2018 12:38:07 PM > Selected port: COM44 9/29/2018 12:38:07 PM > Selected model: H930DS 9/29/2018 12:38:07 PM > Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). 9/29/2018 12:38:07 PM > Reading info... 9/29/2018 12:38:09 PM > Model ID: LG-H930DS 9/29/2018 12:38:09 PM > IMEI: 351537-09-100615-1 9/29/2018 12:38:09 PM > Android version: 8.0.0 9/29/2018 12:38:09 PM > Battery level: 94% 9/29/2018 12:38:09 PM > SW Version: 9/29/2018 12:38:09 PM > H93020a 9/29/2018 12:38:09 PM > Mode: Emergency 9/29/2018 12:38:09 PM > Initializing flash...9/29/2018 12:38:12 PM > OK 9/29/2018 12:38:13 PM > SW version: 9/29/2018 12:38:13 PM > LGH930DSAT-00-V20a-IND-XX-JUN-26-2018+0 9/29/2018 12:38:13 PM > Android version: 8.0.0 9/29/2018 12:38:13 PM > LAF Version: 1.1 9/29/2018 12:38:13 PM > Product ID: YE07S171115001049 9/29/2018 12:38:13 PM > IMEI: 351537-09-100615-1 9/29/2018 12:38:13 PM > Target operator: GLOBAL 9/29/2018 12:38:13 PM > Hardware: rev_11 9/29/2018 12:38:13 PM > Reset FRP operation is currently not supported for your phone's firmware. 9/29/2018 12:38:13 PM > Performed by 2.8.7 Software version. |
09-29-2018, 10:31 | #4 (permalink) |
Member: 894213 Status: Offline Thanks Meter: 599 | extremely sorry for old version info here is correct FRP reset log Log file "C:\Program Files (x86)\Octoplus\Octoplus_LG\LOG\29-09-2018_13-26-55.log" created. 9/29/2018 1:26:57 PM > Searching for server... 9/29/2018 1:26:59 PM > Trying to ping server... 9/29/2018 1:26:59 PM > The necessary server was not found! 9/29/2018 1:27:00 PM > Welcome to Octoplus/Octopus Box LG Software version 2.8.9 9/29/2018 1:29:23 PM > Please select Reset FRP Method! 9/29/2018 1:29:27 PM > -------------------------------------------------------------------------------- 9/29/2018 1:29:27 PM > Checking data...9/29/2018 1:29:28 PM > OK 9/29/2018 1:29:28 PM > Platform: LG Qualcomm 9/29/2018 1:29:28 PM > Selected port: COM44 9/29/2018 1:29:28 PM > Selected model: H930DS 9/29/2018 1:29:28 PM > Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). 9/29/2018 1:29:28 PM > Reading info... 9/29/2018 1:29:30 PM > Model ID: LG-H930DS 9/29/2018 1:29:30 PM > IMEI: 351537-09-100615-1 9/29/2018 1:29:30 PM > Android version: 8.0.0 9/29/2018 1:29:30 PM > Battery level: 87% 9/29/2018 1:29:30 PM > SW Version: 9/29/2018 1:29:30 PM > H93020a 9/29/2018 1:29:30 PM > Mode: Emergency 9/29/2018 1:29:30 PM > Initializing flash...9/29/2018 1:29:32 PM > OK 9/29/2018 1:29:33 PM > Platform: msm8998 9/29/2018 1:29:33 PM > SW version: 9/29/2018 1:29:33 PM > LGH930DSAT-00-V20a-IND-XX-JUN-26-2018+0 9/29/2018 1:29:33 PM > Android version: 8.0.0 9/29/2018 1:29:33 PM > LAF Version: 1.1 9/29/2018 1:29:33 PM > Product ID: YE07S171115001049 9/29/2018 1:29:33 PM > IMEI: 351537-09-100615-1 9/29/2018 1:29:33 PM > Target operator: GLOBAL 9/29/2018 1:29:33 PM > Hardware: rev_11 9/29/2018 1:29:33 PM > Reading partitions...9/29/2018 1:29:40 PM > OK 9/29/2018 1:29:40 PM > Reading BOOT... 9/29/2018 1:29:41 PM > ID: 0005E0E100310000 9/29/2018 1:29:41 PM > Operation is not safe and exist risk to damage the device! Do You want to continue?9/29/2018 1:29:47 PM > OK 9/29/2018 1:29:47 PM > Backup saved to "H930DS_351537091006151_29-09-2018_13-29-47.oct" 9/29/2018 1:29:47 PM > Switching to Qualcomm 9008 mode... 9/29/2018 1:30:08 PM > Found port COM47 9/29/2018 1:30:08 PM > Connecting...9/29/2018 1:30:08 PM > OK 9/29/2018 1:30:08 PM > Sending loader...9/29/2018 1:30:38 PM > OK 9/29/2018 1:30:38 PM > Reconnecting phone...9/29/2018 1:30:38 PM > OK 9/29/2018 1:30:40 PM > Checking request... 9/29/2018 1:30:40 PM > Request has been successfully sent! 9/29/2018 1:30:40 PM > Obtaining response...9/29/2018 1:30:41 PM > OK 9/29/2018 1:30:41 PM > Reading partitions...9/29/2018 1:30:41 PM > OK 9/29/2018 1:30:41 PM > Rebooting phone... 9/29/2018 1:30:41 PM > Performed by 2.8.9 Software version. 9/29/2018 1:30:41 PM > Elapsed Time: 12:01:18 AM |
09-29-2018, 10:43 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | If you device stuck in 9008 mode, then please, before creating thread, use forum search H930 Reset FRP solution |
09-29-2018, 10:51 | #6 (permalink) |
Member: 894213 Status: Offline Thanks Meter: 599 | Code: Welcome to Octoplus/Octopus Box LG Software version 2.8.9 Please select Reset FRP Method! Opening "H930DS_351537091006151_29-09-2018_13-29-47.oct"... Restore device from backup file? Please, connect the phone... Found port COM43 Connecting...OK Sending loader...OK Reconnecting phone...OK Checking request... Request has been successfully sent! Obtaining response...OK Reading partitions...OK Rebooting phone... Performed by 2.8.9 Software version. |
09-29-2018, 10:59 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please, check your PM, we have sent You test Software version, after repeat write backup. |
09-29-2018, 11:13 | #8 (permalink) | |
Member: 894213 Status: Offline Thanks Meter: 599 | Quote:
But FRP not reset Code: Welcome to Octoplus/Octopus Box LG Software version 2.8.9.1 Please select Reset FRP Method! Opening "H930DS_351537091006151_29-09-2018_13-29-47.oct"... Restore device from backup file? Please, connect the phone... Found port COM43 Connecting...OK Sending loader...OK Reconnecting phone...OK Checking request... Request has been successfully sent! Obtaining response...OK Reading partitions...OK Restoring BOOT...OK Rebooting phone... Performed by 2.8.9.1 Software version Can I try frp reset with test version ? | |
09-29-2018, 11:33 | #10 (permalink) | |
Code: Welcome to Octoplus/Octopus Box LG Software version 2.8.9.1 Please select Reset FRP Method! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM45 Selected model: H930DS Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... Model ID: LG-H930DS IMEI: 351537-09-100615-1 Android version: 8.0.0 Battery level: 87% SW Version: H93020a Mode: Emergency Initializing flash...OK Platform: msm8998 SW version: LGH930DSAT-00-V20a-IND-XX-JUN-26-2018+0 Android version: 8.0.0 LAF Version: 1.1 Product ID: YE07S171115001049 IMEI: 351537-09-100615-1 Target operator: GLOBAL Hardware: rev_11 Reading partitions...OK Reading BOOT... ID: 0005E0E100310000 Operation is not safe and exist risk to damage the device! Do You want to continue?OK Backup saved to "H930DS_351537091006151_29-09-2018_16-28-31.oct" Switching to Qualcomm 9008 mode... Found port COM43 Connecting...OK Sending loader...OK Reconnecting phone...OK Checking request... Request has been successfully sent! Obtaining response...OK Reading partitions...OK Restoring BOOT...OK Searching signatures... Step 1... Resetting FRP Lock...OK Resetting FRP lock successfully completed! Rebooting phone... Performed by 2.8.9.1 Software version. Everything working Perfect | |
The Following User Says Thank You to HB MOBILE For This Useful Post: |
