06-20-2019, 09:38 | #1 (permalink) |
Crazy Poster Join Date: Jul 2002 Location: a coruņa, spain Age: 47
Member: 13445 Status: Offline Thanks Meter: 11 | LG k9 X210EM 10j ORG (ORY) FRP unlock - failed [Solved] version 10j - ORG solution: downgrade (write firmware) to 10f. display garbages. frp unlock (blinded) OK write correct firmware (in my case 10j ORY). displays ok, phone working unlocked |
07-08-2019, 11:27 | #3 (permalink) |
Insane Poster Join Date: Jul 2006 Location: Romania
Member: 311520 Status: Offline Thanks Meter: 6 | why it does not work???? Platform: LG Selected model: LMX210EM Put the phone into Download Mode: 1. Power phone OFF; 2. Press and hold "Vol+" button and connect USB cable. Searching for a phone. Please wait... Found phone on COM24 Reading info... Detected phone model: LM-X210EM Mode: Emergency Initializing.. SW version: LMX210EMAT-00-V10m-EUR-XX-MAY-09-2019+0 Android version: 7.1.2 Platform: msm8909 Reset FRP operation for LMX210EM will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partition... Detecting writing method... Trying to repeat.. Trying third method... Resetting FRP lock.. Trying to repeat.. Operation was failed! Performed by 1.7.5.0 Software version. |
07-08-2019, 12:47 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Quote:
Read thread attentive, You can try to downgrade phone's firmware version but only at your own risk. | |
09-06-2019, 15:15 | #5 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 441775 Status: Offline Thanks Meter: 22 | same problem as error Welcome to Octoplus/Octopus Box LG Software version 2.9.6 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM13 Selected model: LMX210EM Reading info... Model ID: LM-X210EM IMEI: 353457-09-xxxxxxx Android version: 7.1.2 Battery level: 74% Mode: Emergency Initializing flash...OK Platform: msm8909 SW version: LMX210EMAT-00-V10j-EUR-XX-NOV-14-2018+0 Android version: 7.1.2 LAF Version: 1.1 Product ID: IMEI: 353457-09-xxxxxxxxxxx Target operator: LAO Hardware: rev_10 Performed by 2.9.6 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM13 Selected model: LMX210EM Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LM-X210EM IMEI: 353457-09-xxxxxxxxxxx Android version: 7.1.2 Battery level: 74% Mode: Emergency Initializing flash...OK Platform: msm8909 SW version: LMX210EMAT-00-V10j-EUR-XX-NOV-14-2018+0 Android version: 7.1.2 LAF Version: 1.1 Product ID: IMEI: 353457-09-xxxxxxxxxxx Target operator: LAO Hardware: rev_10 Reset FRP operation for LMX210EM will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Detecting writing method... Trying third method...Failed! Resetting FRP Lock...Failed! Error code: WHU8CHON7CFailed! Performed by 2.9.6 Software version. |
