06-21-2016, 15:30 | #1 (permalink) |
No Life Poster Join Date: Sep 2002 Location: south Afrika Age: 38
Member: 15156 Status: Offline Thanks Meter: 73 | lg hh15p imei repair help Welcome to Octoplus/Octopus Box LG Software version 2.1.9 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM43 Selected model: H815P Reading info... Model ID: LG-H815P IMEI: 359871-06-262750-1 Android version: 6.0 Battery level: 100% Mode: Normal Performed by 2.1.9 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM43 Selected model: H815P Reading info... Model ID: LG-H815P IMEI: 359871-06-262750-1 Android version: 6.0 Battery level: 100% Mode: Normal Fixing IMEI... New IMEI: 359871-16-262750-0 Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...Failed! Reading NV_Numbered Items...Canceled! Backup saved to "H815P_359871062627501_21-06-2016_07-28-38.qcn" Performed by 2.1.9 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM43 Selected model: H815P Reading info... Model ID: LG-H815P IMEI: 359871-06-262750-1 Android version: 6.0 Battery level: 100% Mode: Normal Fixing IMEI... New IMEI: 359871-16-262750-0 Skip Read/Write QCN Writing security area... Performed by 2.1.9 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM43 Selected model: H815P Reading info... Model ID: LG-H815P IMEI: 359871-06-262750-1 Android version: 6.0 Battery level: 100% Mode: Normal Fixing IMEI... New IMEI: 359871-16-262750-0 Skip Read/Write QCN Writing security area... Performed by 2.1.9 software version. plz help.thanx |
06-22-2016, 08:33 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Hello. Please, install the latest Software version and repeat Repair IMEI operation again, after post here full Software log. |
06-24-2016, 14:35 | #3 (permalink) |
Member: 15156 Status: Offline Thanks Meter: 73 | 6/22/2016 12:29:13 AM > Checking data...6/22/2016 12:29:14 AM > OK 6/22/2016 12:29:15 AM > Platform: LG Qualcomm 6/22/2016 12:29:15 AM > Selected port: COM43 6/22/2016 12:29:15 AM > Selected model: H815P 6/22/2016 12:29:15 AM > Reading info... 6/22/2016 12:29:17 AM > Model ID: LG-H815P 6/22/2016 12:29:17 AM > IMEI: 359871-06-262750-1 6/22/2016 12:29:17 AM > Android version: 6.0 6/22/2016 12:29:17 AM > Battery level: 100% 6/22/2016 12:29:26 AM > Mode: Normal 6/22/2016 12:29:26 AM > Fixing IMEI... 6/22/2016 12:29:27 AM > New IMEI: 359871-16-262750-0 6/22/2016 12:29:32 AM > Skip Read/Write QCN 6/22/2016 12:29:32 AM > Do you want to create security backup? 6/22/2016 12:29:36 AM > Writing security area...6/22/2016 12:29:39 AM > Failed! 6/22/2016 12:29:40 AM > Performed by 2.3.4 software version. 6/22/2016 12:29:56 AM > -------------------------------------------------------------------------------- 6/22/2016 12:29:56 AM > Checking data...6/22/2016 12:29:57 AM > OK 6/22/2016 12:29:57 AM > Platform: LG Qualcomm 6/22/2016 12:29:57 AM > Selected port: COM43 6/22/2016 12:29:57 AM > Selected model: H815P 6/22/2016 12:29:57 AM > Reading info... 6/22/2016 12:29:59 AM > Model ID: LG-H815P 6/22/2016 12:29:59 AM > IMEI: 359871-06-262750-1 6/22/2016 12:29:59 AM > Android version: 6.0 6/22/2016 12:29:59 AM > Battery level: 100% 6/22/2016 12:30:09 AM > Mode: Normal 6/22/2016 12:30:09 AM > Fixing IMEI... 6/22/2016 12:30:09 AM > New IMEI: 359871-16-262750-0 6/22/2016 12:30:14 AM > Skip Read/Write QCN 6/22/2016 12:30:14 AM > Do you want to create security backup? 6/22/2016 12:30:21 AM > Switching to Download mode...6/22/2016 12:30:55 AM > Failed! 6/22/2016 12:30:55 AM > Please perform the following steps: 1. Disconnect cable 2. Put phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P990 cable)) 3. Connect cable and press "Ok" button. 6/22/2016 12:32:45 AM > Initializing flash...6/22/2016 12:32:48 AM > OK 6/22/2016 12:32:48 AM > Reading partitions...6/22/2016 12:32:50 AM > OK 6/22/2016 12:32:50 AM > Reading security area...6/22/2016 12:32:51 AM > OK 6/22/2016 12:32:51 AM > Backup saved to "H815P_359871062627501_22-06-2016_00-30-21.SEC" 6/22/2016 12:32:51 AM > Switching to Normal mode... 6/22/2016 12:33:45 AM > Trying to enable Diagnostics ports... 6/22/2016 12:33:45 AM > Initializing ADB...6/22/2016 12:33:47 AM > OK 6/22/2016 12:33:47 AM > Waiting for phone... 6/22/2016 12:33:47 AM > Please, reconnect phone, enable USB debugging, and try again. 6/22/2016 12:33:47 AM > To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.6/22/2016 12:34:07 AM > OK 6/22/2016 12:34:09 AM > Diagnostics ports are enbled! 6/22/2016 12:34:09 AM > Switching to Serial Port... 6/22/2016 12:34:38 AM > Failed! 6/22/2016 12:34:38 AM > Trying to enable Diagnostics ports... 6/22/2016 12:34:38 AM > Checking root access... 6/22/2016 12:34:39 AM > Phone is not rooted. 6/22/2016 12:34:40 AM > Please, root the phone manually! 6/22/2016 12:34:40 AM > Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Press "Ok" button 6/22/2016 12:36:45 AM > Trying to enable Diagnostics ports... 6/22/2016 12:36:45 AM > Failed! still not working help please.thanx |
06-24-2016, 15:05 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Quote:
06-25-2016, 09:52 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Please, try to do next: Skip Read/Write QCM during Repair IMEI operation, option, after perform these steps:
