08-07-2017, 20:20 | #1 (permalink) |
No Life Poster Join Date: Sep 2012 Location: UK
Member: 1816005 Status: Offline Thanks Meter: 299 | LG K10 2017 M250N FRP Remove OK Code: Welcome to Octoplus/Octopus Box LG Software version 2.7.2 -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM1 Selected baudrate: 0 Selected model: M250N Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM130 Port is not active! Performed by 2.7.2 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM1 Selected baudrate: 0 Selected model: M250N Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM130 Port is not active! Performed by 2.7.2 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM1 Selected baudrate: 0 Selected model: M250N Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM130 Mode: Emergency Initializing flash...OK Model ID: LG-M250n SW version: LGM250nAT-00-V10e-ORG-MCV-APR-25-2017+0 LAF Version: 1.1 Product ID: CT69S170202002708 IMEI: Target operator: GLOBAL Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 354945-08-075738-6 Bluetooth address: B8:1D:AA:5A:66:4E Wi-Fi MAC address: B8:1D:AA:C3:6E:04 SPC: 000000 -------------------------------------------------------------------------------- Reset FRP operation for M250N will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Resetting FRP Lock... Writing loader...OK Writing userdata...OK Formating encrypt...OK Restoring loader...OK Resetting FRP lock successfully completed! Rebooting phone... To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Performed by 2.7.2 Software version. Last edited by Octopus box; 08-07-2017 at 21:32. |
The Following 3 Users Say Thank You to gsmro2012 For This Useful Post: |
04-09-2018, 21:51 | #2 (permalink) |
Freak Poster Join Date: Jul 2005 Age: 54
Member: 166398 Status: Offline Thanks Meter: 21 | Not working for me Welcome to Octoplus/Octopus Box LG Software version 2.8.1 -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM81 Selected baudrate: 0 Selected model: M250N Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM74 Port is not active! Performed by 2.8.1 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM81 Selected baudrate: 0 Selected model: M250N Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM72 Mode: Emergency Initializing flash...OK Model ID: LG-M250n SW version: LGM250nAT-00-V10e-222-01-JAN-04-2018+0 LAF Version: 1.1 Product ID: CY19S170514000259 IMEI: Target operator: GLOBAL Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 35xxxx-xx-xxxxxx-x Bluetooth address: 04:1B:6D:63:03:1A Wi-Fi MAC address: 04:1B:6D:B8:E8:0D SPC: 000000 -------------------------------------------------------------------------------- Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...OK Reset FRP operation for M250N will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Resetting FRP Lock... Writing loader...OK Writing userdata...Failed! Restoring loader...OK Rebooting phone... Performed by 2.8.1 Software version. Last edited by Octopus box; 04-10-2018 at 08:32. |
04-10-2018, 09:17 | #5 (permalink) |
No Life Poster Join Date: Apr 2012
Member: 1744883 Status: Offline Sonork: 100.1609806 Thanks Meter: 1,127 | No Way. Code: Welcome to Octoplus/Octopus Box LG Software version 2.8.1 -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM7 Selected baudrate: 0 Selected model: M250N Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM120 Mode: Emergency Initializing flash...OK Model ID: LG-M250n SW version: LGM250nAT-00-V10n-EUR-XX-DEC-18-2017+0 LAF Version: 1.1 Product ID: CY19S170713007007 IMEI: Target operator: GLOBAL Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 354945-08-441539-5 Bluetooth address: 88:36:5F:6F:91:AF Wi-Fi MAC address: 88:36:5F:DF:06:EC SPC: 000000 -------------------------------------------------------------------------------- Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...OK Reset FRP operation for M250N will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Resetting FRP Lock... Writing loader...OK Writing userdata...Failed! Restoring loader...OK Rebooting phone... Performed by 2.8.1 Software version. |
04-10-2018, 09:26 | #7 (permalink) |
Member: 1744883 Status: Offline Sonork: 100.1609806 Thanks Meter: 1,127 | I do it for 3 --- Hard reset + Remove FRP = Same Code: Welcome to Octoplus/Octopus Box LG Software version 2.8.1 -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM7 Selected baudrate: 0 Selected model: M250N Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM120 Mode: Emergency Initializing flash...OK Model ID: LG-M250n SW version: LGM250nAT-00-V10n-EUR-XX-DEC-18-2017+0 LAF Version: 1.1 Product ID: CY19S170713007007 IMEI: Target operator: GLOBAL Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 35xxxx-xx-xxxxxx-x Bluetooth address: 88:36:5F:6F:91:AF Wi-Fi MAC address: 88:36:5FF:06:EC SPC: 000000 -------------------------------------------------------------------------------- Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...OK Reset FRP operation for M250N will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Resetting FRP Lock... Writing loader...OK Writing userdata...Failed! Restoring loader...OK Rebooting phone... Performed by 2.8.1 Software version. Last edited by .::StarCodes::.; 04-10-2018 at 09:31. |
04-10-2018, 09:42 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Please, download and install the latest test Software version v2.8.1.2 from the Support Area, then repeat operation again, post here full Software log. Last edited by Octopus box; 04-10-2018 at 09:58. |
04-10-2018, 10:40 | #9 (permalink) |
Member: 1744883 Status: Offline Sonork: 100.1609806 Thanks Meter: 1,127 | with V2.8.1.2 it's ok Code: Welcome to Octoplus/Octopus Box LG Software version 2.8.1.2 -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM7 Selected baudrate: 0 Selected model: M250N Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM120 Mode: Emergency Initializing flash...OK Model ID: LG-M250n SW version: LGM250nAT-00-V10n-EUR-XX-DEC-18-2017+0 LAF Version: 1.1 Product ID: CY19S170713007007 IMEI: Target operator: GLOBAL Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 3549xxxxxxxxx Bluetooth address: 88:36xxxxxxx Wi-Fi MAC address: 88:36xxxxxxxx SPC: 000000 -------------------------------------------------------------------------------- Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...OK Reset FRP operation for M250N will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Resetting FRP Lock... Writing loader...OK Writing userdata...OK Formating encrypt...OK Restoring loader...OK Resetting FRP lock successfully completed! Rebooting phone... To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Performed by 2.8.1.2 Software version. |
The Following 2 Users Say Thank You to .::StarCodes::. For This Useful Post: |
