02-22-2017, 15:42 | #1 (permalink) |
Registered User Join Date: Aug 2007 Location: United Kingdom
Member: 567838 Status: Offline Thanks Meter: 64 | LG K520 not entering emergency mode I tried battery out cable out press volume up but keep failing |
02-22-2017, 16:02 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. To enter emergency mode, disconnect cable, disconnect battery, press and hold "Vol+" button and connect USB cable. If problem still remain, try to reconnect phone to another USB port and use another USB cable. |
02-22-2017, 17:14 | #3 (permalink) |
Member: 567838 Status: Offline Thanks Meter: 64 | Welcome to Octoplus/Octopus Box LG Software version 2.5.8 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM1 Selected model: K520 Reading info... Could not detect mode! Performed by 2.5.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM1 Selected model: K520 Reading info... Could not detect mode! Performed by 2.5.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM1 Selected model: K520 Reading info... Could not detect mode! Performed by 2.5.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM22 Selected model: K520 Reading info... Model ID: LG-K520 IMEI: 358385-07-0272xxxxx Android version: 6.0.1 Battery level: 100% SW Version: K52010c Mode: Emergency Initializing flash...OK SW version: LGK520AT-01-V10c-234-10-NOV-23-2016+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CT69S160412000658 IMEI: 358385-07-xxxxxxx Target operator: GLOBAL Hardware: rev_10 Unlocking... Switching to Normal mode... Trying to enable Diagnostics ports... Performed by 2.5.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM1 Selected model: K520 Reading info... Could not detect mode! Performed by 2.5.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM1 Selected model: K520 Reading info... Could not detect mode! Performed by 2.5.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM22 Selected model: K520 Reading info... Model ID: LG-K520 IMEI: 358xxxxxxxx Android version: 6.0.1 Battery level: 100% SW Version: K52010c Mode: Emergency Initializing flash...OK SW version: LGK520AT-01-V10c-234-10-NOV-23-2016+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CT69S160412000658 IMEI: 358385-07-027231-8 Target operator: GLOBAL Hardware: rev_10 Unlocking... Switching to Normal mode... Trying to enable Diagnostics ports... Performed by 2.5.8 Software version. when it gets to switching normal mode does nothing port is enabled in svc mode |
02-23-2017, 08:57 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Please, connect phone to PC, select File Transfer type of connection, then: 1. Enable "USB Debugging" mode; 2. Type 277634#*# or *#546368#*520# or 3845*#520#, go to "Port Check Test" (or "SVC Menu -> Port Check Test") and switch "Port Check Test" to "Enabled". |
