09-02-2019, 09:37 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: philippines Age: 42
Member: 388962 Status: Offline Sonork: 100.1637202 Thanks Meter: 264 | LG K520DY NO display after flash [Answered] i tried to flash using this file > K520DY10g_00_1227.oct it is success on flashing no error shown on logs : Code: Welcome to Octoplus/Octopus Box LG Software version 2.9.6 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM62 Selected model: K520DY Reading info... Model ID: LG-K520DY IMEI: 357952-07-360619-7 Android version: 6.0.1 Battery level: 22% Mode: Emergency Initializing flash...OK Platform: msm8916 SW version: LGK520DYAT-00-V10d-ESA-XX-NOV-23-2016+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CT01S160611000175 IMEI: 357952-07-360619-7 Target operator: GLOBAL Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "K520DY20d_00_0331.oct"...OK Selecting firmware partitions...OK Selected default partitions! Setting options...OK Do you want to format User Data? Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Sending signature...OK Writing PrimaryGPT...OK Writing sbl1...OK Writing tz...OK Writing hyp...OK Writing rpm...OK Writing aboot...OK Writing sbl1bak...OK Writing tzbak...OK Writing hypbak...OK Writing rpmbak...OK Writing abootbak...OK Writing persist...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing recoverybak...OK Writing sec...OK Writing factory...OK Writing modem...OK Writing cust...OK Writing system...OK Writing OP...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.9.6 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM62 Selected model: K520DY Reading info... Model ID: LG-K520DY IMEI: 357952-07-360619-7 Android version: 6.0.1 Battery level: 54% Mode: Emergency Initializing flash...OK Platform: msm8916 SW version: LGK520DYAT-00-V20m-GLOBAL-COM-MAR-31-2017 +0 Android version: 7.0 LAF Version: 1.1 Product ID: CT01S160611000175 IMEI: 357952-07-360619-7 Target operator: GLOBAL Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "K520DY10g_00_1227.oct"...OK Selecting firmware partitions...OK Selected default partitions! Setting options...OK Do you want to format User Data? Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Sending signature...OK Writing PrimaryGPT...OK Writing sbl1...OK Writing tz...OK Writing hyp...OK Writing rpm...OK Writing aboot...OK Writing sbl1bak...OK Writing tzbak...OK Writing hypbak...OK Writing rpmbak...OK Writing abootbak...OK Writing persist...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing recoverybak...OK Writing sec...OK Writing factory...OK Writing modem...OK Writing cust...OK Writing system...OK Writing OP...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.9.6 Software version. i tried again with this firmware > k520dy20d_00_0331.oct here is logs : Code: Checking data...OK Platform: LG Qualcomm Selected port: COM62 Selected model: K520DY Reading info... Model ID: LG-K520DY IMEI: 357952-07-360619-7 Android version: 6.0.1 Battery level: 54% Mode: Emergency Initializing flash...OK Platform: msm8916 SW version: LGK520DYAT-00-V20m-GLOBAL-COM-MAR-31-2017+0 Android version: 7.0 LAF Version: 1.1 Product ID: CT01S160611000175 IMEI: 357952-07-360619-7 Target operator: GLOBAL Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "K520DY10g_00_1227.oct"...OK Selecting firmware partitions...OK Selected default partitions! Setting options...OK Do you want to format User Data? Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Sending signature...OK Writing PrimaryGPT...OK Writing sbl1...OK Writing tz...OK Writing hyp...OK Writing rpm...OK Writing aboot...OK Writing sbl1bak...OK Writing tzbak...OK Writing hypbak...OK Writing rpmbak...OK Writing abootbak...OK Writing persist...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing recoverybak...OK Writing sec...OK Writing factory...OK Writing modem...OK Writing cust...OK Writing system...OK Writing OP...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.9.6 Software version. what do i need to do? |
09-02-2019, 10:19 | #3 (permalink) |
Member: 388962 Status: Offline Sonork: 100.1637202 Thanks Meter: 264 | in blank screen, when i press volume or the screen to unlock, i can hear sounds. so it means phone is in activation i think,. but no display... but when i remove battery and turn power on, it shows logo then after 5 seconds, it disappear and i can hear LG startup tone. but no display.. |
