Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2009
Member: 1026122 Status: Offline Thanks: 74
| LG KM900 flashing failed....please fix this problem... [Solved] Dear Octopus team.. My phone is not power on....always restart...So I try to flash the set.. I use USB and RJ45... also use the following files KM900AT-00-V10b-202-01-MAY-07-2009+0.oct KM900AT-00-V10f-ARB-XXX-JUN-12-2009+0.oct KM900AT-00-V10m-EUR-XXX-APR-27-2009+2.oct KM900AT-00-V10m-EUR-XXX-APR-27-2009+2 LOGS USB Welcome to Octopus Box LG Software version 2.1.4 -------------------------------------------------------------------------------- Platform: LG Infineon Selected port: USB Selected model: KM900 Disconnect battery and connect USB cable to phone... Reading info. Please wait... IMEI: 357366-03-037837-0 Opening "KM900AT-00-V10m-EUR-XXX-APR-27-2009+2.oct"...7/17/2012 OK Will be written 11 zone(s) Writing Firmware... Sending certificate...7/17/2012 12:46:32 AM > OK Writing "psi_large_block_16_bit_paging.flb"...7/17/2012 12:46:32 AM > OK Sending certificate...7/17/2012 12:46:36 AM > OK Writing "slb_large_block_16_bit_paging.flb"...7/17/2012 12:46:37 AM > OK Sending certificate...7/17/2012 12:46:45 AM > OK Writing "MPEH_OPERA_EUROPE_OPEN.fls"...7/17/2012 12:47:11 AM > OK Writing "MPEH_OPERA_EUROPE_OPEN.fls"...7/17/2012 12:47:41 AM > OK Sending certificate...7/17/2012 12:47:45 AM > OK Writing "MPEH_OPERA_EUROPE_OPEN.eep"...7/17/2012 12:47:45 AM > OK Sending certificate...7/17/2012 12:47:49 AM > OK Writing "MPEH_OPERA_EUROPE_OPEN.dsp"...7/17/2012 12:47:50 AM > OK Sending certificate...7/17/2012 12:47:53 AM > OK Writing "ua_large_block_16_bit_paging.flb"...7/17/2012 12:47:54 AM > OK Sending certificate...7/17/2012 12:48:02 AM > OK Writing "OPERA_EUROPE_OPEN-ROOT.dfat"...7/17/2012 12:48:19 AM > OK Sending certificate...7/17/2012 12:48:23 AM > OK Writing "OPERA_EUROPE_OPEN-CUST.dfat"...7/17/2012 12:51:19 AM > OK Sending certificate...7/17/2012 12:51:23 AM > OK Writing "OPERA_EUROPE_OPEN-USER.dfat"...7/17/2012 12:51:23 AM > OK Sending certificate...7/17/2012 12:51:27 AM > OK Writing "a250_single_image.fls"... Error of writing block! Disconnected. RJ45 Welcome to Octopus Box LG Software version 2.1.4 -------------------------------------------------------------------------------- Platform: LG Infineon Selected port: COM6 Selected baudrate: 921600 Selected model: KM900 Please reconnect battery, press and hold power button... Phone found. Release power button. Sending loader...OK Reading info. Please wait... IMEI: 357366-03-037837-0 Please select Fiwmware file! Opening "KM900AT-00-V10m-EUR-XXX-APR-27-2009+2.oct"...OK Will be written 11 zone(s) Writing Firmware... Sending certificate...OK Writing "psi_large_block_16_bit_paging.flb"...OK Sending certificate...OK Writing "slb_large_block_16_bit_paging.flb"...OK Sending certificate...OK Writing "MPEH_OPERA_EUROPE_OPEN.fls"...OK Writing "MPEH_OPERA_EUROPE_OPEN.fls"...OK Sending certificate...OK Writing "MPEH_OPERA_EUROPE_OPEN.eep"...OK Sending certificate...OK Writing "MPEH_OPERA_EUROPE_OPEN.dsp"...OK Sending certificate...OK Writing "ua_large_block_16_bit_paging.flb"...OK Sending certificate...OK Writing "OPERA_EUROPE_OPEN-ROOT.dfat"...OK Sending certificate...OK Writing "OPERA_EUROPE_OPEN-CUST.dfat"...OK Sending certificate...OK Writing "OPERA_EUROPE_OPEN-USER.dfat"...OK Sending certificate... Error of changing certificate! Disconnected. It is not the hardware problem..100% software problem.. Now the condition of the phone is dead...But I can connect it via RJ-45 or USB... There are so many users report this problem...So Please fix this.. Thanks. Last edited by Octopus box; 07-23-2012 at 13:09. |
| | #2 (permalink) | |
| Product Supporter ![]() ![]() ![]() Join Date: Oct 2009
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks: 3,606
| Hello. What was the firmware version exactly in the phone before You have tried to write wirmare? Please try to write firmware again, a few times. If the problem will be in the same place - most likely this is HW problem. Quote:
| | #3 (permalink) | ||
| Quote:
Also Quote:
You advice for many users as hardware problem... But this is not hardware problem 100%. it is software...Please give any solution for this. | ||
| | #4 (permalink) |
| Please write firmware using original LG flasher and post here the result. Look for original firmware and flasher in LG section on this forum. |
| | #9 (permalink) |
| Failed Bro..Please check ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us May be need to flash the higher version.? Thanks. |
| | #11 (permalink) |
| Check Your PM for another firmware. If the problem will be the same - most likely, as I have said, this is HW problem. |
| | #15 (permalink) |
| Dear Bro.. As you told me ....100% right...It is hardware ..not the software... When I check the board..I did not touch the any IC or chips...Insded I clean the board using thinner and give the time to try the board And try to flash using the original flasher with last file you pm me.But I failed on 10/10 27% which last time even did not start 1% on 10/10...So I tried on Octopus with the file of KM900AT-00-V10m-EUR-XXX-APR-27-2009+... Ohhhh??.. I success with the great Octopus Box which gave the live to my km900 set. here is the log.. Welcome to Octopus Box LG Software version 2.1.4 -------------------------------------------------------------------------------- Platform: LG Infineon Selected port: COM6 Selected baudrate: 921600 Selected model: KM900 Please reconnect battery, press and hold power button...Canceled! Disconnected. -------------------------------------------------------------------------------- Platform: LG Infineon Selected port: USB Selected model: KM900 Disconnect battery and connect USB cable to phone... Reading info. Please wait... IMEI: 357366-03-037837-0 Opening "KM900AT-00-V10m-EUR-XXX-APR-27-2009+ 2.oct"...OK Will be written 11 zone(s) Writing Firmware... Sending certificate...OK Writing "psi_large_block_16_bit_paging.flb"...OK Sending certificate...OK Writing "slb_large_block_16_bit_paging.flb"...OK Sending certificate...OK Writing "MPEH_OPERA_EUROPE_OPEN.fls"...OK Writing "MPEH_OPERA_EUROPE_OPEN.fls"...OK Sending certificate...OK Writing "MPEH_OPERA_EUROPE_OPEN.eep"...OK Sending certificate...OK Writing "MPEH_OPERA_EUROPE_OPEN.dsp"...OK Sending certificate...OK Writing "ua_large_block_16_bit_paging.flb"...OK Sending certificate...OK Writing "OPERA_EUROPE_OPEN-ROOT.dfat"...OK Sending certificate...OK Writing "OPERA_EUROPE_OPEN-CUST.dfat"...OK Sending certificate...OK Writing "OPERA_EUROPE_OPEN-USER.dfat"...OK Sending certificate...OK Writing "a250_single_image.fls"...OK Writing Firmware done! Disconnected. Now I have the fully working set. Thanks for the great hardworking Team. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Sim card sleep mode problem with 6130 | ratzfatz | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 05-22-2012 11:13 |
| my 8810 is phone locked ,can somebody please help | duyphuc | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 16 | 02-01-2012 05:18 |
| Seeking for flash nokia 5110 old version (3 version) can exchange for new | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 11-17-2011 17:08 |
| 5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 2 | 07-07-1999 12:27 |
| "Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 06-28-1999 14:56 |
