03-05-2017, 08:28 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: .........
Member: 665025 Status: Offline Thanks Meter: 44 | lg-k520dy primaryGPT error,. pls help team,.. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM4 Selected model: K520DY Reading info... Model ID: LG-K520DY IMEI: 357952-07-462757-2 Android version: 6.0.1 Battery level: 47% SW Version: K52010c Mode: Emergency Initializing flash...OK SW version: LGK520DYAT-00-V10d-ESA-XX-NOV-23-2016+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CT01S160709002406 IMEI: 357952-07-462757-2 Target operator: GLOBAL Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "K520DY10d_00_1220.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Writing PrimaryGPT...Failed! Performed by 2.5.1 Software version. already tried 2versions from support,. latest and old octo software,.. status before was no service,. so i decided to reflash first but now always reboot on emergency mode,.. |
03-06-2017, 08:32 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please install the latest Software version, then try to re-flash the phone again. Make sure, You don't downgrade phone's firmware version - downgrade may lead to device damage! Last edited by Octopus box; 03-06-2017 at 08:57. |
03-08-2017, 07:25 | #3 (permalink) |
Member: 665025 Status: Offline Thanks Meter: 44 | Welcome to Octoplus/Octopus Box LG Software version 2.5.9 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM5 Selected model: K520DY Reading info... Mode: Emergency Initializing flash...OK SW version: LGK520DYAT-00-V10d-ESA-XX-NOV-23-2016+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CT01S160709002406 IMEI: Target operator: GLOBAL Hardware: rev_10 Opening "K520DY20b_00_0209.kdz"...OK Firmware version: K52020j Firmware model: LG-K520 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Verifying checkSums...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Sending signature...OK Writing 1/57 PrimaryGPT_0.bin...OK Writing 2/57 sbl1_1024.bin...OK Writing 3/57 tz_2048.bin...OK Writing 4/57 hyp_3072.bin...OK Writing 5/57 rpm_4096.bin...OK Writing 6/57 aboot_5120.bin...OK Writing 7/57 sbl1bak_12288.bin...OK Writing 8/57 tzbak_13312.bin...OK Writing 9/57 hypbak_14336.bin...OK Writing 10/57 rpmbak_15360.bin...OK Writing 11/57 abootbak_16384.bin...OK Writing 12/57 persist_53248.bin...OK Writing 13/57 laf_93184.bin...OK Writing 14/57 boot_142336.bin...OK Writing 15/57 recovery_191488.bin...OK Writing 16/57 recoverybak_240640.bin...OK Writing 17/57 sec_295936.bin...OK Writing 19/57 factory_316416.bin...OK Writing 20/57 modem_513024.bin...OK Writing 21/57 cust_688128.bin...OK Writing 22/57 system_892928.bin...OK Writing 23/57 system_1155072.bin...OK Writing 24/57 system_1156616.bin...OK Writing 25/57 system_1160632.bin...OK Writing 26/57 system_1421232.bin...OK Writing 27/57 system_1680904.bin...OK Writing 28/57 system_1684920.bin...OK Writing 29/57 system_1945520.bin...OK Writing 30/57 system_2203648.bin...OK Writing 31/57 system_2205192.bin...OK Writing 32/57 system_2209208.bin...OK Writing 33/57 system_2469808.bin...OK Writing 34/57 system_2729480.bin...OK Writing 35/57 system_2733496.bin...OK Writing 36/57 system_2994096.bin...OK Writing 37/57 system_3253768.bin...OK Writing 38/57 system_3257784.bin...OK Writing 39/57 system_3518384.bin...OK Writing 40/57 system_3780528.bin...OK Writing 41/57 system_4042672.bin...OK Writing 42/57 system_4304816.bin...OK Writing 43/57 system_4566960.bin...OK Writing 44/57 system_4829104.bin...OK Writing 45/57 system_5091248.bin...OK Writing 46/57 system_5353392.bin...OK Writing 47/57 system_5615536.bin...OK Writing 48/57 system_5877680.bin...OK Writing 49/57 system_6139824.bin...OK Writing 50/57 system_6401968.bin...OK Writing 51/57 system_6664112.bin...OK Writing 52/57 system_6925304.bin...OK Writing 53/57 OP_7651328.bin...OK Writing 54/57 OP_7913472.bin...OK Writing 55/57 OP_8175616.bin...OK Writing 56/57 OP_8178832.bin...OK Writing 57/57 BackupGPT_30534656.bin...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.5.9 Software version. thanks team,.. by the way,. can you pls help me also about the signal,. service was disable, no service,.. |
