03-09-2020, 15:40 | #1 (permalink) |
Freak Poster Join Date: Nov 2002 Location: Ukraine Age: 42
Member: 17973 Status: Offline Thanks Meter: 16 | LG K450 Cricket unlock problem [Answered] Platform: LG Qualcomm Selected port: COM28 Selected model: K450 Reading info... Model ID: LG-K450 IMEI: 359560-07-178561-2 Android version: 6.0.1 Battery level: 4% Mode: Emergency Initializing flash...OK Platform: msm8909 SW version: LGK450AT-01-V12d-310-150-APR-02-2018-ARB00+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CT69S170106005982 IMEI: 359560-07-178561-2 Target operator: CRK Hardware: rev_10 Unlocking... Skip Read/Write QCN Do you want to create security backup? Reading partitions...OK Detecting writing method...OK Reading security area...OK Backup saved to "K450_359560071785612_09-03-2020_16-37- 20.SEC" Switching to Normal mode... Trying to enable Diagnostics ports...Failed! Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Diagnostics ports are enbled! Switching to Serial Port...Failed! Trying to enable Diagnostics ports... Checking root access... Phone is not rooted. Please, root the phone manually! Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Connect USB cable to then phone 4. Press "Ok" button Trying to enable Diagnostics ports...Failed! Trying to enable Diagnostics ports... Diagnostics ports are enbled! Switching to Serial Port...Failed! Trying to enable Diagnostics ports... Checking root access... Phone is not rooted. Please, root the phone manually! Performed by 3.0.0 Software version. |
The Following User Says Thank You to Arty For This Useful Post: |
03-10-2020, 07:43 | #2 (permalink) | |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,138 | Hello. According to software manual please do next steps: Quote:
03-10-2020, 15:42 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | If You've done all the steps, then connect your device in Normal mode and repeat operation again, after post here full Software log |
03-11-2020, 16:26 | #6 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Quote:
03-11-2020, 17:08 | #8 (permalink) | |
